Question about GE Profile Harmony DPGT750GC Gas Dryer
General error message
Dryer displays "Problem found with dryer, call 1-800-GET HELP", was working fine the loads before. Is there anyway I can troubleshoot or reset? Happened within 1 day of an email stating my warranty was up and I should purchase an extended service contract.
  • 179 Answers
I would purchase an extended warranty because the problem will not just go away. It will eventually get worse
Posted on Dec 23, 2008
Brand new Electrolux EIED200QSW compact 220v dryer has error message "unstable mains supply". Also displays error message E04.
Hello Scott, thank you for your inquiry!
From the information you have provided your Electrolux dryer is displaying an error code of "E04". I see that this dryer is a new appliance from the manufacturer and I would recommend contacting them directly for further assistance. I hope that this information is helpful to you. -Matt
Feb 20, 2016 | Electrolux Dryers
Service Cord message
Check for a good ground, Appliances now days will not run without proper ground because of the electronic boards
Feb 04, 2014 | Electrolux 8.0 Cu. Ft. Electric Front Load...
Dryer working fine but no heat coming through, displaying e72 error code
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Feb 13, 2011 | Zanussi ZWD1470W Front Load Washer / Dryer
I was drying, a load finished fine. Put the next load in, turned the knob for setting and I got the error code of "PR" and it wont turn on. The display is not working. So I unplugged it, then reset the...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 30, 2010 | Electrolux Frigidaire Affinity AGQ8700FE...
Error PF
PF simply means power failure, not really a fault as much as a visual indicator to let you know that you've experienced one. i would check your electrical outlet,sounds like a loose connection
Mar 04, 2008 | Frigidaire GLEQ2152ES Electric Dryer
Error code on dryer display
Check your breakers. Mine was doing the same thing, all of the 120v parts of the machine were working. (blower/drum motor/ lights) However the element wasn't coming on. Went to the breaker and found that one side of the 2 pole breaker was tripped. Turned both off and back on. Heater started working again.
When you set the dryer on settings such as normal or permanent press, it engages the various sensors that help the dryer to make the most efficient use of energy. Moisture sensor, heat sensor etc. (THAT IS WHAT TURNS ON YOUR AD SETTING) Normally it selects a time based on factory settings that it believes your load should be dried by. Say 50 minutes at Normal (high heat, normal) Every so often during the cycle, the machine will check the humidity sensor and the other sensors and try to see if the dryer is still on schedule. Sometimes it will determine that more time is needed, occasionally less time. While it calculates, it displays the Ad meaning that the machine is on auto dry. TO TURN OFF AUTO DRY, set it to a time setting instead of a DESCRIPTION setting.
Oct 26, 2007 | Frigidaire GLEQ2152ES Electric Dryer
E10 error code
I had this problem, the washer/dryer stopped working while in the drying cycle and displayed e10 message. It was caused by a faulty three-way inlet valve. The solenoid controlling flow to dryer condenser proved to be open circuit. Pulled washer out from under counter top, unplugged, removed top cover, tested solenoid circuits with ohm meter and found one solenoid was faulty. The filter going into the unit was clear. Replaced whole three way component with one ordered on Internet and all now works fine. Noticed that during drying cycle, water to condenser is constantly being switched on and off, explaining why the green condenser solenoid is the one that wears out first.
Mar 03, 2007 | Zanussi WJS1265W Front Load Washer/Dryer
Sometimed error being displayed but also not completing cycles and not performing a fast spin
Hi there, I've also had this problem a few times. I've found cleaning out the filter can help solve the problem of the E20 message. Also when it doesn't spin fast it usually means the load is uneven. I found it happens with towels or bedcovers, heavier loads, if the load is uneven it will spin slowly for a good few minutes and then just stop with the clothes still dripping. I found rearranging the load more evenly usually sorts it out. I've had my machine for 18months now and usually love it. It washes and dries well, however, my dryer has stopped working again! I'd only had the machine 7 months when the dryer first stopped working another 11 months down the line and it's not working again! Hope this helps. Lelly2003
Oct 27, 2006 | Zanussi WJD1667W Front Load Washer / Dryer
GE Profile Harmony DPGT750GC Gas Dryer Logo
83 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
