Question about Canon imageRUNNER C3200 Copier
Color printing problem printing in double image looks there is registration problem irc3200 canon
    Sniper:
  • 57 Answers
There is a good chance that you have a problem with your laser motors. There are cams in the laser units for adjustment for colour registration. Check if anu of this cams on each laser are not clogged or something..
Posted on Dec 26, 2008
  • 168 Answers
This is allmost allways the transfer belt assy if you have over 200k on the machine the belt is slipping ever so little. you can take out the unit and remove the belt and clean all the rolles esp the largerer drive one. seen this many times
Posted on Dec 23, 2008
  • andzulisv Dec 24, 2008
    ok did you do any of these things if your colors are not registrating on top of the others this is the problem
How do I fix my Canon IR c5185 printing double image
Check the fusing unit if the heat roller engaged? The unfixed image at the roller causing Double image too in Canon IRc5185.
Nov 27, 2014 | Canon irc5185i
Cant get the canon imagerunner c3220 to print from imac macosx -10
This is a tricky one. The newer MAC OSX does not like the older printer drivers. It usally requires extra software from Apple to deal with these products. Now that being said it should load by itself. I can tell you without a doubt you can not use the self installer as it will fail each and every time. To keep it simple get ip address of the iRC3220 and go in to you printer install and point it to the PPD file which you can get from the Canon website. Final point... There is a different PPD for iRC3200 with Fiery (C1 print controllers) and one without. They are not cross compatible. You will see iRC3200 with C1 and one just saying iRC3200. Pick the right one. Oops one more point the Queue name will be just the word print. Good Luck.
Jun 22, 2011 | Canon imageRUNNER C3220 Color Copier
Canon irC3200 Yellow Bar Going Through Prints
try this press asterisk* with head then on the control panel press adjustment and cleaning then go to clean main inside unit run this 2x. try to phocopy white paper only .check wether the yellow bar is still there it could be this a problem of transfer belt cleaning unit .you can clean this by removing the waste bottle and remove one screw and pull out the cleaning unit and cleaned it and return everything hope this will help
Jul 12, 2009 | Canon Office Equipment & Supplies
IRC3200 - Color Printing Distorted
hi
check your counter if already reach 2k
its means you need to replace the itb belt or assy
any question just leave a message
May 21, 2009 | Canon imageRUNNER C3200 Copier
HP 1600 Colour laserjet Double image
Colour registration problem (some printer loose their registration from time to time).
There will be an option somewhere in the menu system of the printer, or the HP 'Toolbox' to correct this.
Apr 04, 2009 | HP Color LaserJet 2600n Printer
Canon imageRunner 3200n printing problem in color
ok you are in the right area are you taking the belt off to clean those rollers???? if not do that 1st. then you may have to clear the dc controller but 1st do a DPRINT under the service function menu. after the dccon clear you will need to put those #s back in
Dec 24, 2008 | Canon imageRUNNER C3200 Copier
Manual/Drivers and software for a Fiery on a Canon IRC3200
ok the driver for the printer is at imagerunner.com support/ drivers/ office-production then look for imagepass E-1 im assuming you have a print controller attached to the copier. i think you can also get the guides there also for the fiery... Not sure about manuals for the copier never looked
Dec 10, 2008 | Canon imageRUNNER C3200 Copier
Brother MFC-9420CN has double image in color only!
There should be a COLOR REGISTRATION function in the menus.
Sep 19, 2008 | Brother IntelliFAX 4100 Laser Fax
Documetation for canon IR3200N
Hi friends,
I cleared DC -CON of IRC3200,After I am getting double image problem,I put all values back but same problem,If anybody have a soluation pl. let me know.
Thank you
Aug 04, 2008 | Canon imageRUNNER C3200 Copier
CANON irc 3200 PERINTER
in the printer settings you can check there is a only one color selected so please change in auto coulor. if solve this ple letme konw at my email add ok sir take care
Mar 11, 2008 | Canon imageRUNNER C3200 Color Printer
Canon imageRUNNER C3200 Copier Logo
308 people viewed this question
old marine
old marine
