Question about HP Pavilion TX1000Z 12.1" Touch Screen TABLET NOTEBOOK LAPTOP PC PC Notebook
Broken ts my HP txt1499us has a broken touch screen. The monitor works just fine but the glass behind the touch screen's plastic shield is broken, not allowing the TS to work. Is there a way to remove the plastic and the glass and just usee the laptop as a regular laptop vs using the TS?
Yes you can take the glass out but leave the plastic that protects the screen. but remember your touch screen wont work if the glass is not replaced which can be a bit expensive
Posted on Jun 24, 2009
    Problem Solver:
  • 17 Answers
Ummm, the glass is actually adhered to the screen border, and not a protectant but rather the conduit for the stylus pen (for your digitizer functions). The LCD+Glass combo is NOT sold as a separate item, unfortunately, you will need part# 441106-001 for the full assembly plastics and all. There is a less-expensive alternative, part# 441758-001 which is LCD only, but it's the BrightView display and NOT the digitizer-enabled screen. Should be half the price of the full assembly and much safer solution than removing thick shards of broken glass from ur laptop, also it nets the same result of what ur looking to do.
-Sy
Posted on Jul 07, 2009
2 Suggested Answers
SOURCE: Broken touch screen glass
thanks for the help!..after using a screwdriver removing the 8 screws on my tx2500 screen (front) and carefully using a small knife swiss army knife along the edges to remove the glued on glass screen my laptop works like a normal one. take your time. its possible to "fix" by removing the touch screen portion of the display so long as the other part is not damaged. i dont know if i did it the best way but it worked and im happy!
Posted on Feb 24, 2009
How do i replace a broken laptop screan
Take out Battery
Remove screw covers on monitor
Remove screws
Remove plastic Bessel around screen
Remove screws at top screen assembly
Loosen screws at bottom top screen assembly
Remove video cable behind Screen
Remove screws on side of the screen
Remove webcam cable
Remove video connector
Found it on this video:
HP ProBook 4525s Notebook Screen Replacement Procedure
Feb 04, 2014 | HP ProBook Computers & Internet
The touchscreen of my Z22 is broken
The Z22 is a bullet-proof device for securely saving your personal data, and full marks go to the team at PALM for its solid design. However, the AGE of the Z22, over the last decade, results in 3 problems - the batteries are all dying, and the delicate plastic touchscreen top layer is deteriorating - simply through AGE. When you say the touchscreen is "Broken", I would guess you mean that it does not respond to touch commands from the black plastic stylus that sits in the slot on the back, side, of the unit, when stored. I have never actually seen or heard of a screen that is physically "broken" - like the thousands of iPod, iPhone, Motorola RAZOR, and other touch screen phones that you see today, with cracks running across the broken GLASS. It "Could" happen that the glass screen under the top plastic touch layer is, actually "BROKEN", with the resulting cracks, but this is unlikely, since the trim around the screen is raised a HUGE distance, compared to today's touchscreens.
You can easily replace the screen for $9 if you wait for free shipping from CHINA, or, you can try a few tricks I learned on my Z22 over the years. I have put it in the freezer - which worked temporarily, heated it with a hair dryer - which worked temporarily, and peeled the top plastic layer off the screen- which worked temporarily. I have also replaced the screen with a new one. It is IMPERATIVE to put a hard plastic cover on the Z22 at all times- or you will eventually loose the screen again...
My Z22 page is at:
kidbots.com/WEBADD/Z22_PALM_PILOT/Z22_PALM_PILOT.html
I hope this helps you to get your Z22 back up and running
have fun
good luck
robin dusty graves
Z22 PALM PILOT touchscreen-z22-broken-ngl0e1lc0ft3j10pmz4xzklk-1-0.jpg touchscreen-z22-broken-ngl0e1lc0ft3j10pmz4xzklk-1-1.jpg touchscreen-z22-broken-ngl0e1lc0ft3j10pmz4xzklk-1-3.jpg
Dec 12, 2009 | Palm Z22 Handheld
How do I remove the bezel from my hp l1955 monitor
There usually screws hidden behind stick-on plastic covers on the front and or edges of the screen. Use a sharp point to lift off these covers to reveal the screws.
The bezel will also have plastic catches/clips that secures the bezel to the lid as well as double sided tape. Slip a thin blade between the glass screen and bezel and gently lift the bezel free. Start at a corner and gradually work along each side.
Be careful not the apply too much pressure on the glass (it is easily cracked) and be careful not to scratch the screen.
Nov 15, 2009 | HP L1955 19" LCD Monitor
A broken handle on door&how to fix it
To access the door handle mounting screws, you have to remove the inner door panel that goes around the perimeter of the glass. You can use a small screwdriver to simply pry the plastic up and work your way gradually around the perimiter of the glass. Most microwave ovens have grooves in the panel that you can insert the screwdriver into. Use care not to pry against the glass. The glass is tempered and also has an RF shield that prevents harmful microwaves from potentially harming the consumer. If you break the glass, you will need to purchase a new door.
The door handle screws are located behind the inner panel. Simply remove the broken handle and install the new one. Re-insert the inner door panel carefully and gradually work your way around the perimeter of the door glass and make sure it snaps back into place.
If you have questions, or need assistance ordering parts, please let me know. Post back with your Model Number if you need parts assistance. I hope you find this information helpful.
May 13, 2009 | GE Microwave Ovens
they've got screens for about $205 for the tx2500 and the tx1000 with easy to understand manuals on ebay at the following site: http://shop.ebay.com/merchant/browngranite_W0QQ_nkwZQQ_armrsZ1QQ_fromZQQ_mdoZ
Sep 23, 2008 | HP Pavilion TX1000Z 12.1" Touch Screen...
Monitor
If your LCD monitor has damage it could be in three forrmats:
1) Damage LCD ribbon. The screen will power up bright white and you will see random strings of color in diaganol or horizontal streaking slowly across your screen.
2) Damaged Liquid Crystal Container. The thin glass/plastic may have ruptured due to an impact on the screen. You will see sharp jagged lines and maybe a partial post screen, but where the sharp "jaggies" are, are now permantly broken
3) Nothing on screen. This indicates that your internal CCFL (oh I love LED technology) tubes have now lived their life and will not ignite. To test this method, hold a very bright light to the screen and see if you can see any logos (Compaq/HP/Win Xp loading screen...etc)
If you can see something, your screen is fine, but there is no light behind it for you to see.
Hope this helps.
Jun 05, 2008 | Compaq tc1000 Tablet PC
Touch screen half loading only
Try uninstalling the TS from the control panel-system-devices (hardware).
Reboot and reinstall the drivers when asked.
The driver must match the OS.
The TS may be defective, does it operate proper on another Pc?
Mar 14, 2008 | Computers & Internet
BROKEN SHIELD
Behind the protective shield are two plastic layersright next to each other if the front one is not broken and the quality of the picture is good considering the damage to that specific spot on the screen you should not have to replace it,only remove whats left of the broken shield.Be careful not to scratch that front lens.
Sep 21, 2006 | RCA P61960 61" Rear Projection Television
HP Pavilion TX1000Z 12.1" Touch Screen TABLET NOTEBOOK LAPTOP PC PC Notebook Logo
289 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
