Question about Konica Minolta bizhub 350 All-In-One Laser Printer
BizHub 350 Network Fax - Prints instead of faxing
I have installed the network fax software on my computer. I have also set up the BizHub 350 on the network.
When I try to fax from my desk...I get the network fax screen and I can successfully put in the phone number...However, the BizHub never tries to dail out...Instead it simply prints the document.
  • Anonymous Mar 27, 2014
    Faxs not printing out...
    fax not printing on bizhub c35
May i ask ! so where to get the network fax driver ?
Posted on Aug 01, 2012
I try to solve my problem with above mentioned solution but password of my machine has been change by bizhub company technician what shall i do next
Posted on Jul 01, 2010
Set the Gateway TX to "Allow"
1. Press the Utility/Counter button.
2. Touch Admin Management
3. Enter Password (The default password is 12345678)
4. Touch Admin2
5. Touch Network Settings
6. Touch Network Settings1
7. Touch Scanner Settings
8. Touch Gateway TX
9. Set Gateway TX to Allow
Posted on Jan 16, 2009
My printer will not fax says not connected to network when it is.
faxing requires some type of Phone connection in most instances, network faxing is another set of drivers that need to run on your PC, the same as phone line faxing that utilizes your modem (as long as the modem is fax capable) the issue you have is the way it is set up. first off you have to have the communications between the printer and the computer running properly. If you do not have a router with a wifi connection and the printer is connecting directly to the computer wirelessly, you need to make sure it is set for peer to peer networking, if you have a true network using a router and wifi (more than one computer can connect to it, you need to make sure you are set for that. Remember, you are not faxing from the printer if it is not connected to a phone line, you are faxing from your computer. and you need to make sure you are running the correct type of fax software, for network faxing or dial up (phone line) faxing.
Jan 21, 2015 | HP Photosmart 7510 e-All-in-One -...
Need to replace the drum on a minolta bizhub 350 copier
First get into service mode. Utility/Counter then meter count then check details. Then Stop 00 stop 01. Counters. Clear Drum and Developer. Then touch end do not exit all the way out of service mode. Turn off the machine using the main on/off rear of machine left hand side. Then remove the image cart. and replace the drum and developer. then turn machine on reenter service mode. Run F-8 found under Function. Do not print copy or allow fax to print before this is done. Or you will have to replace the developer again. So remove network cable and fax line if machine is as printer and FAX. after powering off
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Jan 15, 2014 | Minolta bizhub 350 Black and White Copier
Bizhub 350 cannot receive faxes
There are two clips on the fax PCB, make sure you are using the Line and not the handset. Also, do you have the fax card installed and did it ever receive faxes? It may be a issue with the phone line.... Good Luck
Nov 16, 2012 | Minolta bizhub 350 Black and White Copier
Minolta bizhub C250 is "offline" every time it rains/electricity
Does your copier have a good surge protector or is just plugged into the wall and not some 5 and dime surge protector ???? does the surge protector have the network cable protected to???? goods one will protect power fax and network. Why FTP (File Transport Protocol) File sharing Do you scan to one or to your computers and email????
Have a electrician come out place the copier on its own circuit.
Oct 14, 2017 | Konica Minolta bizhub C250 All-In-One...
Pc fax transmission problem for bizhub 750?
The only solution may be a very expensive "Fax server".
You must have the fax kit in order to translate your print file to the fax language.
Is like trying to send an email without a modem, you may have access to a network but cannot talk the language required.
Feb 12, 2009 | Konica Minolta bizhub C250 All-In-One...
Question about Konica Minolta Bizhub 350
click here for the steps on how to configure the bizhub 350 and here for the vista driver that you need to use if you're going to install it in a vista computer
hope this'll help you
ciao
Aug 26, 2008 | Konica Minolta bizhub 350 All-In-One Laser...
Fax device I/O error
installed samsung scx-4521f multi function printer. can't fax from smarThru program. get message : Fax device I/O error
Jan 11, 2008 | Samsung CLX 3160fn All-In-One Printer
Konica Minolta bizhub 350 All-In-One Laser Printer Logo
1,304 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
carpediemweb
Level 1 Expert
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
