Question about Indesit W 123 Front Load Washer
Snapped door lock on hotpoint washer/dryer
We have a hotpoint frontloading washer/dryer, during the wash cycle we heard a loud snapping noise and it turned out the catch on the door had snapped. we have been able to duct tape the door shut in order to let it run the rest of the wash (it was half full of water). is this easily fixed, or are we going to have to get a new washer? i am hoping it's something we can do, or is easily fixed before christmas. we haven't had it very long, but our landlord bought it second-hand, so i don't know how old it actually is.
thanks in advance for any help :)
  • racheltomlin Dec 23, 2008
    oops, i thought i had posted this in the hotpoint bit, sorry!
  • 640 Answers
This happens when unit goes off balance and tub bangs door..open door.. you will see to screws holding the door locking device remove,,now take a screw driver and remove the front wire spring clip..replace latch and door probe,,reverse to put back together
Posted on Dec 25, 2008
Hotpoint wma48 shuts down anywhere during cycle
which suggests possible the faulty door lock has been fitted with another faulty door lock. this has happened to me on two or three occasions in different situations.
May 23, 2016 | Hotpoint Washing Machines
Hotpoint WMA62 washing machine door won't release
If the machine didnt finish the cycle due to the pump being clogged the door will remained locked also if the lock mechanism went bad, the machine will stay locked. Remove the top of the machine by taking the screws from the top back out. Once removed look down the right hand side and you'll see the lock mechanism, usually with a plastic tab you pull to manually release the lock.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Apr 24, 2012 | Hotpoint WMA64 Front Load Washer
My hotpoint WNA64 has been making loads of noise during the spin cycle now the belt has snapped are the two conected?U
I say so think its drum bearing failure common on this machine is the drum noisy on its own try a hand turn and see could also be a sock stuck in it if not free....Please leave feeddback
Apr 08, 2010 | Hotpoint WMA64 Front Load Washer
Magic Chef Clothes washer model CAV2004AWW
Something locked up on the transmission then the drive belt broke. Put on a new belt and try a spin cycle, if it works but it won't agitate then the trans will need replaced.
Feb 28, 2009 | Magic Chef CAV2004A Top Load Washer
Indesit wil 113 washing machine
try to put more clothes but not to much it wont banging.
must change door lock switch.
Feb 14, 2009 | Hotpoint Aquarius WD63 Front Load...
Washing machine won't spin
Do you hear the motor spinning loud whirring noise,when drum is not,if so drum belt has come off or snapped,if no noise possible brushes on motor need replacing
Jan 18, 2009 | Hotpoint Ultima WD72 Front Load...
Hotpoint WD 865- washes ok, dryer won't work makes loud popping
sounds like the dryer heater element has worked loose perhaps and shorted out against the metal dryer box which sits on top of the drum.
best to get an engineer out i'd say.
Jan 14, 2009 | Hotpoint Aquarius WD63 Front Load...
What you need is a new door latch assy. To fit, remove all screws that hold the 2 halves of the door together, and prize the 2 halves apart, be careful the door glass does not fall to the floor and break.
Fit the new door latch, and reassemble door.
That should solve your problem.
The part is relatively inexpensive.
If you can;t obtain the part locally,then try:
www.hotpoint.co.uk
Plz rate my solution.
Thanks.
Dec 23, 2008 | Hotpoint Aquarius WD63 Front Load...
Door Lock Light - flashing
does the door still lock? becasue it sounds like a faulty lock. It may need to be replaced.
Aug 25, 2008 | Hotpoint WMA46 Front Load Washer
Indesit W 123 Front Load Washer Logo
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
