Question about Canon PIXMA MP470 All-in-One Printer
Error code 6000
I tried to print something on my printer today...it said there was a paper jam... I throughly checked it out and there was no paper jam. It is now giving me error code 6000 and the Alarm light flashes. Any ideas on how to fix? I've tried turning off and back on as well as unplugging. i went to turn my computer on today and when it finally warmed up i heard a loud grinding sound and then the Error code 6000 appeared. and there is no paper in there yet to jam.
4 Suggested Answers
SOURCE: Error code 6000
I had same trouble with pixma MP110. Did everything but no luck. Noticed the paper feed tray was off centre...turned it all upside down and a drawing pin fell out. it was jammed behind thepaper feed and unit itself. All works well now. So, check something has not dropped into the paper area!!!
Posted on May 16, 2008
I have been driving myself crazy with this same problem MP470 Error 6000 to no avail cleaned the machine to the extreme...no paper inside. Followed solution #9 but still in error. Used these reset instructions and now feel like the smartest person on earth. With the power off, press the reset button (red) and hold while pressing the green power button. Release the red reset but continue to hold the green power button. While still holding the green power button, press the red reset button twice and then release both green and red together. Now press the red reset 4times. Power off and you should clear the blinking orange. Hope this helps someone else. Now I need to go clean this ink off my fingers!!!
Posted on Dec 15, 2009
optimus101919
Sounds like driver related problem to me, try re install your driver by CD, or just download this Driver Update Software for XP Vista 7 8, and update the driver. Have a nice day
Prime
Posted on Jan 07, 2015
Error code 6000
Error 6000 is a line feed error, it means the platen roller isn't advancing properly. It usually means something has fallen in from the back where the paper goes and is stopping the rollers from turning.
Check the printer for any paper jam or try to reset the printer to release memory code errors.
1. Press and hold the Resume button for 1 - 2 minutes.
2. Open the cover.
3. Remove the cartridge and then reinstall it.
4. Close the cover.
5. Turn Off the printer.
6. Turn On the printer.
Jun 14, 2011 | Canon PIXMA mini260 InkJet Photo Printer
Printer error has occurred 6000
Error 6000 gets displayed when there is a paper jam or other general malfunction. When the message "6000 Printer error has occurred. Turn off the printer then back on again. If the problem persists, see the manual." Is displayed, something may block the paper feed tray from opening.
If the printer is surrounded with documents or when you copy large documents such as books, make sure that you secure the clear space in front of the tray before printing / copying. When the error message above is displayed and if you find something is in front of the tray, remove it. Then, turn OFF the printer and back ON again and the printer will be ready for printing.
If you still have the trouble, contact the repair service.
2. Open the cover.
4. Close the cover.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Feb 14, 2011 | Computers & Internet
Printer Error message : Printer Error has occurred. 6000
2. Open the cover.
4. Close the cover.
Dec 21, 2010 | Canon Office Equipment & Supplies
Getting code 6000
Error code [6000] or light blinking 3 times.
1. Smearing or scratches on the LF encoder. Please clean the LF encoder.
2. Foreign material or paper debris in the LF drive. Please remove any foreign materials if encounter.
3. Check cable connection.
4. Replace LF encoder or Logic Board or Paper Feed Motor or Paper Feed Roller Unit
May 27, 2010 | Canon PIXMA MP620 All-In-One InkJet...
I keep getting error 6000 when I am trying to print how do I rectify this
Hi there
I think THE 6000 is the same problem error as the ERROR 6A00
This answers with a titch more detail.
The 6A00 is a Canon generic code for paper path jam.
Some where in the paper path a sensor is activated indicating paper jam so the printer will give off a 6A00 code.
As a Canon tech, I usually find the code, almost 90% of the time, is related to the purge unit being jammed with something and not being able to move.
Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like.
And yes I have found all those things in a purge unit.
The offending item needs to be removed or the purge unit needs replacement.
Incidentally, the 6A00 error pertains to all Canon printers made in the last several years, its not just used in one model.
And it’s always a paper path error or purge unit.
The purge unit, called a spittoon assembly in an HP, Lexmark, and other inkjet printers, is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing.
That is where you'll find the print head assembly parked on top of it.
It also has an electrical pump to milk the print heads and test for ink flow.
So clean all under where the heads are parked and on IP6600D models you can take out the heads just by clipping them out, and then clean well.
Also clean the purge unit out make sure all is clean.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Mar 19, 2010 | Canon BubbleJet i560 InkJet Printer
Canon error code 6000 in mx308
please help me. i have canon print mx308. the have paper jams. paper has the full out from print. how i can finish the problems?
Jul 25, 2009 | Canon Pixma MP450 All-In-One InkJet...
What is error 6000
I the paper is jammed. Purge unit is jammed with something and not being able to move. Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like.
Jun 26, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Error code 6000
  • Unplug the printer cable from the computer.
  • Unistall the printer drivers from Device manager and also unistall the all the printer appications
  • restart the computer
  • try to download drivers from the website
  • after installing drivers and software it will ask you to connect the printer.
  • then you can connect the printer and and try to Print the test page.
Apr 27, 2009 | Office Equipment & Supplies
Error code 6000
Prime
Jul 16, 2007 | Canon Pixma MP450 All-In-One InkJet...
Canon PIXMA MP470 All-in-One Printer Logo
42 people viewed this question
Clive
Clive
old marine
old marine
