Question about Proview PS 709 17 in.CRT Conventional Monitor
Proview monitor Hi. i have this proview monitor. I only see half of the picture, which is the bottom half and there is a white line across the screen. I checked the voltage the vertical ic. the voltage supply is 15 and there is no out put coming out of that ic..any ideas. let me know soon
  • 225 Answers
SOURCE: Proview 15" screen turns white
probably failure in the LCD controller IC in the lcd controller board. that no signal was sent out to the lcd driver ic thus you could only see white display. A replacement of LCD panel is the best solution. I suggest to bring it to an authorized service center. best regards
Posted on May 22, 2009
0 characters
1 Points
My lg m2762d lcd tv has a half millimeter white line across the screen can you tell me whats wrong?
makes a difference where this line is... very top, top, middle, bottom, very bottom? also, is this set new to you, or has it been fine for a while, and just started doing this? does the line stay there when you switch to other inputs? (like a dvd player or a gaming console)? this kinda stuff will help you get an answer that makes sense - good luck
Dec 11, 2010 | LG W2753V PF Flat Panel 27" LCD monitor
I have a Proview PL716S and sometimes the entire
ur monitor got err i need to be changecoz repairing of monitor is unprofit
Apr 14, 2010 | Proview PL916S2 Monitor
My proview 558 monitor has a 1/2 inch black line at the bottom
ms_biguns, You need to test one or the other, The tower should output and drive a substitute known good monitor, or a known good pc should be able to display the WIN-desktop screen on your Proview 558. Could it also be that the software in pc not set up for driving a Proview558? 12fixlouie
Feb 28, 2010 | Proview Computer Monitors
White horizontal lines flicker and screen goes off.
check the wiring inside the monitor, pull the sceen out and move the wires with the screen on so you can see when it's working. then tape the wires where it works.
Dec 16, 2009 | Proview PL926WBi 19" LCD Monitor
My ViewSonic monitor is having an issue with blurring lines. Anything on the left or middle of the screen blurs to the right in a faded color, extremely noticable when I open MS Paint and fill the left...
This is a tipical flyback defect circuit, the lines can 1st appear on top/bottom of screen, then can increase to center. Send monitor to repair center, for check and repair. You can test with a tv test signal.
Dec 11, 2009 | Computer Monitors
Darker fatter letters every 2 inches apart from top to bottom
it is called phase you can attempt to let the lcd monitor auto set or you can disconnect the power over night then plug in and then do not auto set this default usually seems best some times
Nov 29, 2008 | Proview PL926WBi 19" LCD Monitor
Streaks make letters fatter every 2 inches apart across screen
this is called phase it can be set auto by the button or you can disconnect the power and next day reconnect and leave it in default which can be better than letting the monitor try to set the phase.
Beware this monitor! PL713s
Probably a good solution. 17" LCD's are pretty inexpensive these days and probably cost as much to diagnose and fix this one. You can purchase on-line as well. Good luck
Aug 27, 2007 | Proview PL713S 17" Flat Panel LCD Monitor
Proview PS 709 17 in.CRT Conventional Monitor Logo
44 people viewed this question
Top Proview Computer Monitors Experts
 Mike M
Mike M
Diego Zenizo
Diego Zenizo
Level 1 Expert
Are you a Proview Computer Monitor Expert? Answer questions, earn points and help others
