Question about Sharp VL-Z5 Mini DV Digital Camcorder
Sharp VL-Z5 as a WebCam
Hi and thanks for the support.
I have a Sharp VL-Z5 with firewire connectivity to my Windows XP Pro laptop.
Is there a way to make it function as a WebCam?
Read more >> Options >>
  • Sharp Master
  • 2,794 Answers
You can but it requires a capture program to do it. You can't use it for chat sessions or IM programs such as Windows Live. Pinnacle Studio will allow you to record to hard drive directly through the firewire cable.
Posted on Dec 23, 2008
How to change langeuage of Sharp VL-Z5 Mini DV Digital Camcorder
turn camera on, (on record side.) then press display button, go to menu, then select execute, press execute, that will bring you to settings 1 scroll down, the menu will get longer. you will find language selection there. .
Oct 17, 2011 | Sharp VL-Z5 Mini DV Digital Camcorder
I have put a new cassette in my VL-Z5 camcorder and the display says "eject the cassette". My problem is that the cassette will not eject when the cover is opened. Battery is fully charged and...
I have put a new cassette in my VL-Z5 camcorder and the display says "eject the cassette". My problem is that the cassette will not eject when the cover is opened. Battery is fully charged and I've also tried it with power supply connected?
Oct 04, 2011 | Sharp VL-Z5 Mini DV Digital Camcorder
I WANTS SHARP MIN DV VL-DC5 DRIVER
Hi there
Okay so I have carried out some research on the problem you are having.
The VL-DC5 does not have drivers online to download because the drivers in windows XP support this model camcorder
The problem is that you are probably trying to connect the device to your computer using USB.
The drivers in windows XP are only compatible with this camcorder when using Firewire cables.
If you don't have a firewire cable then you will need to buy one and use this to connect your camcorder to your pc.
It should work fine after you have tried this.
Let me know how you get on!
Mar 15, 2011 | Sharp Video Cameras
I cannot transfer video from my Sharp VL-NZ50 to my PC
I had the same problem with the VL-NZ50. It wasn't the camera, it was the IEEE 1394 interface on the laptop(s) -
I tried two different ones, one XP, the other W7 64; both were HPs with on-board (OHCI compliant) TI
IEEE-1394 chipsets.
Then I tried a Gateway desktop (Vista) with an on-board Ricoh
IEEE 1394 interface: the VL-NZ50 was recongnized instantly, controlled by the PC and transferring video flawlessly.
If you want it to work with your laptop , try an Adaptec PCMCIA card (I've heard they work with this camera), they can be had for under $10.
Jul 11, 2009 | Sharp Viewcam VL-NZ50U Mini DV Digital...
SHARP Viewcam z vl-Z500H-S Camcorder
To transfer video you need to use firewire, not usb. If you use firewire to connect, set the camera to the 'play' icon and then open up a capture program (ie, movie maker) you should be able to just record/capture from there. Good luck!
Jun 17, 2008 | Sharp VL-Z500H Mini DV Digital Camcorder
Help!! Can not connect my Sharp ViewCam Z VL-Z3U Through FireWire
Try searching these posts to see if they will help your problem. Seems this is common. See the link below.
http://www.fixya.com/tags/VL_Z3U
Mar 26, 2008 | Sharp Viewcam VL-Z3U Mini DV Digital...
Sharp VL-DC5
You should have the driver on the cdrom that came with the cam, as it may well be hidden within the software if you have'nt installed it. But if the problem continues, uninstal the current drivers in add/remove programmes and re install and add your cam to a different usb port than before, although i would of thought firewire connection would be more suitable for speedier transfers.
Jan 29, 2007 | Sharp Viewcam VL-NZ150U Mini DV Digital...
Sharp VL-Z5 Mini DV Digital Camcorder Logo
311 people viewed this question
Top Sharp Video Cameras Experts
Marvin
Marvin
abdul rauf
abdul rauf
Are you a Sharp Video Camera Expert? Answer questions, earn points and help others
