Question about Sony DCR-DVD605 DVD Camcorder
Sony DCR-DVD605 Power Issue
It appears when i try to charge the battery i get the following message:
Please insert a new adaptor and switches off
And when i use the power adaptor without the battery i get the following:
Battery Low
I have checked the battery using the Battery info button
it is charged up to 90%
What could it be?
SOURCE: DCR-PC1E
My camera say's the batteries are empty already after 2 minutes of recording. I de-charge the batteries with a 3R9 5W resistor and they gave 1 hour 1A equals 3000mAh so the batteries where fully charged. After emptying the batteries put them on the charger for ±5sec and then emptying them further with the resistor. Repeat this cycle until the batteries are realy empty. (the resistor don't get warm). Then fully charge them and do the de-charging cycle again. Repeat this a couple of times and you see that you can record 1 hour whith the batteries again. Succes and greeting louisgeenen@hotmail.com
Posted on May 29, 2007
SOURCE: what program do i use for editing please?
Premiere elements will work well. It's one of the better consumer programs out there because it has so many features and allows multiple file types imports and exports. It's a little complicated but I like it because it allows you to use a lot of formats and it give you all of the program features right away.
Pinnacle is also an option. It is not as complicated. It does not give you all of the features, but it is easier to use if you can get past the bugs.
Another option that I would not recommend is Movie Maker. It's free on your computer. However it can be very buggy. Simply plug your cam in and capture.It also has relatively few file export options.
Posted on Dec 09, 2007
  • 6 Answers
SOURCE: sony handycam
Hi, Just wanted to know how old your unit is. The original Sony batteries usually last a long time. I also had a similar problem, none of these batteries last 1000 charges. Batteries are cheap now . I just purchased a new battery for my old sony and it was $18 and it is a higher capacity. You can even find them combined with a new charge for about $35. You should also try to keep the new batteries charged . I fully charge them and then remove them from the recorder. If there is any drain on them and it is left uncharged for a long period you will kill the battery. I have a garage full of battery operated toys that worked fine when they were put away and now are shot. They should be stored just like they do at the store when you got them , disconnected and fully charged. Hope this helps
Posted on Sep 19, 2009
  • 21 Answers
SOURCE: error message on lcd screen :for infolithium battery only"
Problem connector,DC-IN part no.1-794-637-11
Posted on Sep 23, 2009
  • 49 Answers
SOURCE: my sony handycam dcr-sr32 wont charge got new
It could be a dodgy Charger, if it has a problem and not kicking out enough power, it will think that the battery has power equal to that of the charger, i.e. fully charged altho' it isnt, and cut off, making it appear to all be working. If its a mini USB type charger you could try a different one from something else they are all 5v, but some draw more current (mA).
Posted on Dec 26, 2009
My sony handycam DCR-TRV340E is not charging at all, dont know if its to do with the battery or the AC power adaptor
First, check that the camera switch is in the off (charging) position.
If this is OK, Check the battery output connections for voltage: use a multimeter.
To check the charger, put a load resistor across the output terminals (about 1000 ti 2000 ohms) and again, using a multimeter, check there is a charging voltage. Alternatively, if the camera operates OK with the charger attached and switched on the charger is OK, AND, the problem is then in the charging circuit from camera to battery. If the battery checks OK as in the beginning, then you will need a Sony repair man who needs to know all the results from your testing above.
May 27, 2014 | Sony Handycam DCR-TRV340E Digital...
Sony DCR-HC40E when turned on using battery (NP-FP50) power will display the following mesaage "Use InfoLithium Battery Pack" and then switch off.When on DC power it works fine. Also, when I...
It means the camera has detected that the battery is not genuine or not compatible. sony batteries has the data chip that provides the 'info' in infolithium.
check with the vendor who sold you the battery.
Sep 21, 2011 | Sony Handycam DCR-HC40E Mini DV Digital...
MY SONY CAMCORDER DCR-HC20 TOUCH SCREEN IS NOT WORKING
If the touch screen of the Camcorder is not working, please follow the troubleshooting steps.
Please make sure that you're using fully charged batteries.
Turn off the Camcorder and turn ON again and check the operation.
Try resetting the Camcorder by pressing the reset button behind the LCD panel.
Note: 8 represents the reset button on the above figure.
If the issue persists again, please perform LCD screen Calibration and check if that helps.
Please follow the steps below to perform the LCD Calibration
Perform a power resetting of the Camcorder. To perform power resetting, please remove the battery pack, turn the Power switch to Play/EDIT/ON for more than 15 seconds, turn the Power switch to OFF position and then reinsert the battery pack.
If the issue persists even after performing all the above-mentioned steps, service is required.
I hope this information will help you to resolve the touch screen issue of the Camcorder.
Jan 15, 2011 | Sony DCR-HC26 Mini DV Digital Camcorder
When I turn on my handycam sony DCR-HC 35,the touch-screen don't work!? What can I do about it?
Jan 05, 2011 | Sony DCR-HC35E Mini DV Digital Camcorder
My sony handycam DCR-SR200 's lcd touch srceen is not giving response whille touching.what to do
shajanrs_91.jpg If the issue persists again, please perform LCD screen Calibration and check if that helps.
If the issue persists, perform a power resetting of the Camcorder. To perform power resetting, please remove the battery pack, turn the Power switch to ON for more than 15 seconds, turn the Power switch to OFF position and then reinsert the battery pack.
Thanks for understanding.
Dec 31, 2010 | Sony Handycam DCR-SR200 Camcorder
Sony DCR-HC28E Camcorder tape won't eject
I\'ve got a Sony DCR-HC28E Camcorder power switch off position but it's turn on automatic when I put power AC adaptor in DC inlet and battery not charg
Dec 29, 2009 | Sony DCR-HC28E Camcorder
Sony handycam DCR-DVD205: use new ac adapter or reinsert
Remove the battery insert your AC adaptor turn on your DVD CAM if it work fine reinstall the battery set CAM to off position the amber light should be on to indicate battery is charging
You got that msg depend what function you use if the CAM calculated the battery not enough to run or finish this task it display that msg for you to use AC adaptor to ensure no power corrupted such in formating the disc
Some time system control is faulty even you use AC adaptor it still display this msg I hope that is not in your case
Let me kown how you go with this problem
Nov 30, 2008 | Sony Handycam DCR-DVD205 DVD Camcorder
Video Cameras Logo
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
