Question about Lenovo ThinkPad T61 Notebook
Wireless connection I havent had any problems with my wireless connection at all, and today I turn my computer on and its not picking up and wireless connection. the signal on the modem is great, and my sister can connect no problem. I dont know what to do, and how to go about fixing it. when i called the technical support they mentioned i might have turned off some button on my computer. the laptop is a lenovo, t61, ThinkPad. I tryed pressing the Fn-F9 and it didnt do anything, the wireless light is not lit on my laptop. please please help me. I dont know what to do, and I need internet for my project.
You may have a physical switch on your laptop.
The following says that it may be hard to find but have a look at the front left edge of the casing.
http://www.thinkwiki.org/wiki/Intel_PRO/Wireless_3945ABG_Mini-PCI_Express_Adapter
Posted on Jan 29, 2009
2 Suggested Answers
tborn6
  • 700 Answers
SOURCE: my wireless connection is not
yoiu can press the button again and when promted eturn turn back on the wireless radio . also there is the access connectipons that you can run and that will set it up for you
Posted on Dec 23, 2008
Cannot connect my dell laptop wirelessly, will connect with a wire and will connect wirelessly at the library. The old 2wire was ok but we replaced it with a new 2wire today. Have spent 3 hours with att...
Since you are able to connect using a hardwired connection and you're able to connect wirelessly at the library, that simply means that your computer and your internet browser are fine. where is your wireless computer and your wireless located? are there any possible wireless devices interfering with the wireless signal like chordless phones, cellphone, TVs, radios, microwave oven? are your walls in your house covered with metal plates coz that would really make the signal deteriorate. the settinngs on your wireless router may also need to be reconfigured and boost up the signal of the wireless router.if only i could remotely access your wireless router, I would really walk you thru on what to check on your wireless router
Jul 07, 2011 | 2wire (1000-000057-000) Modem
The signal is strong but there's no connection to internet
I have this problem sometimes. If you lose connection to the modem, you can't connect back to it, you have to reset the modem. Goto the modem, unplug it, wait 10 seconds, then plug it back in. Goto your connections, select yours, disconnect and then reconnect, wait a few seconds and it should connect. Hope this helps, let me know if it does or doesn't.
May 14, 2010 | NetGear WGR614 Wireless Router
Can connect the cable from the ISP modem directly to the PC and everything works. When the router is connected there is no connection to the ISP modem. Can you help me understand what I'm doing wrong?
Hi ppitcher, If you havent done anything to the router, meaning like you just bough it. Then, what you have to do is turn both the router and modem off. Then turn the router ON then after 30 seconds, turn the modem ON. And the router will get the IP from the modem automatically. Then you have to configure the router if you want to have it secure or change the name of the wireless connection, etc. I hope this helps. Please do not forget to rate and provide positive feedback for our fast - free support today. Thank you :D
May 01, 2010 | D-Link RangeBooster G WBR-2310 Wireless...
Router cannot find wireless network
1. check if you have cloned the MAC address in the either the Advanced or basic setup page.
2. After verification of the MAC clone restart the router
3. after router is restart then log in to the router >> go to status page and verify IP Adress.
If no ip address from cable modem then pwer cycle the cable modem >> then power cycle the router.
Apr 25, 2010 | Linksys Wireless-G WRT54G Router
Netgear software, picks up wireless network then loses connection moments later
Netgear generally functions well. You may simply need to adjust the location of the router. Check the signal strength when you do have a signal. You may be losing a signal intermittently because the signal is weak. If your signal is "good" or better and the signal is lost without apparent reason, there could be a malfunction with the router itself. Check the router when the signal is lost and ensure the power light is on and the connection light is on.
If your signal is weak and you lose it intermittently, adjust the location of the router
If your signal is strong and you lose it intermittently, you may be experiencing a connection problem at the source or the power may be cutting out at the modem. The more likely answer is the source signal interruption. It is rare for a power supply to go bad in those.
Check the source connection INTO the router.
You can also reset the router. You'll want to unplug everything. Unplug the power supply from the wall AND from the modem and leave it unplugged for at least 2 minutes. There may also be a very small recessed reset button (the kind that you need to use the end of a paperclip to press). Press and hold that for 10-30 seconds to reset while it's still plugged in.
When you plug everything back in, plug the power in first (to the wall and modem), then connect the source cable. Wait until you have a signal confirmation light, then try to connect with your computer.
Last but not least, the connection problem could be with your computer. Try pluging directly into the source if possible and see how that works. Then try just moving close to the wireless modem and see how the signal strength is and if you lose the signal the same way. If there is a switch on your computer to turn on the wireless feature, make sure it's all the way on. Sometimes these are kind of stuck between 'on' and 'off' and that can cause problems.
I hope one of these suggestions helps you!
Jan 12, 2010 | NetGear RangeMax WPN824 Wireless Router...
Wireless not working
Yes, There could be alot of things that are causing your Operating System to not obtain signal from your Wireless Router....I would first of all try troubleshooting this by;;
1st - Unplug your High-Speed Internet Modem and Wireless Router for 30 seconds apprx.
2nd - Restart your Computer.
3rd - Once your computer is logged in and at desktop, Plug-In your High-Speed Modem then wait until all lights appear that show your Modem is online then plug-in your Wireless Router then wait about 30 seconds then try to connect to your Wireless Connection.
If these do not work make sure that, you do not have your Wireless Router. I would also recommend that a way to create and obtain a signal strength that the computer can reach please go to the following website http://www.mythings.com/tips/1664/Where-to-Put-Your-Wireless-Router This should assist you with making a stronger signal strength.
Oct 25, 2008 | Computers & Internet
Wireless broadband connection dropping all the time
Hi
There are a number of things that can cause this. The most common as as follows.
1) Either your computer or wireless modem is being effected by mains interference. Make sure that all power cables are clear of your modem and computer, except those essential to run the units.
2) Your computer is picking up another local wireless modem signal on the same channel. Try changing channels.
3) Your modem drivers need updating. Visit the manufacturer's website and download the latest driver.
4) Your computer is too far away from your wireless modem.
There are numerous other reasons, but it is worth trying the obvious first. The most common of all is mains or power cable interference.
Oct 14, 2008 | Computers & Internet
Got wireless signal but no internet connection
You can try to power cycle your entire network (refresh).
This often happens when you have a large network.
  1. power down ALL Computers and disconnect the desktop from the D-Link Switch.
  2. turn off all SLAVE AP's first.
  3. Turn off the Master AP and disconnect one end of the Ethernet.
  4. Turn off the D-Link Switch and disconnect one end of the Ethernet.
  5. Now, turn off your modem.
Leave them for about 10 to 15 minutes, depending on your urgency.
Turn on and connect all devices in the EXACT order.
  1. Turn on the modem. wait 2 minutes.
  2. Turn on the D-Link Switch and wait 1 minute. Then connect the Ethernet to the MODEM.
  3. Turn on the Master AP and wait 1 minute. Then connect the Ethernet to the D-Link Switch.
  4. Turn ONE of the Slave AP's. Turn on your Laptop. try to connect to the Internet. If successful, Disconnect from the network on the computer and proceed to turn on the rest of the Slave AP's, Laptops, and Desktop. If its NOT successful, power on the Desktop and try to connect to the internet.
  • If the desktop connects to the Internet, Check your D-Link's homepage "192.168.1.1" (default) for any wrong settings. If it does not connect, check your DSL Modem's settings.
If the above does not work, post what you did the day before this happened. Probably something small might have messed with the network.
Aug 15, 2008 | D-Link AirPlus DI-524 Wireless Router
NOT WORKING AFTER POWER OUTAGE.
are u getting all the lights on the router?if yes then connect the router with modem n if its wireless then turn off all three devices
then turn modem on first n wait till the lights on the modem get settelled,then turn the router back on n the computer,n check whether the computer is picking the wireless or not,if yes try the
internet.
Apr 20, 2008 | D-Link DI 514 Wireless Router (DI-514)
Networking
You actually have a couple of issues here. Fix these in this order. 1.) Login to router and turn off wireless (if you're not wanting to use wireless) 2.) Connect the ADSL modem CAT5 port to the WAN port of the Belkin router. 3.) Login to router and turn on NAT and make sure DHCP is enabled. 4.) On your Windows machine turn on DHCP under the network settings. This should allow your connection to be setup automatically and stop wireless access on the Belkin router. Let me know if you need more help. JC
Jun 24, 2006 | Belkin Wireless (F5D7130) 802.11g/b...
Lenovo ThinkPad T61 Notebook Logo
380 people viewed this question
Top Lenovo Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
