Question about KitchenAid KAWS850LE Top Load Washer
Our KitchenAid KAWS850LE1 Washing machine will not drain or spin
The cycle went through the wash and rinse and now the machine is full of water and will not continue to drain or spin.
  • Tinkerbell40 May 23, 2009
    My washer is about 3 years old, i live alone and maybe only use it 2 times a week or less. this morning i put in my wash and it works all the way to draining the water off which it does not do. i took most of the water out by hand and it still not not drain or spin, it feels like the switch is not clicking like it used to, so does anyone know if its the switch or the pump. i would be greatful for any help as i am a lady on my own and need it fixed for as little as possible and if i can do it i will:
    Greatful
  • 179 Answers
You need to replace the lid switch
Posted on Dec 23, 2008
Kenmore Series 70 Top Load Washer Direct Drive Model # 110.20722991 Serial# CL 1134809 Wet Clothes after Spin Cycle
many machine spin a full tub as they are pumping the water out
this helps to even out the washing load and reduce the unbalance situation
when the water is removed , the machine progresses the program to a high speed spin
call a technician as there may be a problem in the program board
Jun 11, 2016 | Kenmore Washing Machines
Oko 72630. Why is it stuck on rinse cycle?
Could be several reasons:
- Selected the "Night cycle" program (means standing with the drum full of water, reason: too much noise in the spin cycle)
- Set to the "Rinse hold" (means standing with the drum full of water, reason: wrinkles on the clothes)
According to your description I think that this is not a failure otherwise error E20 will be appears on display.
Once the washing programme has come to an end, END illuminates on the programme progress display.
If RINSE HOLD was selected, the display beside the START/ PAUSE button flashes.
1. After a rinse hold, the water must first be pumped out:
- Either press the START/PAUSE button (the water is pumped out and the washing is spun according to the completed programme;
After the START/PAUSE button is pressed again, the spin speed can still also be changed during spinning), or
- Turn the programme selector to PUMP OUT and press the START/PAUSE button (the water is pumped out without spinning),or
- Turn the programme selector to SPIN or SHORT SPIN and press theSTART/PAUSE button (the water is pumped out and the washing is spun or gently spun).
At the end of this programme step, the END indicator will illuminate.
2. Open the door.
As soon as the DOOR indicator lights up green, the door can be opened.
Dado
Aug 15, 2015 | AEG Washing Machines
Please describe a typical washing cycle to me on the RTW4440XQ Roper 3.1 Cu. Ft. Top-Load Washer, please.
The typical cycle is;
fills to selected water level
agitates wash cycle
drains wash water
spins wash cycle
fills to selected water level on rinse cycle
agitates on rinse cycle
drains rinse water
spins final time
end of cycle
Aug 08, 2011 | Roper Washing Machines
My kitchenaid wash machine won't drain
most od the time it is a bad lid switch-mike
Jan 23, 2010 | Washing Machines
Washing machine won't rinse, drain or spin
COULD BE THE PUMP MOTOR GONE BUT FIRST CHECK THE FLUF FILTER IF FITTED
Dec 30, 2009 | Washing Machines
Washing Machine is not draining in rinse cycle to go to spin cycl
you both seem to have bad lid switches. A bad lid switch will prevent draining and spinning.
Mar 18, 2009 | Kenmore 24032\24036 Top Load Washer
My Kitchenaid washer stops on the rinse cycle...
Do you have an age of the machine and model number? Is there a "spin only" cycle? On older machines, there was a center knob you could slowly rotate, one click at a time, to advance it through its cycle. Can you do that? If the unit is agitating, I don't believe the belt is your issue. Age and model please.
Jul 31, 2017 | KitchenAid KAWS750L Top Load Washer
Bosch classixx 1000 washing machine - stops on spin
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
Apr 29, 2008 | Bosch Classixx WVF 240S Front Load Washer...
KitchenAid KAWS850LE Top Load Washer Logo
1,164 people viewed this question
Top KitchenAid Washing Machines Experts
kj henriksen
kj henriksen
gbob59
Mike
Are you a KitchenAid Washing Machine Expert? Answer questions, earn points and help others
