Question about Mitsubishi VS-60609 60" Rear Projection Television
Program vs-60609 for cable
I need to program my vs-60609 for cable but do not have manual. stations 2 thru 13 are o.k. but station 14 and on are just a fuzzy mess.
thanks in advance
  • Shahid Electronics
    Shahid Electronics May 11, 2010
    Download required user manual form RETREVO, just click manual, sign in / register and download will start, it is free.
    If it help you out, let me know.
    Scholar:
  • 141 Answers
No need to register on this link :http://safemanuals.com/annexe_Owners%20Guide_MITSUBISHI_VS-60609-_E.htm
cheers
Posted on Dec 23, 2008
What does RF CH mean?
What is the difference between a RF channel and a virtual channel? The RF channel is the channel that the TV station uses to broadcast its signal. Before the conversion to digital, TV stations were normally identified by their channel number, and most people knew that a particular network was on a specific TV channel. While analog broadcasting was being phased out and all TV stations were converting to digital broadcasting, it was necessary for the TV stations to continue to broadcast their analog signals on their original RF channels, and also broadcast their digital signals on a different RF channel. However, since the TV station used their broadcast channel as part of their identification, they wanted to keep using the same channel number. To allow this to happen, the new digital television broadcasting standards (ATSC) provided TV stations the ability to continue to use their original channel number and also tell the TV set to tune to the new RF broadcast channel when their virtual channel number was selected. The original channel number is called the virtual channel number, and it will be followed by a period and a second number (3.1, 7.1, etc.).
One of the benefits of converting to digital for the TV stations is that they now have the ability to transmit more than one program at the same time on the same RF channel. The number of additional channels they can broadcast is determined by the resolution of the program (SD vs. HD, text only, music only, etc.). The second number in their virtual channel number indicates that one of the additional programming sources from the same TV station is being viewed (10.2, 10.3, 10.4, etc.).
When selecting an antenna, it is important to understand the difference between the RF broadcast channel and the virtual channel. Antennas are designed to receive specific ranges of RF channels, and the antenna needs to be selected for the RF channel you wish to receive. TV stations broadcast in two broad frequency ranges, called VHF and UHF. RF channels 2 through 13 are considered VHF, and RF channels 14 through 51 are considered UHF. In order to pick up the channels, the antenna has to be designed for the correct frequency range. It is very common today to find that TV stations using virtual channels 2 through 13 are actually using RF broadcast channels in the UHF range. Although not as common, some TV stations using virtual channels 14 through 51 are actually transmitting in the VHF range. An antenna designed for only UHF channels will not work effectively for RF broadcast channels in the VHF range, and an antenna designed for only VHF channels will not work effectively for RF broadcast channels in the UHF range.
Apr 09, 2015 | Televison & Video
Can only pick up chanel from 2 thru 13,do i need a box converter all other tv get 98 stations
A converter box will allow you to get all the channels but if you are only getting 2-13 now go into the customer menu and I think you will find the set is in the AIR band and not the CATV band.
With the remote you should be able to move it into the CATV or cable mode and then if needed find and select auto program.
The fact you are only getting 2-13 means it is not in the CATV or cable mode.
If this helped you rate this solution as I do this here for Free.
SD TECH
Dec 07, 2009 | Pioneer SD-P6093K 62 in. Rear Projection...
Manual for mitsubishi vs 5043 cannot program for
If you go into the main menue with the Mitsubishi remote, there should be a set up icon for programing stations. It should give you a selection for cable and or standard tuning. Select cable then press auto program.
Hope this got it done,
Skyassoc
Jun 19, 2009 | Mitsubishi VS-5043 50" Rear Projection...
All of my stations available to me will not program into my vcr
You need to go into the menu and where it says cable or air switch it to cable and you will get all of your channels,Have a great day...
Apr 02, 2009 | Televison & Video
Jvc av-20cm5 channel programming issue
you have a programing error in the main control ic it ca be repaired but its $$$$$$ my guess is 150.00 -200.00 the control ic has a modified control memory the memory is held in place by a charged capacator if you unplug it and leave it for a week and plug it back in it might be ok for a while if not try unplug it for a month . that might be enough for a reset but the problem will keep comeing back the chip is damaged
Apr 01, 2009 | JVC Televison & Video
Can not hear the telephone ring on one of the main phones upstair
You will need to know which line(s), and on which station(s) (extensions) you want each line to ring.
Programming is accomplished as follows:
Default Installer Password = INTERCOM *746
You can enable different ringing assignments for individual lines and stations.
You must program ringing assignments on a per station/per line basis. You can control ringing for every line that has appearance at a station assigning immediate, or direct, ringing to some lines and delayed ringing to others. NOTE: Do not program direct ringing for lines that you assign to the direct department calling feature.
To Program: 1. Dial 54. “STA/LINE CONFIG.”
2. Dial 1 “DIRECT RING”
—OR—
Dial 2. “DELAY RING”
NOTE: For no station ringing, skip step 3 and make no line selection.
3. Select line ports for ringing (LED On = Selected Ports).
—Line port 1–14 = Dial 01–14 or press A1–A14
—Line port 15, 16 = Dial 15, 16 or press B1, B2
—Line port 17–24 = Dial 17–24 or press HOLD then press A1–A8.
4. Dial # when all line ports are selected.
5. Select station ports (LED On = Feature Assigned)
—Station 10–57: Dial 10–57 or press C10–C57.
6. Dial * when all station ports are selected
—OR—
dial ** for next station/line ringing assignment
—OR—
dial ***for configuration mode.
To clear current setting, repeat procedure.
Use an LCD speakerphone and a DSS/BLF console at station port 11 or 13 to see which features are assigned to individual stations. While you can install any non-LCD digital telephone and use it for programming, visual feedback of the programming operations will not be available. You must always keep the handset of the LCD speakerphone on-hook while you use this telephone to program the system.
Mar 26, 2009 | Comdial Impact 8024S Corded Phone
Only getting some channels to come in...
Check your latest phone bill and see if you have a basic extended package. If you dont you may have been downgraded to only get basic cable which is 2-13.
The auto program adds every channel that the television can detect.
Jan 04, 2009 | Sanyo DS25390 TV
Lost Station
table top box from rca,to get the channels
Nov 05, 2007 | RCA F38310 38" TV
Channels blocked
Hello to all, go to your TV menu and go to V-chip set up, then go thru and see that you don't have any channels blocked. If you do and you are watching a show with that rating, you will receive the "protected program message".
Have a great day!
Oct 21, 2007 | Emerson EWC1304 13 in. TV/VCR Combo
Mitsubishi VS-60609 60" Rear Projection Television Logo
81 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
