Question about Janome Sewing Machines
Broken center shaft on tension assembly
If I can just get the center shaft great, if not then the whole assembly
  • 323 Answers
BUy the complete assembly. It's faster,easier and it's pre assembled. Should cost about $15
sewman7
Posted on Dec 23, 2008
How to replace the tension knob on baby lock blind hemmer
If you have all of the parts your in good shape. Otherwise you'll need to order the whole assembly.
Is the whole assembly loose from the machine or is it in pieces?
Sal the Sewing Gal
Apr 13, 2016 | Baby Lock Sewing Machines
Parts Diagram For Needle Shaft.
send ur exact model and brand name ..will get ur schematic diagram soon
Sep 20, 2008 | New Home L-373 Mechanical Sewing Machine
When winding the bobbin thread slipped off tension disk and wound around the bobbin shaft. When I removed the thread the bobbin will not fill with thread.
Well, you COULD get this fixed -- or you could purchase an inexpensive bobbin winder and skip the whole issue. Does a better job, too.
Oct 30, 2015 | Singer 7258 Sewing Machine
How to set the tension
The carrier and bobbin are removed. Place the thread in the carrier with the thread dispensing counterclockwise. Place the thread between the metal pieces (tension). let the carrier hang from your finger and bob it slightly. It should extend one inch. If it doesn't then you can adjust it by turning the small screw slightly until it does what I said. Now, replace this assembly. The top tension you can start at three. The sewing should be an even pull between the upper and lower thread. If the thread knot is in the center of the material it is right. If the knot is under the material then raise the upper tension. If the knot is on the upper material then you should lower the upper tension. The key is to start with the bobbin tension correct and adjust the upper tension until the knot is in the center of the fabric
Oct 26, 2014 | Sewing Machines
What can I do to wind my bobbin tighter
Make certain you are passing the thread through the tension for the bobbin winder when setting up to wind the bobbin. Check that tension assembly for anything that could be stuck in it, preventing the assembly from putting tension on your thread, such as another thread. Wiggle the disc on the assembly to make sure it isn't stuck. If none of that works, disassemble that assembly from the top of the machine (NOT the tension you use when threading to sew!) and see if the spring inside is broken. If it is, replace the spring if you can get it, or the whole assembly if you cannot.
Apr 28, 2012 | Brother LS-2125 Mechanical Sewing Machine
I have a singer sewing machine 413. The tension setter on it has broken and I have a new one to put on but I can't figure out how to get the broken one off?????
Open the faceplate and you will see a screw inset into the body of the machine where the tension unit is, unscrew it and the whole unit comes out.
Sep 12, 2009 | Singer Sewing Machines
Part for sewing machine
any one have a power cord/manuel for a Janome 2049 Harmony Sewing Machine?
Jun 06, 2008 | Sewing Machines
Elna 2002 Sewing Machine
Can't get a manual for you but here's how to wind a bobbin.
Guide your thread from the spool holder to the bobbin thread tension device on the top left side of the machine.(That's the round assembly that is about 1/2 inch in diameter with a screw in the center of it.) Pull the thread in the front and wrap it to the back and continue towards the bobbin winder on the right side top. Wrap thread around the bobbin, place the bobbin on the spindle sticking up. Release the handwheel(either by pulling out on the center of the wheel or twisting on the center of the wheel). Press on the foot control. It should stop winding when it is full.
To thread the machine
all machines thread the same. TTN tension, take up, needle.
Beginning with the spool, guide the thread through the thread guides to the tension assembly. Pull the thread through the tension assembly and test it to make sure the tension is working correctly.
(To do this test, adjust your tension setting to normal or medium or 5 or something in the middle. Raise the presser foot and pull the thread through the tension. It should pull easily!! Lower the presser foot and pull the thread. It should pull noticeably harder.) If it passes this test, continue up through the take up lever,then down through the thread guides to the needle. Make sure your needle is fully inserted and turned the correct way. Flat side to the back and it threads front to back
Sewman7
Jun 02, 2008 | Elna 2007 Mechanical Sewing Machine
Singer 404 sewing machine
I would first make sure the thread tension is adjusted properly. if this does not fix your issue, check the point on the shuttle hook and make sure it is not broken off. it should come to a needle sharp point. if the tip is broken off it may not pick up the thread from the needle properly. then double check the timing and the needle shaft depth. first, make sure your needle is fully seated and tightened down. the groove in the needle should face forward. there are two timing marks on the needle shaft. at maximum depth you should see both lines and the top line should be right at the bottom of the needle shaft bushing. then as the shaft goes back up, when the bottom line is at the bottom of the bushing the point of the shuttle hook should be right behind the needle and centered in the indentation on the back of the needle. you may need to make minor adjustments on the needle shaft depth depending on what brand and type of needles you are using.
Mar 18, 2008 | Janome 4623 Mechanical Sewing Machine
Sewing Machines Logo
54 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Eva Hack
Level 1 Expert
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
