Question about Nikon N65 35mm SLR Camera
Premature Film Rewinding
My N65 won't allow me to shoot an entire roll of film. I'll load a brand new roll into the camera, then I'll shoot anywhere between 3 and 7 exposures, then all of a sudden the camera rewinds the film as if I'm at the end of my roll. Typically, I use 24-exposure film. Someone suggested simply replacing the batteries with new ones, but the problem persisted after I took THAT advice. I've asked around a couple places, but no one else seems to have any potential solutions. Please help!!!
    Problem Solver:
  • 30 Answers
If you are using dx coded film,and still the problem persist,the problem is inside advance mechanism,either it is sticky (moisture)or some gear problem,if you're not qualified to do so,pls have it check by service center.
Posted on Jun 25, 2007
  • 68 Answers
The only thing that I could think of when I read your situation is, that you might not be using a DX coated films. see, the camera reads the bar code on the film and maybe it is not the same program. check the camear manual and make sure you are using the same kind of the suggested film in the manual. good luck
Posted on Apr 13, 2007
SOURCE:
My 35mm film won't load. It keeps rewinding
Solution: Repair or replace auto-rewind system.
Cause: The built in auto-rewind system that supposed to work when film is finished but because it is faulty it receives wrong signal when film is lloaded. So the camera thinks the film is at the end of the roll.
Possible cost: $65-$75
Oct 26, 2012 | Photography
What does the blinking E in the Nikon n65 mean?
It means "Film remains in the camera after film rewind complete."
If this is happening after shooting, the remedy is simple: open the camera and remove the film. If this is happening right after loading the film, then you've got a more serious problem: the camera is rewinding the film upon loading.
Mar 03, 2010 | Nikon Photography
When film loaded it is not rolling on properly
film not advancing? film not rewinding? film transport motor dead/ needs replaced.
Rewinding but counter not resetting and light meter dead? Prolly bad connector or ic inside camera = repair shop.
Oct 16, 2009 | Photography
Why is the film automatically rewinding around 15 shots instead of the end of the 24 shot roll? The batteries are fresh.
the roll sensor is not reading the silver code on the film roll.
Open the camera when you have no film in it.
Clean the film roll slot where the "fingers" are.
These fingers touch the case of the film roll to determine the film type, which includes the number of exposures. You nmay have to "adjust" the fingers so that they make good contact with the film roll case.
Look at different rolls of film, notice the silver blocks are different. If the roll has a "dent" on it, it can't be sensed correctly.
Hope this helps!
Sep 15, 2009 | Canon Sure Shot Classic 120 35mm Point and...
2 rolls out of a 3-pack ruined.
I would suggest you buy an off-brand roll of 12 or 24 exposures. Run it through the camera taking snaps of anything -- but make sure you vary the lighting, ISO, shutter speed, aperture, etc. as you snap the pics. Don't worry too much about composition. This roll is a quick test, NOT for photos to keep.
Have the film developed and then follow-up with comments on the results. I'll gladly assist you further at that time.
Char1ieJ
Nov 11, 2008 | Nikon N65 35mm SLR Camera
Fuji 35mm Camera (Model DL-400)
Dawn
remove the battery and check that it is good. replace battery and open back door, close the door and it should run the motor / transport. if so, load film up to the drive sprocket being sure film will catch on the sprocket.
or move the latch holding back cover, and open the door fully. check the pressure plate on the door, gently pull the plate up a little to increase pressure on the film. bring the holding lever out toward the latch and close the door to lock the lever back to position.
Jun 11, 2008 | Fuji Discovery 185 Zoom 35mm Point and...
Film advance lever and shutter release button are "stuck"
No, it is not the battery. My guess is that the film leader did not stay in the take-up spool and is now bunched up around it. Try rewinding the film carefully as you normally would but remember that you are only rewinding a small portion of the length. You can even just open the film door and start over. You will only loose 3 or 4 frames on the roll.
Apr 27, 2008 | Nikon FE 35mm SLR Camera
Film loading
Rewinding button or option may be in action
Oct 27, 2007 | Canon EOS Rebel G 35mm SLR Camera
Rewind Problem
Wait till night. Go to a room. Draw all the curtains and switch off all lights. Now you have a dark room. Make sure you can't even see your own fingers! Pop the camera film cover. Pull out the film and rewind manually.
May 03, 2007 | Nikon N65 35mm SLR Camera
Nikon N65 35mm SLR Camera Logo
119 people viewed this question
Top Nikon Photography Experts
Ric Donato
pictureman4u
Jay Plesset
Are you a Nikon Photography Expert? Answer questions, earn points and help others
