SOURCE: ASUS EEE PC 4G Password recovery!
its all technician consultation and for me remove the CR2032 battery inside the laptop to reset the biois inside... or press F8 to go safe mode and remove the previous password to enter at administrator...
SOURCE: forgotten password
try pressing ESC 2 or 3 times to bypass this option. Then go to your user account settings and change or delete your password. If all else fails, format HD or burn a bootable windows password recovery program and boot up pc with the disc.
SOURCE: UPDATES for Asus Eee PC Series 2G Surf
Hi i'm Rain.
Ok i need to know is that the Red hat based Linux or Or is that more compatible to the Father OS Unix.
I Have a list of commands everything from changing a User names thru Linux to By passing the XP Adminastrator passwaord .
Xandros is just a Updated Of Red Hat if i'm correct and im sure i am .
Make sure you have full administrator rights!!
Next you will need to type . Sudo usermod -g admin user
I assume you do have Sudo Access . The command will give you rights . But still like i said i need the other information.
SOURCE: Asus Eee PC 2G Surf netbook fails to boot into OS
Unfortunately Xandros is a paid (yes, you have read correctly , PAID) Linux distro. You will have to pay to get a Live-USB to reinstall.
Instead you should go here
http://www.pclinuxos.com/forum/index.php/topic,46097.0.html
and follow the instructions to create your own PCLinuxOS (the one i use) Live-USB. You will need another pc for that. After booting from it all you're gonna have to do is to click on the Install icon on the desktop.
SOURCE: how to reset asus eee pc 4g surf to factory
Run the recovery software in the programs menu and fallow the prompts.
