Question about Westinghouse WST3501 Microwave Oven
How to replace bulb in #3501 Westinghouse Microwave
  • Westinghouse Master
  • 9,100 Answers
If there's no obvious removable cover over the bulb (most often on the rear or side) and the owner's manual doesn't address it, then disassembly will be required.
Always unplug a microwave before removing or installing any bulbs.
If it's an over the range type, remove the vent grille across the top and see if bulbs can be accessed there. There may be a panel on the bottom covering the light(s), instead.
If not, chances are you'll have to remove it from the wall, then remove the outer cover. If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
Once it's out of the wall, the outer cover (wrapper) will need to be removed, just as you'll need to do on a counter top model.
On a counter top model, be sure it's unplugged, but otherwise ignore the instructions above this paragraph.
The screws you need to remove should be pretty obvious, but a special driver (such as a T20H type or GTXH20-100) may be needed.
Be sure to put all the screws back in the right holes, since some may be special grounding screws.
Bulbs can be had in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Many models use halogen lamps. You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
Posted on Dec 25, 2008
Wst 3501 set clock
read your instr. manual and proceed according download you manual www.retrevo.com
God bless you
Aug 03, 2012 | Westinghouse WST3501 Microwave Oven
Westinghouse microwave 3501
May I know the specific problem?
Hope to hear from you soon!
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
Oct 12, 2010 | Westinghouse WST3504 Microwave Oven
Fuse replacement
inside the outer cover,you need to remove outer skin its on top
Jul 15, 2009 | Westinghouse Microwave Ovens
How to change lightbulbs and how to get bottom off for cleaning
Please unplug your oven before you remove or install bulbs!
The bulbs are often tacked in place with contact cement or hot glue,and sometimes there may have been enough moisture to corrode and seize up.
You could heat them up with a hair dryer to loosen the glue.
That usually works.
You can find helpful exploded view diagrams (and order parts if needed) by entering your full model number here.
These views will help you see how the oven comes apart.
Dec 22, 2008 | Microwave Ovens
I have a Westinghouse WST 3501 Microwave
In this case you need to replace complit asseble door on microwave.
I’m happy to help further over the phone at https://www.6ya.com/expert/vitaliy_f406165329c75ede
Dec 15, 2008 | Westinghouse WST3501 Microwave Oven
Locked with the word CHIL on the display
Press the Stop/Clear button several times in a row. This should clear the error.
Nov 29, 2008 | Westinghouse WST3501 Microwave Oven
Westinghouse microwave WST3502..... Problem:
Press "Clock", type in the time on the keypad and then press "Start". The clock runs a little slow (at least on mine) and I have to reset it about once a month. It gets about 10 - 15 minutes behind after awhile.
Sep 06, 2008 | Westinghouse WST3501 Microwave Oven
Light bulb
If you are comfortable with taking the cover off, Unplug the microwave, usually there are 2 philips screws on the top back, 2 on the right back and 2 on the left back edge cover. Sometimes, their might be a screw on the bottom but you will notice this right away if there are or not if the cover doesnt come off.
Then located the light bulb. You should be able to see the opening from inside the microwave where the light bulb is located.
Once you locate the bulb, then there are usually 2 types, type 1 screws in and the other type is a bayonet type, which you push down, and then twist. You should be able to figure this out.
Sometimes there is a plastic cover that is placed around the bulb to kinda help focus the light towards the inside of the microwave.
Once the bulb is out, then take it to your local hardware store and see if they can match it up. You might want to call first to see if they carry them before driving all over the place.
Hope this helps.
Good luck.
If i have helped you with you question, then please remember to post a feedback and a rating.
Thanks.
Mac
Feb 19, 2008 | Westinghouse WST3504 Microwave Oven
Microwave's Power goes off after 3 minutes running..
If the time from START to shut off were EXACTLY 3 minutes, then I would suspect a sensor problem or corrupted code in the microprocesor. But since that time sounds more random, it sounds heat-related, and I would suspect a failing magnetron or a failure in the cooling system. If the cooling fan is not running while the oven is cooking, this failure can occur, and can destroy the magnetron in short order. A cracked magnet (has the oven been dropped?) or other problem can cause a magnetron to go bad and overheat. If it's under warranty, I would definitely contact the manufacturer (see your manual) to find an authorized local servicer. If it's out of warranty, I would balance the cost of a new microwave versus a bench diagnosis fee of $25 or more or an in-shop repair cost of maybe $80 or more.
Oct 15, 2006 | Westinghouse WST3504 Microwave Oven
Microwave Ovens Logo
497 people viewed this question
Top Westinghouse Microwave Ovens Experts
William Miller
William Miller
Jaime Hernandez
Vitaliy Gins
Vitaliy Gins
Are you a Westinghouse Microwave Oven Expert? Answer questions, earn points and help others
