Question about Gateway M305CRV Notebook
Screen on laptop ...no signs of life
Power lights come on the battery charging light is on when plugged in, the fan turns on but the screen does not come up. Might I have voltage issues?The laptop screen is black yet I know the system is booting. Pluged in ext monitor with no success. Could the graphics chip be bad? Is there a button stuck?
  • Mark Robinson May 11, 2010
    try taking out the battery and booting from mains only...what happens ?
    Scholar:
  • 53 Answers
Yes the graphics chip is bad its also made in to the motherboard we repair these every day the mother board are listed on ebay you can buy a whole working bottom for less then 70 bucks this is one of the few problem this model laptop seams to have.they are dependable normally. i have tons of parts for these laptops.
Posted on Feb 20, 2009
Powered but not booting. No visual. HDD light not doing anything.
Remove the RAM and start, see if it beeps and/or shows something on the screen. Try with the external screen too.
Let me know how it goes
Cheers
Jun 27, 2013 | eMachines Acer 350-21g16i Netbook
Laptop will not power up
Take the battery out, plug in the charger and see if the laptop works. If it works, the battery may be the problem. Check the AC Adapter
Check to make sure the adapter is plugged securely into the wall outlet, connected firmly to the adapter box and to the back of your laptop. Most AC adapters have a little light in them on that rectangular box in the middle of the cord that lights up when it's getting electricity. If that light isn't on, try a different outlet. Check your fuse or circuit breaker box and plug a different device into that outlet to make sure there is power to it. If it still does not light up, your adapter could need replacing. Also check the adapter box for signs of warmth, as it will generate heat when it's plugged in. No heat means no power.
Remove the Battery Sometimes it's as simple as a seated battery. Remove the battery entirely and clean out any dust, lint or hair that may be clogging the connectors and preventing a proper connection. Reseat the battery securely and make sure the little locking pins that hold your battery in place are securely fastened and there is no movement. Unplug your laptop while it is running. If it still works, the battery has been charging. If it shuts off, or doesn't hold a charge very long, you have a bad battery. Unplug your laptop while it is off, then try to turn it on. If the battery is bad, your laptop probably won't turn on at all. Turn off your laptop's screen-saver when testing its battery. The screen-saver will conserve the battery and not give a clear time frame for how long your battery can really last. Click the battery icon on your laptop when it is unplugged. It can tell you how much battery life you have available. This icon is usually located in the bottom right corner of your screen and will provide the percentage of battery power you have left. Keep track of the time it takes to go from 100% charged to 1% charged. If this takes less than an hour, your battery is probably beginning to fail. You can also try this every week or two to see if your battery holds a charge for shorter periods. Factor in the amount of time you have used your laptop. Most laptop batteries last 2 to 3 years or about 500 charges. Wait a few days before determining whether a new laptop battery is faulty. New batteries sometimes take a few charges to build up to their maximum run time.
Feb 10, 2013 | Toshiba Satellite Computers & Internet
Computer will not start up.
One thing that might be worth trying that I have seen work on several occasions is to disconnect the power, then remove the laptop battery, reconnect the power lead and try operating the laptop with no battery.
If this does work, then the laptop battery has probably failed and made a short-circuit internally which would be why it will no longer charge and why the laptop will not power on as a safety precaution.
Dec 22, 2011 | Dell Inspiron 6000 Notebook
E system 1212 Laptop won't switch on. Power
Laptops are so integrated that usually a system failure that involves power issues such as in your case where you cant get it turn on with anything on the screen mean the mainboard (motherboard) is damaged. This usually leads to buying a new laptop or paying for the board to be replaced which usually costs as much as the laptop.
May 12, 2011 | Computers & Internet
I was using it and turned it off and i came and turn it on and hp logo didnt appear on the screen it was only the lights and blank background please help me.is my sisters laptop and i took it without...
well. be sure the power is plugged in
then pull the battery out of the laptop
press the power button down
look at the little lights indicating power on .. battery charging and hard drive activity
if the power light comes on..
then the screen is the problem
if the hard drive comes on after say 10 seconds
it is definitely the screen
put the battery back in.. be sure it is in solid
put the power pack in the wall
if the battery charge light comes on
then the power is to the laptop and battery connections are good
so the laptop may have overheated...
wait five minutes
try to power it on again
if the fan does not power on...
it has a bad fan...
quietly set it where ya got it from then
Jan 21, 2011 | HP G60-235DX Notebook
Wont come on!
Starting with the easy stuff: Try plugging in the power cord, but not the battery.
If that works, your battery is either dead, or the circuit for it is shorted out.
Are there any signs of life? When you press the power button, do you hear any fans? do see any lights?
Does the screen flicker? Your RAM may be dead if it does.
Oct 05, 2008 | Acer Aspire 5315 Notebook
Laptop crashes shortly after boot, power light rapidly blinks red.
Its late, so just to make sure I'm not brain-dead basically your laptop runs fine as long as its powered by the AC adaptor but dies fairly quickly while running via battery. This is very typical of a battery that will no longer hold a charge, not normally a user repairable item. It could also be that the charging electronics (in the laptop) isn't charging the battery, again not a typical user repair job. About your only option short of taking it to the repair shop is buying or borrowing a battery as a test.
Dec 12, 2006 | Medion (40010998)
Gateway M305CRV Notebook Logo
286 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
