Error code sc 552 on Ricoh CL7100
Getting an error code of sc552 on my Ricoh CL7100. They want $180 to come out and put the reset code in to get rid of it. Anybody know the reset code for this.
Thanks !
  • jpappada Dec 29, 2008
    I have the same error on my ricoh cl7100. I have heard that the fuser unit may need replaced any word on that?
  • cavedog Mar 11, 2009
    I have a 'Replace Fuser Unit (Type C) error on my CL7200. Got a reset for it?
To clear any code on a Ricoh / Savin copier that will no reset by turning the power off / on you need to first enter the service program mode. This is a safety feature installed when repeated resets of some codes could cause damage to the machine or possible fire hazard. Most of the time these codes deal with the fusing unit. The fusing units operate at around 180 degrees celcius. Thats pretty near the point where paper catches fire so you see the need for safety there. Anyway, you can sometimes get a false fuser code if the room is cold in the morning when you first power up the copier and the machine takes longer than normal to reach operating temp. Another reason can be that maybe you didn't push the fuser back in good enough after clearing a jam and the electrical contacts did not make good contact. In these instances you can clear the code and go back to copying. Should the code come back after doing one of these resets then it means there is a bigger problem with your fuser and you need to call for a service visit to have the problem fixed.
Here is the reset for it:
1. Press the Clear Modes (yellow on most machines)
2. Press the numbers 1,0,7
3. Press and hold the Clear / Stop (red on most machines)
after a few seconds on machines with an LCD display screen you should see the screen change to display "SP mode" with a few selections. On older or smaller machines without an LDC display screen you should see a flashing "0" on the panel. This lets the machine know its ok to reset the code. Do not make any selections in this mode. SP mode if for making electrical adjustments to the copier and taking the machine out of spec can cause a lot of problems for you. Once you enter the SP mode you just need to turn the machine off / on. (make sure you do so with the main switch that you have to rock back and forth and not the button that just gets pressed to shut down the machine, the main rocker switch is often located on the front door or on the left side of the machine, sometimes covered by a swinging cover you have to lift first)
If you do not hit the keys in the right order, the machine will not go into SP mode. You can just start over with step one untill you get into SP mode.
After doing this and the code resets but then comes back again or gives you another code, you'll have to place that service call. If not then happy copying to you.
Posted on Jan 14, 2009
  • Gary Kenney
    Gary Kenney Feb 03, 2015
    Paper catches fire at 451 Fahrenheit (233 Celcius)
  • Abass Afis
    Abass Afis Nov 25, 2015
    helpful for LANIER LD115 RICOH
  • 3 Answers
This also works for lanier 450 printers.
Thanks exok
Posted on Aug 05, 2010
  • Tech Hughes Sep 15, 2010
    Should this work the same with a Ricoh AFicio MP7500 got same prob. Tried this but didn't hold clear/stop and could not get into SP
Ricoh Afficio cl 7000 sc 552 code what is it?
Try the procedure below. Its a hardware error on the device
Press and hold online + escape, then power on.
Use up and down arrow keys to select SP2
Press Enter
Use up and down arror to locate SP5
Press Enter
Use up and down arrow keys to select 810
Press Enter
Confirm the selection
Power off and on.
The error code is now cleared.
Aug 18, 2008 | Ricoh Aficio CL7000 Laser Printer
Ricoh 2018D error code sc 552
Do following steps
1. Yellow cancel
2. 107
3. Hold down red clear/cancel
Machine will beep.
Select 1 - copier sp
Type 5# 810# (fuser sc reset)
Select execute and restart the machine.
If code re-appears you have a faulty fuser lamp or thermostat.
If machine works for a while or at least tries to warm up, you have a faulty thermistor.
Feb 06, 2018 | Ricoh Office Equipment & Supplies
How to clear ricoh MP 2001 sc 552 errors code
http://terraofficesolutions.com/forum/index.php?topic=7.0
Quoting from the link shown:
Ricoh Error Code 552, SC552 Fix - Printer, Copier, Fax Machine « on: September 20, 2012, 10:37:12 pm »
This error is a fusing thermistor error, it can mean:
The fusing lamp is not connected. Reconnecting it may solve the problem.
Thermistor is bent or gone bad. You may need to replace it.
Or, the thermistor position is incorrect.
To try and reset the code press:
Clear Mode, 107, Clear/Stop and hold for 5 seconds.
May 08, 2017 | Ricoh Office Equipment & Supplies
What is sc 552 error code on a MP6002SP
Dirty fusing thermistor. Clean it, go into tech mode and turn off main power switch to reset it.
Aug 29, 2014 | Ricoh Office Equipment & Supplies
RICOH AFICIO SP C811DN
press the up/down arrows together for @ 5 seconds, then hit "ok".
scroll to "engine"
look for 5-810 -SC reset, hit "OK" turn machine off/on using toggle switch.
May 09, 2014 | Ricoh Aficio SP C411DN Laser Printer
How to reset MP161 Ricio
The Ricoh Aficio MP 161 LN give error code - SC 302
Please adivse
Nov 21, 2010 | Ricoh Aficio MP 161 Black and White Copier
Ricoh Aficio Cl7100 - Getting SC 552 error. Ideas?
Hot section problems Replace the fusing unit Its a kit make sure to put a new oil unit DO NOT USE THE OLD ONE, (sorry I yelled but new fuser failure sucks) -Carl
Jul 13, 2009 | Ricoh Aficio 450 Copier
CL7100 error message sc 440-2 Power off and On.
hello, you problem is a color(cmy) pcu motor lock, the motor is damage or exist a mechanical problem whit the pcu's
Nov 14, 2008 | Ricoh Aficio CL7100 Printer
Error
I do not recognize either of these codes (187 or 387) as part of the Aficio 2015 error list.
If the code is displayed on the screen, physically TURN OFF the copier with the main switch (red switch), wait 10 seconds and turn it back on. If it's an erroneous error, this should reset the error code. NOTE: THE ERROR CODE MUST BE DISPLAYED FOR THIS TO WORK.
Jul 08, 2008 | Ricoh Aficio 2015 Copier
10,368 people viewed this question
k24674
Marvin
Marvin
