Question about Sony Playstation 3 (PS3) Console
Playstation 3 will not turn on - Sony Playstation 3 (PS3) Console
    Problem Solver:
  • 8 Answers
This is not the kind of question you want to be answering without details about your playstation. You should probably send it back to sony to get it fixed if you have had it under a year.
iSpearz.
Posted on Jan 19, 2009
When i turn my PS3 on the light goes from red to green but nothing else happens, the discs load and eject thats it. You cannot turn the system off without turning the power off at the wall.
This is a problem with the Playstation 3 software becoming corrupt. It is very easy to fix if you follow my simple steps.
Please note, this method will erase your hard drive so any save games you had will be lost. All your online trophies will be preserved.
Step 1.
Turn your Playstation 3 off into standby mode (red light on)
Step 2.
Press and hold the power button. The Playstation 3 will beep when you first press it, then beep again 5 seconds later and then beep once more and turn off back into standby mode (red light on). You must now release the power button.
Step 3.
Press and hold the power again. The Playstation 3 will beep when you first press it, beep again 5 seconds later then there will be 2 quick beeps together. When you hear these 2 quick beeps release the power button.
Step 4.
Your Playstation 3 will now start up with a screen asking you to connect a controller via USB. Connect your controller and then press the PS button.
Step 5.
A menu will now be displayed on screen. Select option 5 "Restore PS3 System". This will then ask you to confirm that you wish to go ahead with the system restore. Accept whatever the Playstation 3 says.
The Playstation 3 will now go through the system restore process and re-install the system software back to out of the box status. You will have to set your user name, date and time and network settings again.
Once you have completed the above, the Playstation 3 will restart and spring back to life again!
I hope this helps all of those out there who are suffering this problem
Jan 01, 2011 | Sony Playstation 3 (PS3) Console
My playstation 3 wont come on. The red light keeps blinking. It was working fine the I turned it off for awhile, when I came back it wont come on.
1)Turn off your playstation 3. If you think your ps3 has been caught by the heat, then wait at least 20 minutes and put it back on again
2) Check if there's any loose cable.
3) Try to put out your playstation's hard-drive, and put it back in. You might want to repeat this 2-3 times for better results.
If this did not work
Send your playstation 3 back to Sony
May 09, 2010 | Sony Playstation 3 (PS3) Console
I turn on my playstation 3 and it turns right back
This is called the yellow light of death. You'll need to get your console repaired. Contact us today at 888-389-3038 to get a free quote.
- You've been helped by a Wired Extreme technician.
Apr 16, 2010 | Sony Playstation 3 (PS3) Console
Wont read the disc .my sony playstation 3 wont read any disc.
The PS3 has a special Recovery Menu, which you can access in the following way:
1. Turn off Playstation 3.
2. Hold the power button down; the system will turn on and turn off once again.
3. Once the System has been shutdown, re-press you finger until you hear 2 consecutive beeps
4. When you hear the 2 beeps take finger off power button.
5. You will be prompted to plug in your controller via USB and then hit the PS button
6. The Recovery menu will pop up.
The current Recovery Menu supports:
• Restart System: Restarts the PLAYSTATION 3 System.
• Restore Default Settings: Reset all system settings back to default.
• Restore File System: Checks for corrupt/missing system files.
• Rebuild Database: Rebuilds the OS for the PLAYSTATION 3.
• Restore PS3 System: Fresh restore; Deletes everything and starts from Scratch.
• System Update: Update the PLAYSTATION 3 System
From the above select option "Rebuild Database". After PS3 has executed this DB rebuilding operation, the disc games will be visible again in the menu.
Apr 07, 2010 | Sony Playstation 3 (PS3) Console
My playstation 3 just stopped. Now it turns on
This is a hardware fault. This console will need to be repaired
Aug 30, 2009 | Sony Playstation 3 (PS3) Console
My ps3 wont turn on
If the PLAYSTATION 3 feels extremely hot or the system will power off and the power light will flash, this could be an indicator there is a temperature issue with the PLAYSTATION 3 and it is not able to keep the system cool. Please attempt the following troubleshooting steps.
  • Remove any obstructions from the vents.
  • Allow at least 4 inches of clearance on all sides for the PLAYSTATION 3.
  • Remove the PLAYSTATION 3 from any cabinets so it is out in the open.
  • Shut the PLAYSTATION 3 down completely and let it cool down to room temperature, then try running it again.
  • If the fan cannot be heard before the system shut down, the PLAYSTATION 3 may need to be sent in for service.
  • If there is no airflow from any of the vents, the system may need to be sent in for service.
May 25, 2009 | Sony Playstation 3 (PS3) Console
Playstation 3 problem turning on
contact sony @ 1-800-345-SONY (7669) tell them your situation and request an RMA number, this is a known issue and they should fix/replace the unit for you.
Dec 12, 2008 | Sony Playstation 3 (PS3) Console
Playstation 3
no that will be perfectly fine if you play it while its turned up side down
Dec 12, 2007 | Sony PlayStation® 3 (60 GB) Console
Sony Playstation 3 (PS3) Console Logo
55 people viewed this question
Top Sony Video Game Consoles & Games Experts
shaun taylor
juanmireles1
Damen Wong
Damen Wong
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
