Question about Garden
Hi, My name is John I have a Ariens powersweeper Model 936PB that I am installing a new chain on. I need a picture of how it is threaded through the idler pulley.
SOURCE: MTD Lawn Tractor: Constantly shredding deck belt...
I have the exact same model MTD tractor with same problem. It began when the bolt that extends through the idler arm assembly broke and subsequently damaged the pulley. Upon examination of the broken bolt, I found that the threaded end that extends below the deck is significantly smaller that the rest of the bolt. I got a larger bolt with the same size threads, bored out the hole through the deck and it made the whole idler assembly much stronger. the deck still has some vibration and some unusual belt harmonics, but it appears to be working. Compared to most other tractors of this size, this deck is very complicated.
Posted on Jun 15, 2009
  • 218 Answers
SOURCE: can someone please help lookingh for belt routing
Hey John..my name is Keith..and you can go to an online lawn mower parts site..and they will have a pic of the deck and they way the belt is routed...one of the sites is www.outdoordistributers.com ...i hope this will help
Posted on Jul 08, 2009
mowerman1857
  • 389 Answers
SOURCE: The mower deck drive belt slipped off the idler
Get the model number off the tractor, go to:
www.murray.com
enter the model number and you will find a manual with pictures of how to route the belts along with a lot of other good information
Posted on Sep 30, 2009
mowerman1857
  • 389 Answers
SOURCE: CRAFTSMAN Tractor Model%23 917257643 adjust idler
First things first! Before you installed the new belt, did you check the blades and idler pulleys to see if they all turned freely with no resistance while the belt was off and the blade brakes released? Release the blade brakes by engaging the handle with the engine off!
When you installed the new belt, did you put the back side of the belt against the flat pulleys and the inside of the belt in the V-pulleys? Did you double check to make sure you didn't inadvertently miss a belt guide getting the belt on the outside of it instead of underneath it. Did you look at the picture in your owners manual to make sure you had it routed correctly and make sure it is not rubbing against anything when you have the blade lever engaged? CHECK THIS WITH THE ENGINE OFF If you don't have your owners manual, look under the foot boards on the tractor, many of the Sears tractors have the routing diagrams there. If it is not there you can go to searspartsdirect.com , enter model number 917.257644 (NOTE the number difference) and look at the picture of the deck, it shows what the belt should look like when it is installed. You can also download an owners manual there. As best as I can remember, there is no adjustment for the idler pulleys.
Posted on Oct 25, 2009
  • 146 Answers
SOURCE: 609 yard machine tractor idler pulley spring broke
Here's a diagram, not a great copy, but it may help:
The spring hooks to the idler arm on the opposite end from where the pulley is mounted. The other end of the spring looks like it hooks to a raised tab on the deck, straight behind the left mower spindle. Hope this helps you, please rate my solution if so, thanks!
Posted on Jun 08, 2010
Where can I find a deck diagram for a Scotts 1642h. I need to order a flat idler and a v pulley.
Looks like Ariens Dealer could be of Help to You ,Look to see if you have a Dealer near you and call with your model Number and make tractor they should be able to help, You can look on Google for Scotts/ Ariens Mower Parts Manuel find you parts needed? Thanks John
Apr 09, 2017 | Scotts Garden
How to install a new blade for my 10 inch electric chainsaw - model 358-34010
Loosen the chain adjuster and remove the bar bolts. Remove the side cover. Remove the existing chain. Thread the new chain over the sprocket making sure the drive cogs are engaging the sprocket correctly, then thread it over the end of the bar ensuring the drive cogs are inserted correctly in the bar groove. Install the bar/chain onto the bolts aligned with the chain adjustment pin and install the cover. Snug the bolts and tighten the chain with the guide bar tip elevated. Once you are satisfied with the chain tension, tighten the bar bolts and....... VOILA.... you are done. Head for that pesky neighbors tree that drops leaves in your yard.....
Of course, make sure the chain orientation is correct !!!! I have seen them installed backwards on the shelf in the big box stores....
Apr 19, 2015 | Craftsman Garden
Are there any left hand threads on the Ariens ST824 snowblower model 924050
As far as I know there is none on the Tecumseh engine. For the rest of the blower there shouldn't be any but there could always be some.
Manufactures tend avoid left hand threads as much as possible.
Feb 13, 2015 | Ariens Garden
Replacing my cam chain on a 1995 xjr 400 can the chain be split and threaded round the crank please help thanks
Hi, John for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Yamaha, despair not, for a mere zero $ you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
Sneaky motorcycle cam chain replacement technic how to Davidsfarmison...
Cam Chain Wear and Replacement Tips
http://www.doremiweb.com/yamaha-xjr-400-manual.pdf
OEM parts for Yamaha
http://japan.webike.net/YAMAHA/XJR400/Others/866/9900/mc/p.b=847
Aug 22, 2013 | 1999 Yamaha XJR 400
Chain ****
Scott, this sounds like maybe the derailler is not taking up the slack in the chain. You might not be threading the chain through the derailer correctly, or the spring in the derailer is not working. Maybe if you could post a picture of the folded chain and a picture of how the chain is threaded through the derailer I could help you further
Apr 03, 2012 | Norco Six SE
Blade number for Ariens Zero Turn Model 1840. Need
Depending on which version of the 1840 you have and when it was built it could be several blades...
Please get your model and serial number and then enter them into the following site's search engine. You should then be able to identify the parts you need.
http://partsradar.arinet.com/scripts/EmpartISAPI.dll?MF&app=ariens&lang=EN&TF=Empartweb&loginID=ariensc&loginpwd=consumer
John
Jan 18, 2011 | Ariens Zoom 42 In 165 HP Briggs Stratton...
Bobbine keeps getting knotted up, I have replaced it with a new bobbin and it keeps happening.
Hi my name is John. Welcome to FixYa. If the bobbin is knotting up, you need to loosen the tension on the bobbin and tighten up a little on the thread, you kinda have to play around with it a little to get the feel of it. Say may less than a half a turn, until you get it to where you want it. Then there will be a question about the thread breaking, sometimes it will be old outdated four year old thread. Thanks for choosing FixYa...John
Dec 08, 2010 | Janome Sewing Machines
Hi, i have a Ariens Zoom M 2148 xl tractor model
Probably you can get what you need at a lawn mower shop, they have exploede parts diagrams on microfilm.
Sep 28, 2010 | Ariens 34 In 344 CC Briggs Stratton...
Can someone please help lookingh for belt routing for the mower deck for a ariens riding mover yt12g model and the belt to the mower deck how it routes on tension pulley thankyou john
Jul 08, 2009 | Garden
Garden Logo
24 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
