Question about Sony Xplod XM-1652Z Car Audio Amplifier
Amp will not power up at all
Today while I was driving to work, I lost all bass. I checked and my amp is no longer powering up, not lights what so ever come on. The amp is about 5 yrs old and so are the subs, I checked all the fuses and everything and all the wiring is in good condition. Could my head unit (which has been having problems) be causing this or is my amp more than likely dead? Thanks.
  • 113 Answers
Check all power present.main,remote and gnd.
Posted on Aug 09, 2007
Amp shuts off.
check the connection of power connection and the remote connection tone amp,you can check also you inside by using your hand ,turn on the amp and wiggle it the power connection parts.
Jun 15, 2013 | Jl Audio 500/1 Car Audio Amplifier
Remote bass control
there might be a hidden switch on the amp for with or with out bass control
Apr 25, 2010 | Power Acoustik GOTHIC OV2-1800 Car Amp
Amp burned out but fuses still good?
this is caused by inproper wiring from the speakers/subs to the amplifier.. an amp will still put out power to subs and speakers when it's wired improperly but it won't last for very long doing it... 6 months is longer than usual....
Dec 05, 2009 | MA Audio M1900XE Car Amp
Kicker zx 400.1 amp no power.. is it fried?
Well Friend, the chances that your amplifier is Fried are very low. First of all deactivate the Auto Turn On Feature on the Amplifier. Second, check that the voltage is received at the Power connector of the Lead that is coming from the Battery using the Multimeter to make sure that the Main Fuse is all right. If No Go, then check the Amplifiers fuses thoroughly. Then check if the Protection LED is lit. If it does not work after all of it, get it checked at any local radio shack as I'm sure, it cannot get fried just like that, as it is possible that some internal connection has fried or became loose and will be fixed without spending much. I wish it will help you..
Mar 14, 2009 | Car Audio & Video
Fender Rumble 100 210 pop noise then hum after strong low e note
I just fixed my bass amp with a similar problem last week: the problem is related to a loose connection on the PCB board (likely).
A bass amp is a rough place for circuitry: the low rumble and power shake a bass amp more than a guitar amp.
In my case, the power transistors needed to be re-soldered and then the grounding bolts and screws needed to be removed and cleaned because the connection was bad. Remember that when two different metals needed for an electric connection are toughing, there is the likelyhood that corrosion WILL happen.
My bass amp did basically the same thing yours did: sounded good at low volumes, but at higher volumes it would act up.
In short, there is nothing you can do (unless you are a repair person): you need to take it to a local music shop and have a tech fix the intermittant contact problem: someone who knows what they are doing should only take an hour at most.
Hope that helps!
-mike
Feb 22, 2009 | Fender Rumble 100 Bass Guitar Amplifier
JL 300/2 v2 Power Light Blinks, No sound out of Sub. Works in friends Car HELP
Are you sure you don't have any shorted wiring or defective speakers?
Sep 30, 2008 | Jl Audio 300/2 Car Audio Amplifier
Powers on but no sound
Check the main amp fuse under the hood, even if it looks good just change it. Often times that light on the amp can come on just from the power amp tunon wire. Try a friends subwoofer box just to make sure the connectors on your box are good, and if that doesn't work then give me some more details....year/make/model of car, what kind of sub, what types of things do you see on the side of the amp....is there a green light as well as a red light?
Aug 18, 2007 | Xtant A3001 Car Audio Amplifier
Speakers cut off when bass goes up...
it might be that your wires from your amp to your subs are too thin. since they were relatively new the first three months, they were probably undamaged, but after pushing them too much, they probably have broken wires, and can't get enough power to the subs when turned up, i suggest getting thicker wires before investing in a capacitor, it could save you money.
Mar 21, 2007 | Sony Xplod 1100 Watt Max 10" Subwoofer,...
Amp stopped working...
Has the amp been overheating lately? It's quite possible that the amp could have just blown. Smell around the outside of the amp for an electrical burnt smell. If available, see if a friend also has an amp hookup and try removing your amp and copnnecting to the friend's cables. That will tell you if it's a wiring problem or an amp problem.
Sep 13, 2006 | Kenwood KAC-9152D Car Audio Amplifier
Sony Xplod XM-1652Z Car Audio Amplifier Logo
43 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
