Question about Tektronix Phaser 780P Laser Printer
Crackling noise coming from fuser area while rotating
Hi -  RE: Phaser 780: 22,000 pages - very clean Fuser: 70% remaining.
I'm inquiring because the fuser assembly items seemed to pass inspection, and want to know that if the machine is printing just fine, can I afford to ignore this sound or do I try to replace the correct part because I could be doing expensive damage I don't know about.
I inspected the fuser, shiny gray roller and red rubber rollers and did not see any defects/ scratches or gouges or toner buildup. The red roller did seem to have a slight bit of oil present at either end. When the printer is warming up, and while printing (prints fine by the way), only while parts are rotating in the fuser area, or the fuser is being heated, I hear a sort of snap-crackling noise akin to hot oil....
May be important to note that when I had the fuser out to inspect the other 2 rollers and turned them with the gear on the left, I thought I could hear the same crackling noise intermittently, so it may be one of the other two rollers and not the fuser.
I do have the luxury of a newly acquired donor printer from which I could swap parts, as well as a new fuser on hand to see if I could correct the problem.
Many thanks for any advice before I spend Christmas frankensteining the donor printer.
5 Suggested Answers
SOURCE: Tektronix 740 fuser
found solution, was the clutch on the accumulator shaft
Posted on Feb 06, 2008
faxman789
  • 297 Answers
SOURCE: White stripes evident each time the printer is started up from cold
Those solid ink machines are designed to be left on 24 hours a day, 7 days a week. (it uses about $20 in ink to turn on each time)
When turned off the printhead nozzles can get clogged up with dry ink, which causes white stripes. Running the eliminate light stripes routine purges the printhead (using another $10 or $12 in ink). When it becomes a continuous problem the printhead needs to be replaced....very expensive and time to get a new printer !
Posted on Jan 22, 2009
  • 42 Answers
SOURCE: I have a Tektronic Color
hi,
the paper jamming problem is generic to most printer models of this capability. one way to circumvent this is to use a multimedia-tray while printing.
the reason is probably the two springs that hold down a silver metal pressure roller in the feeding unit. The tension is uneven due to old springs and the paper pulls crooked. If you follow the paper path in the fedder mechanism, you will see the roller I am referring to. The springs are at either end of this bar.
If you are good mechanically, you can replace the springs yourself, although they are a ***** to get back on (some disassembly required).
try this for details on doing it.
cheers
Posted on Jul 23, 2009
  • 4 Answers
SOURCE: My phaser 740 has print
Recalibrate the colors. Flaking is sometimes caused by more ink/toner than can be fused to the media. There's a limit for the total amount of ink/toner. Yours may be set too high.
You'll need a copy of the Printer's User's Guide (also Downloadable from Xerox.com)
Controlling Color Density
When colors look faded, adjust the toner color density to extend the life of the components.
Print and use the Color Reference Page 1 In the printer's front panel, scroll to Calibrate Colors,
press Menu and print the Color Reference Page. 2 Compare the Color Reference Page to the Color Density
Samples on page 39. Make a note of the value (-10 to +10) for each color that most closely matches the samples.
3 Adjust the density for each color: Enter the value noted in Step 2 in the Calibrate Colors menu, under Adjust Each Color.
? Decrease color density: Press . ? Increase color density: Press --->.
4 Reprint the Color Reference Page; check your adjustments
Posted on Sep 25, 2011
How to clean phaser 7750
Included general maintenance video and how to clear smears from the paper.
Solution: Remove Print Smears / Printing Fuser Cleaning Pages
7750 Support Knowledge Base Remove Print Smears Fuser Cleaning...
With Troublshooting highlighted on the printer display perform the following steps:
  1. Press OK.
  2. Press the Down Arrow and scroll to Print Quality Problems.
  3. Press OK.
  4. Press the Down Arrow and scroll to Remove Print Smears.
  5. Press OK. The printer will print 5 cleaning pages.
Repeat this process five or six times, to remove stubborn toner buildup from the fuser.
Always make sure you are matching the type of paper loaded in the printer tray(s) to the correct Paper Type front panel setting. When you load a tray with paper, the front panel will ask you to indicate the type of paper you loaded. For correct print quality and printer operation, be sure to set this correctly.
MAINTENANCE:
Phaser 7750 Video Instruction Maintenance for the Printer Phaser
Apr 23, 2014 | Xerox Phaser 8550/SDP Color Laser Printer
Xerox Phaser 4500 printer has a U4 fuser code.
From the Xerox Phaser 4500 Service Manual (here), the main problems could be one of:
  • Warm-up failure - Fuser warm-up not complete within 110 seconds after
  • starting.
  • Cool-down error - Cool-down process not complete within 200 seconds.
  • Low trouble temperature - The fuser temperature drops to the low trouble
  • temperature (approximately current control temperature, minus
  • approximately 25°C).
  • High trouble temperature - The fuser temperature rises to the high trouble
  • temperature (approximately current control temperature, plus
  • approximately 35°C).
  • STS circuit open
  • STS failure - The heat rod remains on for at least 10 seconds after warm-
  • up has completed
It could be that your fuser needs to be replaced, but as you can see that code relates to a couple of problems, so even replacing the Fuser might not fix the problem.
If it doesn't even do the warm up checks it is likely to be the fuser because the other components such as STS failure and cooldown won't have had a chance to run..
May 03, 2011 | Office Equipment & Supplies
I have an ImageCass D861 copier. I have loved it until recently and it's getting worse. If I make only one copy when the machine isn't warmed up, it will be clean. But if I make multiple copies, or more...
This is coming from 1 of 2 places. The first and most common is the toner cartridge itself. If you have a spare go ahead and replace it. If not you will need to get another cartridge and swap it with your current cartridge. This will correct the copy quality 9 times out of 10 on these machines. If a new cartridge does not resolve the issue then the only other cause is the fusing unit. The fusing unit is located right where the paper exits the machine. It heats up and uses heat and pressure to "fuse" the toner onto the paper. When the fuser film in the fuser starts to go bad they will start to run dirty and also "double image" where a part of the printing from the top of the page gets reprinted lighter at the middle/bottom of the page. Sometimes you may also hear a crackling sound coming from this area which can be a sign of the fuser film going bad. The fuser replacement is much more expensive to have done so let hope that the cartridge will resolve your issue.
Good Luck and Thank You for using Fixya.
Sep 04, 2010 | Canon ImageClass D861 Printer
The black print jobs have a shadow about 3 inches down the page
I had replaced the fuser - no improvement. I removed the fuser, imaging unit & transfer roller. CAREFULLY using a vacuum cleaner I cleaned all units and the internals of the printer, rotating the roller on the imaging unit to clean all parts. (Warning Place Imaging unit on paper as toner escapes) After a few test prints the page cleared and duplicate ghosting cleared.
Apr 07, 2010 | Xerox Phaser 6360 Laser Printer
Making a cracking noise from the fuser unit area
I'm assuming that the cracking noise occurs as the printed page is passing through the fuser?
Check your print settings to ensure that your paper stock is not set to heavy (card). This setting applies extra heat to the fuser to 'fuse' the text to the paper, which is what you want for card, but if you are printing normal stock, it will overheat the toner causing it to stick to the fuser roller on the way through and make a 'cracking' sound as the paper peels off the roller.
Whilst it is possible that there is a fault with the thermostat and the fuser heater is not switching off, this is rare. If you have been printing a number of pages at an incorrect paper stock setting you may need to clean baked text of the upper fuser roller, in which case, apply the following procedure.
After switching off the pirnter and it has had time to cool you may be able to clean the upper fuser roller with a rag moistened with a little methylated spirit, although you will not be able to rotate the roller fully without removing the fuser assembly from the printer. If the roller is physically damaged however, eg. scoured, cleaning will not resolve the problem, the roller will need to be replaced. This usually occurs after a long life, so it is generally best to install a new or reconditioned fuser (includes new rollers, top and bottom and new heat lamp).
Mar 19, 2010 | HP LaserJet 2420 Printer
HP LJ P2015DN making noise/squeaking
As you mentioned that the printer makes loud grinding noise or squeaking when page comes out than i feel this is the noise coming out due to faulty fuser.
I want to be sure so please open the rear bin and try to print if still noise comes than i m sure it is fuser.
If there are smudges on the printed page or if some film coating is coming out with printed page than fuser roller are physically damage.
However in this case i assume fuser is faulty.
If there opening the rear bin noise goes off than top output rollers are faulty.
Thanks and Regards
Neeraj Sharma
Feb 18, 2009 | HP LaserJet P2015dn Printer
Phaser 7700 steaks on Magenta, sometimes yellow.
Each color has its own laser. Use the cleaning wand in the front door to clean the lens covers for each color. You will need to remove the waste toner cartridge in front of the the slots to do this. If that does not cure the problem, you will need to replace the developer housings for the colors that are streaking. The manual can be downloaded at: www.lpscomputer.com/ec/Phaser_7700_Service_Manual.pdf
and parts purchased at: http://www.lpscomputer.com/p-3063-1-116-1115-00-developer-housing.aspx
Dec 12, 2008 | Xerox Phaser 7700 Laser Printer
Reset page count
Hi bseema:
Hope that this helps you.
Resetting Fuser Life
This procedure restarts the counter that tracks Fuser life. Perform this procedure after
you install a new Maintenance Kit.
To reset the fuser:
1. From the Main Menu, select Information, then press the OK button.
2. Select Supplies Info, then press the OK button.
3. Select Reset Fuser Life, then press the OK button.
4. Select Reset Fuser Life NOW, then press the OK button to reset the fuser life
Oct 13, 2008 | Xerox Phaser 4500 Printer
Phaser 7700GX Color Printer prints wrinkled pages!
when this occurs the problem is most of the time with the transport roller, fuser / fixing assembly roller.question is the image still toner only and not fused to the paper.
In these areas there is offen a jammed and not removed piece of paper dislodged in the paper path or jammed in the fuser or the transfer rollers teflon coating has perished inspect the areas carefully and remove any found if the unit still is faulty (fanning of paper the fuser would be the first to be replaced are past there usable life) if so then Post a reply
Sep 10, 2007 | Xerox Phaser 7700 Laser Printer
HP 2600n crackling noise at top feed - paper creased
Can you wipe the toner off the page or smear it? Most likely the fuser has had the fixing film fail. Thus the crackling noise. You have two solutions, 1. replace the fuser with a ne or rebuilt one or 2. find a fixing film and replace it yourself. Both jobs require removing the fuser which means disassembling the printer. Check Printer Works for a diagram and Google for the best price on a fuser. Hope this helps.
Sep 01, 2007 | HP Color LaserJet 2600n Printer
Tektronix Phaser 780P Laser Printer Logo
60 people viewed this question
Top Tektronix Office Equipment & Supplies Experts
k24674
Marvin
Marvin
Are you a Tektronix Office Equipment and Supply Expert? Answer questions, earn points and help others
