Question about Microsoft Xbox 360 Console
My 360 has one red flashing light.
The red light only comes on with the HDMI is hooked up or the component cords are hooked up.
Help please.. my xbox has 3rl.. cant play 2k9 for a long period of time
Posted on Dec 23, 2008
How do I hook up Xbox 360 to the HDTV
Step 1:
Connect the audio/video input of the component cable into the "A/V" port located on the back of the xbox 360
Step 2:
Match the red, blue and green cables on the other end of the component cable to the corresponding component ports on your HDTV. If your HDTV has more than one set of component inputs, make note of which one you use.
Step 3:
Slide the switch on the component cable to "HDTV."
Step 4:
Turn on your HDTV. Set the video mode to the component port that will be used. HDTVs with multiple component ports will usually be labeled "Component 1," "Component 2" and so on
Step 5:
Turn on the Xbox 360. Go to "My Xbox." Select "System Settings" then "Console Settings" then "Display" and then "HDTV Settings." Choose the display setting (720p, 1080i and 1080p) that is best compatible with your HDTV. If you're not sure, try them all until you find the one that looks best.
Step 6:
Disconnect any previously connected A/V or component cables.
Step 7:
Connect the HDMI AV cable connector to the "HDMI AV" port on the Xbox 360.
Step 8:
Connect the other end to an available HDMI port on your HDTV. If your HDTV has more than one HDMI input, make note of which one you use.
Step 9:
Turn on your HDTV. Set the video mode to the HDMI port that will be used. HDTVs with multiple component ports will usually label them "HDMI 1," "HDMI 2" and so on.
Step 10:
Turn on the Xbox 360. Go to "My Xbox." Select "System Settings" then "Console Settings" then "Display" and then "HDTV Settings." Pick the display setting (720p, 1080i and 1080p) that looks best on your HDTV.
Dec 26, 2012 | Video Game Consoles & Games
How do i hook up my xbox360 to a 55in philips flat sreen
either with the included component (yellow red white or green red blue, red white(provides HD) or an HDMI cable you supply, you also have to confirm you xbox has a hdmi port on the back (near internet cable)
Mar 02, 2011 | Video Game Consoles & Games
The power to my console comes on. There are no red lights and the disk is spinning. However, the startup sequence doesn't start (the flashing green lights and the startup screen). what is the problem.
I have seen this problem in the past and what fixed it for me was checking the video cable connection on the back of my console and my television. It turned out my HDMI cord had come loose slightly and the console refuses to boot unless the cable is plugged in. Same goes for your standard component cables, so have a look and hopefully that is the problem.
Jan 31, 2011 | Microsoft XBOX 360 ARCADE Console
When i turn my xbox 360 on it starts running hard then the controller lights on the device start flashing red.
Four lights around the power button flash red on your Xbox 360 console. Four flashing lights indicates that the console does not detect an audio/video (AV) cable.
Note Four flashing red lights will not appear on consoles that have both an AV port and an HDMI port.
Solution
http://support.microsoft.com/kb/906652
Mar 24, 2010 | Microsoft Xbox 360 Console
I just need to see a visual connection of xbox 360 to bacig flat screen tv.Eight now i am not getting a picture.Ihave regular x box hooked up and iam getting a picture for that.
First check the AV audio/video wires to determine if you have SD or HD wires. If you have 3 plugs (red, white, and yellow) then you will get standard definition (SD). If there is 6 wires (2 red, white, yellow, blue, and green) then you can connect High Definition (HD) and you can also connect SD as well. Now what you need to look @ if you have the wires with 6 ends (component HD AV wire), is on the part where you plug into the back of the Xbox 360, there is a switch on the box that is on the wire. It should say "TV" and "HDTV". If you have the component wires hooked up (5 wires) then select "HDTV" if you have only the 3 wires (red white yellow) for SD hooked up switch it to "TV". That is the first thing to check. The next thing to check is the way the wires are hooked up. If connecting HD, you very easily could've mixed up the 2 red wires, 1 is video and the other is audio. The way to determine which is video and which is audio is, for video, the actual plug itself is gray with a stripe of color which indicates where it goes on your tv, the audio plugs are solid white or red. And remember that the yellow plug is not used for HD setup. If you have a Xbox 360 that has the HDMI (High Definition Multimedia Interface) input, then I would recommend using that to hook up your console. With the HDMI its only 1 wire to hook up and is extemely easy to set up. The HDMI wire transfers audio and video all in 1. There is only spot it can fit into, and its located right next to where you plug in the AV wire on the console. To me, the HDMI is "cleaner" looking b/c its only 1 wire.
Feb 27, 2010 | Video Game Consoles & Games
Xbox 360, hdtv, surround sound assistance
Since the reciever does not show any picture use that hdmi input for the x box. and component inputs for the reciever.
Jan 23, 2009 | LG 42LG50 42 in. LCD HDTV
HDMI problem with Xbox 360 to Dell TV
check that the wire coming from the xbox 360 elite to the tv is switched to hd, and the other end of the wire has the red and white for the sound pluged into the tv and that the red green and blue wires are pluged into the tv. also check to see if the hdmi cable to conected to the tv and xbox 360 elite.
Jan 06, 2009 | Microsoft Xbox 360 Elite Console
One red flashing light on 360 and error code E73
which light is it? (xbox hd facing up)
anyway.
http://forums.xbox-scene.com/index.php?showtopic=484726
Dec 15, 2008 | Microsoft Xbox 360 Console
No picture or sound on the tv
where you put the cables for the sound and picture if you look on the end where you plug it into the xbox 360 you will see a little switch it has HD and TV on it depending on what your tv supports (HD ready TV) (normal TV) switch that switch to what TV you have (e.g. HD TV, switch the switch to HD) if that doesnt work then try checking that you have all the cables in the right ports if you have pluged the HD cables into a normal TV then this is not going to work, check cables and check the switch!
Jun 05, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
27 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
