Question about Hobart Handler 140 Mig Welder
Seised wire inside feeding tube
My Hobart handler 135 works but the weling wire is stuck solid inside the feeding tube  I have pulled on both ends and the tips are gone now , the wire is still inside is there a way to pull the wire out ?   is there a way to remove nozzel and handle  from cabel/feeding tube?
  • 15,935 Answers
You can replace the liner by removing the shroud tip, and pulling the spring (liner) from the machine end of the trifgger cable.
Liners are replaceable.
Posted on Dec 23, 2008
Wire feed is not stable on Hobart handler 135
is this a lower end machine ? the cheaper machines take the power from the welding transformer to power the feed motor and as a result the feed isn't stable, also is the wire liner and tip in good condition if not replace them, try blowing through the liner with compressed air to clear any dust from the wire
Sep 17, 2013 | Hobart Welding Tools
Hobart handler 135, the wire starts to feed for about 15 seconds then slows and stops.
Hi:
Don't know how old is your unit but my guess is that your gun's liner is the problem. Have you change it lately? If not, change it. Does your machine just stops feeding the wire or does it shuts down? If it just stop then; is the liner, if it shuts down; then you have a pc board problem.
Oct 29, 2011 | Hobart Handler 140 Mig Welder
Hobart handler 135 wire feeds for about a two feet then stops feed motor runs well under no load
This happens to me all the time. Wear and tear has taken its toll and everything has to be maintained for it to work. Most likely the welding tip is worn and should be replaced. Lincoln electric tips work well and I will replace mine several times during the day. Also check your tension and make sure the wire will uncoil freely from the spool. You can remove the tip and make sure the wire will feed without it. If not, your liner may be worn out. Also a welding Jell will help keep the tip from cloging. It will still happen, but hopefully not on your first weld of the day.
Jan 15, 2011 | Hobart Handler 140 Mig Welder
Have a Hobert handler 135 i can't control the wire feed speed it seems to run wide open.
Sounds like the restate that controls the wire speed is gone. Replace it.
Jan 05, 2011 | Hobart Handler 140 Mig Welder
Hi I have a Hobart 135 Handler the problem is the feed motor only works for a few minutes of welding and then slows down or stops the goes slow again.
First there is a overload for the drive motor incase the welding wire gets jammed. I've had one of these for a number of years and only recently understood the markings on the drive wheels. When the wheel is installed, the markings for the wire size is for the wire you're using. In other words, the marking is towards you but is indicating the size for the rear groove. For years, I looked at the numbers and assumed that they were for the groove closest to the numbers. I had no problem with solid wire, but with flux core all kinds of trouble. So, make sure you have the right groove for the wire size. Second make sure there are no kinks in your hose. Make sure your contact tips in the gun are the right size for your wire and in good condition A person has e a tendacy to make ther drive wheels tighter when the feed slips, this can cause problems for the flux core wire if the correct drive wheel is not selected.
Jun 21, 2010 | Hobart Handler 140 Mig Welder
Hobart handler 135 feed motor for wire doesn't feed wire. motor is ok I tested it with seperate power source. No power to motor from main board or ??????
check the SCR ,looks like a big transistor mounted
to a heat sink or some of the older units had a relay
in-line with a fuse , I have a older Hobart and it is
a great little welder. If you snap a pic of the P.C.
board and email it ill rsheehan@northernsteeldesigns.com
point out what parts to check.and replace.
Rob
Dec 06, 2009 | Hobart Handler 140 Mig Welder
Hobart 135 wire feed sped control problem
you have a resistor down, first check the resistor on the centre pole then those going off to the two other pins
Oct 04, 2009 | Hobart Handler 140 Mig Welder
Wire burning betwen rool and feed drive
When you pull the trigger the entire spool of wire and anything metal that touches it becomes electrically hot. If the tail end of the spool is hanging loose and touches something on or connected to the chassis it will do that, and could have welded the connection so it's solid.
May 13, 2009 | Hobart Handler 140 Mig Welder
My hobart 135 will not feed wire. I checked for voltage at the drive motor no voltage. The gas still comes on when trigger is pulled but seems that the problem is in the control board?
does it have a reset button? if so it has gone bad, if not there is a fuse or something inside. they protect that circuit against shorting at the working end of the gun. happens ALL the time.
Hawk
Mar 31, 2009 | Hobart Handler 140 Mig Welder
Hobart handler 140 will not feed wire
A schematic would certainly help, give Hobart a call and ask for a wiring diagram. or manual. Hobart are very helpful and may even give you guidance, you may have to pay the postage, they usually fax these documents so it will not cost you anything.
Feb 13, 2009 | Hobart Handler 140 Mig Welder
Hobart Handler 140 Mig Welder Logo
413 people viewed this question
Top Hobart Welding Tools Experts
Robert Lee
Level 1 Expert
Delage guy
Delage guy
oneStan
oneStan
Are you a Hobart Welding Tool Expert? Answer questions, earn points and help others
