Question about RCA R52WM24 52" HDTV Projection Television
I would like to knowwhere the fuses are located on an RCA HDTV-rear projectio- model #R52WH73?
  • RCA Master
  • 1,527 Answers
The fuses should be right next to ac power cord coming in to the tv and there may be 1 in the middle of the board good luck
shaun
Posted on Jan 10, 2009
Color seperation on my oct. 2006 rca hdtv model no. r52wh73 --- serial no. g432c106i---- chassie itc222a----service no. r52wh73yx61
ghostflame88,
Bad convergence circuit. See my tip at http://www.fixya.com/support/r5119668-fix_convergence_problems_rca_chassis to help solve your convergence problem.
Thanks for using FixYa and for the great rating.
hardrocko
Jun 27, 2011 | RCA R52WH73 Projection Television
A red blue and green line jus appeared across the screen of my 55 inch rca floor model big screen. instantly my picture and color become distorted
conversions are out....rca ... check for bad connections on circuit board around fryback xformer. check fuse by flyback xformer...fuse is shaped like a little plastic rectangle>>fuses should measure a SHORT when GOOD! Flyback Transformer is large in size and sends highvoltage to 3 picture tubes via a SPLITTER . easy to locate
May 19, 2010 | RCA R52WH73 Projection Television
The picture is blury and distorted - can this be fixed? Tv is RCA HDTV model R52WH73
Try to clean the lenses and make sure the convergence is setup right. It should fix your problems. Good luck
Mar 05, 2010 | RCA R52WH73 Projection Television
RCA D52W26- 52 " rear projectio- 3d
try to inspect the convergerce power supply and the convergence output module for cold solder joints around the mos fets...i had seen many of them on the same condition.
Jan 22, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W26- 52 " rear projectio- 3d colors,,,is convergence issue
um i think your gona meet your maker,,,your solutions are not being tolerated.. listen...to the new maker, he can and will make you learn what manners are!!
I have a 52 inch RCA model # R52WH73. The picture is blurry and double. What do I need to do to fix it?
Ur convergence is dead,need a convergence kit,know how to solder right?Tries these websites.Tv Repair World.com,Ebay.com.
Oct 12, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Help I need a replacement screen
You can find a new OEM RCA replacement lenticular screen and Fresnal screen (availble together as the screen assembly) for a model # R52WH73 from a major RCA distributor at the following links:
RCA R52WH73 Replacement Part Screen Assembly (Fresnal Screen w/ Lenticular Screen)
And here's a link for the protection screen if needed:
RCA R52WH73 Replacement Part Protection Screen / Super Shield
Apr 10, 2009 | RCA HD52W59 HDTV Projection Television
No Convergence
yes that model is the same itc222 chasis... the fl231 problem is common on all itc222's even more so on that model .. consult the tips and tricks section for the fl231 problem repair instructions
Jan 11, 2009 | RCA R52WH73 Projection Television
I am working on an RCA HDTV Model # R52WH73. The RGB channels are not aligned properly on the screen and there is no option in the menu for correcting the alignment. I have electronics repair experience,...
There are bad connections on the flyback transformer and, in addition, right beside the flyback you will see three little square fuses. The one in the middle will be open. Replace it and solder the flyback, All will be okay
Dec 05, 2008 | RCA R52WH73 Projection Television
Rca r52wh73
Can you reply to this post and verify which model is your TV?
Jul 20, 2008 | Samsung PCN5425R 54" Rear Projection...
RCA R52WM24 52" HDTV Projection Television Logo
53 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
