Question about HP 530 Notebook PC
Installed service pack 1 from microsoft for windows vista. after updating everytime i turn on my laptop i get installing service pack stage 3 of 3 100 % complete but does not go in os
  • Shoaib Rais
    Shoaib Rais May 11, 2010
    start in safe mode and system restore to earlier date when ur laptop; was ok press f8 or try others i n startup of laptop to go to safemode
Restored My Gateway FX Laptop. Vista Service Pack 1 will not install
Try to manually download and install. Here
http://www.microsoft.com/en-us/download/details.aspx?id=30
That should work
Dec 20, 2012 | Computers & Internet
Tip
What Does It Mean When Support for My Operating System Ends?
Microsoft Support for Windows Vista (with no service packs installed) ended on April 13, 2010, while support for Windows XP (without Service Pack 3 installed) ended on July 13, 2010. Windows 2000 support ended on July 13, 2010 as well.
There is no Service Pack 3 for the 64-bit version of Windows XP. If you're running the 64-bit version of Windows XP with SP2, you have the latest service pack and will continue to be eligible for support and receive updates until April 8, 2014.
If you are still running a version of Windows where support has ended, it means that version of Windows will no longer receive any updates from the Windows Update or Microsoft Update site. These updates are generally provided for security reasons to help protect the PC from harmful viruses, spyware, malware, and other malicious software. Windows Update also provides new drivers for your hardware that can improve the reliability of Windows.
Hackers love to take a security vulnerability in Windows and exploit it to their advantage. So, if a vulnerability is found in Windows XP or Windows Vista and you are not running the latest service pack, you will not be protected and will be at risk.
How Can I Tell What Service Pack is Installed?
Follow these steps to discover what Service Pack is installed:
1) Click on the Start Button
2) Right-click on either My Computer or Computer (depending on your Windows version)
3) Click on Properties
On this window, it should tell you which version of Windows along with which service pack is installed). It should also tell you whether you are running a 32 bit or 64 bit version of Windows.
Where can I download the latest Service Pack for Windows?
For Windows XP, click on the following link to download Service Pack 3
For Windows XP Service Pack 3 info, click below :-
http://windows.microsoft.com/en-us/windows/help/learn-how-to-install-windows-xp-service-pack-3-sp3
For Windows XP Service Pack 3 download, click below :-
http://www.microsoft.com/downloads/details.aspx?FamilyId=5B33B5A8-5E76-401F-BE08-1E1555D4F3D4
For Windows Vista, click on the following link to download Service Pack 2
Windows Vista Service Pack 2 info, click below :-
http://windows.microsoft.com/en-us/windows-vista/Learn-how-to-install-Windows-Vista-Service-Pack-2-SP2
Windows Vista Service Pack 2 download, click below :-
http://support.microsoft.com/kb/935791
on Oct 04, 2010 | Computers & Internet
Tip
How to obtain the latest Windows Vista service pack?
Introduction:
Windows Vista updates are distributed in service packs. Service packs
help keep Windows Vista current, and they can extend and update the
functionality of your computer. This article describes three
step-by-step methods that you can use to obtain the latest service
pack for Windows Vista. However, before you select the method that you
want to use, please make sure that the following conditions are true:
The service pack is not already installed on your computer.
You are logged on to your computer by using a user account that is a
computer administrator.
The computer on which you want to install the service pack is
connected to the Internet.
If you are not sure that all these conditions are true, please see the
"Before you try to download the latest Windows Vista service pack"
section. Otherwise, select the method that you want to use to download
and install the service pack.
Methods to download the latest service pack
Method 1: Turn on Automatic Updates (Recommended for most users)
Method 2: Check for updates on Windows Update (Same as Method 1 but
not automatic)
Method 3: Obtain the latest Windows Vista service pack from the
Microsoft Download Center (Good to use if the computer on which you
want to install the service pack is not connected to the Internet)
Important: Windows Update may not offer the latest Windows Vista
service pack to some users. This issue can occur for several reasons.
For a full list of causes and resolutions, click the following article
number to view the article in the Microsoft Knowledge Base:
948343 Windows Vista service packs are not available for installation
from Windows Update and are not offered by Automatic Updates
on Mar 28, 2010 | Computers & Internet
Says my system does not meet requirements . Cannot download . Running Windows Vista with Service Pack 1
You need to install Vista Service Pack 2 Minimum System Requirements:
  • Microsoft® Windows 7 Home Premium (32- or 64-bit), Microsoft® Windows Vista™ Home Basic SP2, Windows® XP SP3 (32-bit) or SP2 (64-bit), 1 GHz processor and 512 MB RAM
  • 1024x768 DirectX 9.0c compatible graphics card with at least 16-bit color setting, sound card, DVD-ROM drive
  • 2 GB free hard drive space for installation
  • Windows Media Player 10 or higher
  • CD Writer for audio CD and DVD Writer for DVD
  • Internet Explorer 7 and 8
  • QuickTime player version 7.6 for some functionality
  • One available USB 2.0 port
Mar 01, 2011 | Roxio Easy VHS to DVD for PC
Vista error codes 643 and 646
the error codes that you have mention is related to windows update of Microsoft .net framework.
To troubleshoot this issue, I suggest we first perform these steps:
Step 1: Download Microsoft Windows Installer CleanUp utility
1. Visit:
http://download.microsoft.com/downlo...BD/msicuu2.exe
2. Save the file to your computer.
3. Right click "msicuu2.exe", click "Run as administrator" and follow the
wizard to install this tool on your computer.
Step 2: Remove .NET Framework
1. Click Start ->All Programs->Windows Installer Clean Up, click Allow.
2. See if you can find .Net Framework software. If so, remove them.
After that, please restart the computer and perform the following
suggestions to reinstall .NET framework 1.1 and the updates for it.
Step 3: Install .NET Framework 1.1 Redistributable Package and related updates
1. Please download the Microsoft .NET Framework Version 1.1 Redistributable
Package from the following link and save it to the C drive (C:\)
1) Microsoft .NET Framework Version 1.1 Redistributable Package
http://download.microsoft.com/downlo...6/dotnetfx.exe
2) Microsoft .NET Framework 1.1 Service Pack 1
http://download.microsoft.com/downlo...867460-X86.exe
3) Security Update for Microsoft .NET Framework, Version 1.1 Service Pack 1
(KB928366)
http://www.download.windowsupdate.co...d81a178b15.exe
4) .NET Framework 1.1 Service Pack 1 SYSTEM.WEB.DLL and MSCOREE.DLL Security
Update for Windows Vista (KB929729)
http://download.microsoft.com/downlo...929729-X86.exe
Please follow the steps above and if still problem persist please lets us know
Regards,
Om
Oct 20, 2009 | Computers & Internet
I have word2000 and i want to open a word 2oo7 document how can i
Download this tools for Microsoft:
http://www.microsoft.com/downloads/details.aspx?familyid=941b3470-3ae9-4aee-8f43-c6bb74cd1466&displaylang=en
Please note that:
Overview Users of the Microsoft Office XP and 2003 programs Word, Excel, or PowerPoint—please install all High-Priority updates from Microsoft Update before downloading the Compatibility Pack.
By installing the Compatibility Pack in addition to Microsoft Office2000, Office XP, or Office 2003, you will be able to open, edit, andsave files using the file formats new to Word, Excel, and PowerPoint 2007.The Compatibility Pack can also be used in conjunction with theMicrosoft Office Word Viewer 2003, Excel Viewer 2003, and PowerPointViewer 2003 to view files saved in these new formats. For moreinformation about the Compatibility Pack, see Knowledge Base article 924074.
Note: If you use Microsoft Word 2000 or Microsoft Word 2002 to read or write documents containing complex scripts, please see http://support.microsoft.com/kb/925451 for information to enable Word 2007 documents to be displayed correctly in your version of Word.
Administrators: The administrative template for the Word, Excel, and PowerPoint converters contained within the Compatibility Pack is available for download.
Update: The Microsoft Office Compatibility Pack Service Pack 1 (SP1) is available here.
arrow_px_up.gif Top of page
System Requirements
  • Supported Operating Systems: Windows 2000 Service Pack 4; Windows Server 2003; Windows Vista; Windows XP Service Pack 1; Windows XP Service Pack 2
  • Recommended Microsoft Office programs:
    • Microsoft Word 2000 with Service Pack 3, Microsoft Excel 2000with Service Pack 3, and Microsoft PowerPoint 2000 with Service Pack 3
    • Microsoft Word 2002 with Service Pack 3, Microsoft Excel 2002 withService Pack 3, and Microsoft PowerPoint 2002 with Service Pack 3
    • Microsoft Office Word 2003 with at least Service Pack 1, MicrosoftOffice Excel 2003 with at least Service Pack 1, and Microsoft OfficePowerPoint 2003 with at least Service Pack 1
    • Microsoft Office Word Viewer 2003
    • Microsoft Office Excel Viewer 2003
    • Microsoft Office PowerPoint Viewer 2003
InstructionsTo install this download:
  1. Ensure your system is up to date by installing all High-Priority/Required updates on Microsoft Update (required for Microsoft Office XP and 2003 users).
  2. After installing all High-Priority/Required updates with Microsoft Update, download the Compatibility Pack by clicking the Download button above and saving the file to your hard disk.
  3. Double-click the FileFormatConverters.exe program file on your hard disk to start the setup program.
  4. Follow the instructions on the screen to complete the installation.
To remove this download:
  1. On the Windows Start menu, click Control Panel.
  2. Select Add/Remove Programs.
  3. In the list of currently installed programs, select Compatibility Pack for the 2007 Office system and then click Remove or Add/Remove. If a dialog box appears, follow the instructions to remove the program.
  4. Click Yes or OK to confirm that you want to remove the program.
P.S.: If this information was helpful, please rate this solution.
Mar 23, 2009 | Microsoft Office Professional 2007 Full...
How do I get my Acer 5500 to boot from my uTorrent recovery disc?
Do you have your original recovery media for Vista? Sounds like you're going to have to repair the installation.
Dec 27, 2008 | Microsoft Windows Vista Home Premium with...
Cannot get out of Configurating updates: stage 3 of 3 screen
This is all I could find:
It's not only Windows Vista Service Pack 1 that isn't ready for general consumer availability. Some of the updates released on February 12, 2008, as a part of the Microsoft monthly patch cycle, have managed to effectively kill Windows Vista. Users are reporting that, following the introduction of the February 12 updates, Vista gets stuck at the finalization of the deployment of the updates displaying the message "Configuring Updates Stage 3 of 3 0% completes" and then entering
an infinite reboot loop. And there is absolutely no way out for the end users, because canceling the configuration process of the updates is a move equivalent to losing access to the operating system entirely. This will even happen in Safe Mode.
Microsoft has yet to officially respond to the issue, or to provide a resolve or at least a workaround. However, it does seem at this point that there is an issue with the deployment of the pre-requisite updates necessary for the smooth installation of Windows Vista SP1. Namely, the problem resides in the Vista installation software. The fact of the matter is that end users will have to first update the Vista installation software and only then deploy the remaining February 12 updates and only at the end Vista SP1 RTM.
If you are stuck watching the "Configuring Updates Stage 3 of 3 0% complete Do not turn off Computer" and in the endless reboot loop, then stop the cycle and boot from the Vista media. You will need to "Repair your computer," so select your Vista installation and restore it to a point before the deployment of the updates. After gaining back access to your operating system, you will have to install the service stack update, namely Update for Windows Vista (KB937287). Deploy this update before any other on your Vista, and only then install the rest. At this point in time, you should experience no more problems.
"Update 937287 is a prerequisite package that contains updates to the Windows Vista installation software. The installation software is the component that handles the installation and the removal of software updates, language packs, optional Windows features, and service packs. Update 937287 is necessary to successfully install and to remove Windows Vista SP1 on all versions of Windows Vista," Microsoft revealed.
Dec 18, 2008 | Lenovo IdeaPad Y510 - Intel Core 2 Duo...
Acer Aspire 5630
Seems like your VISTA upgrade didn't sucessfully upgrade itself from XP to VISTA. Seems like M$ update program detects your OS as XP and tries to install the SP3 for XP. VISTA only has SP1 released. Its currently stuck in a loop that it doesn't know what to do. Restart your laptop into safe mode by pressing F8 before the VISTA loading page comes up and go to Safe mode and backup your data and use the ACER RESTORE CD OR ACER RESTORE METHOD to help you reload your system back to factory defaults then upgrade back to vista without install any updates or connecting it to the internet.
This is my best solution to get you out of this weird and unusual situation.
Jun 30, 2008 | Acer Ferrari 4000 Notebook
HP 530 Notebook PC Logo
176 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
