Question about HP Deskjet 3845 InkJet Printer
Hp 3845 does not print
The 3845 has electrical power, power on, letter size paper, and ink.
  • 700 Answers
Does the pc knoe =w that the printer is online? also check to see if it is set up to spool the print job untill all has been sent to the printer and if the box is checked that says "print off Line" You can checkout all of these settings with the digital imageing center utility
Posted on Dec 23, 2008
    President:
  • 2,110 Answers
Http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&dlc=en&cc=us&product=372330&
HAVE U INSTALLED THE LATEST DRIVER IF NOT DOWNLOAD FROM ABOVE LINK...
  • Sibananda Jena
    Sibananda Jena Dec 23, 2008
    Verify the following conditions
    • Printer is connected to the power source.
    • Cable connections are secure.
    • Printer is turned on.
    • Print cartridges are correctly installed.
    • Paper or other media is correctly loaded in the In tray.
    • Printer cover is closed.
    • Rear access door is attached.
    Check the printer cable connection
    If the printer cable is attached to a USB hub, a printing conflict might exist. Use one
    of these methods for solving the conflict:
    • Attach the printer USB cable directly to your computer.
    • When printing, do not use other USB devices that are attached to the hub.
    If the printer does not turn on
    The printer might have drawn too much power.
    1. Disconnect the power cord from the electrical outlet.
    HP Deskjet 3840 series printer
    73
    2. Wait approximately 10 seconds.
    3. Reconnect the power cord.
    4. Press the Power button to turn on the printer.
    If the printer still does not turn on, try the following solutions:
    • Plug the printer into a different electrical outlet.
    • Plug the printer directly into an electrical outlet rather than into a surge
    protector.
    If the printer still does not print
    Select the topic below that best describes the problem:
    • Paper jam
    • Out-of-paper message
    10.2 Paper jam
    Follow each of these steps until the paper jam is cleared.
    1. Press the Power button to turn off the printer.
    2. Disconnect the power cable and the USB cable from the rear of the printer.
    3. Remove the paper from the In tray.
    4. If you are printing labels, verify that a label did not become detached from the
    label sheet while passing through the printer.
    5. Remove the rear access door. Press the handle to the right, and then pull out
    the door.
    6. Remove the paper jam from the back of the printer, and then replace the rear
    access door.
    74
    7. Reload paper in the In tray.
    8. Reconnect the power cord and USB cable.
    9. Press the Power button to turn on the printer.
    10. Reprint the document.
    10.3 Paper problems
    Printer prints on multiple sheets at once
    Paper weight
    The printer might print on multiple sheets of paper at once if the paper is under the
    recommended paper weight. Use paper that meets the recommended paper weight.
    For paper weight specifications, see the reference guide that came with the printer.
    Paper is loaded improperly
    The printer might print on multiple sheets of paper at once if the paper is loaded too
    far toward the back of the printer. Reload paper into the paper tray, pushing the
    paper until you feel resistance.
    The printer also might print on multiple sheets if different paper types are loaded in
    the printer. For example, photo paper might be mixed with plain paper. Empty the
    paper tray and load only the paper type that is appropriate for the document that
    you are printing.
    Other paper problems
    • For information about clearing a paper jam, see the paper jam page.
    • If an out-of-paper message appears, see the error messages page.
  • Sibananda Jena
    Genius:
  • 3,422 Answers
HI,
Please reinstall your printer drivers.Also reset your printer by unplugging all the cords of the printer for 30min and then plugging them back in after 30min.
My hp office jet all in one printer is only displaying error ,when i turn it on
HP Officejet J4580 All-in-One Printer Troubleshooting ' HP ...
support.hp.com/us.../HP-Officejet...All-in-One-Printer.../troubleshooting/
Let HP find my products ... Note: This tool can only find HP products you are currently using or ... Error · Printer Problems after Upgrading to Windows 10 · A 'Paper Jam' Message Displays for HP Officejet J4500/J4600 All-in-One Printer Series ... PrinterSpecifications for HP Officejet J4500 and J4600 All-in-One Printer Series ...
A 'Paper Jam' Error Displays on the HP Officejet 4215 a
Dec 18, 2015 | HP Office Equipment & Supplies
Hp deskjet 3845 printer will not print and it is no paper jammed, it is installed properly
it sounds like your printer is not connected to the pc or laptop,check the USB cable properly.another problem is paper jam or which leads to qeueing of docs to be printed.
Mar 01, 2013 | HP Deskjet 3845 InkJet Printer
Cannot print on regular letter size paper on my HP Officejet 6500A Plus printer. Gives me an error message saying Paper Size Mismatch, but it is the right paper for the print job.
I had same problem. Try this: When you go to print, change your ink quality to "draft". For some reason, I was able to print after trying everything. Hope this works for you!
Jan 26, 2011 | HP Officejet 6500 Wireless All-in-One...
Printer des not print
does PC recognize it as a printer?
the cable may be loose, or driver needs updating.
Dec 23, 2008 | HP Deskjet 3845 InkJet Printer
HP Deskjet 3845 will print the web page, but wehn I try to print a short word document it feeds a sheet through, but prints nothing
plz try by reloading the printer driver and check if you have correct paper size selected in the printer.
Dec 05, 2008 | HP Deskjet 3845 InkJet Printer
My HP Deskjet F2100 All-in-one printer/scanner will not print a photo which is only post card size at less than A4 size when I use photo paper. It prints the correct size when I use plain paper.
just leave your paper type as Plain Paper,
and if your printing out a 5R size photo or photo sizes not exceed on Letter size paper, just leave the paper sizes using Letter,
print on both sides set as OFF.
then just customize the printing quality for a good printing result.
then load or place your photo paper properly on the paper tray to avoid jam.
Aug 24, 2008 | HP Office Equipment & Supplies
Printing
more information is needed to solve your problem
1.what kind of printer?
2.Do you have it hooked up to your pc and have power?
3.are you getting an error message?
thank you
Jan 08, 2008 | HP DeskJet F380 All-In-One Printer
Printing on Stationary with an HP Laser Jet 1320
Most printers and copiers are made for the standard 20# paper, if using a different paper then most of the time you need to specify what type ie: transparency, labels, lbs etc. so the machine can accommodate itself. ( lowering or increasing the heat in the fusing section, and pressure on the paper.)
for that machine everything is done through the pc. go to File, Print, right click on the printer, go to properties got to device settings, General, printing preferences and paper quality, there is a box there for paper options. try setting it to cardstock.
Oct 04, 2007 | HP LaserJet 1320n Printer
Deskjet 3845 not printing properly
it needs a proper service as the moving parts are not moving freely .. or maybe when installing the cartridge you have damagaed one of the sensors .. it can be one of both
Jun 25, 2007 | HP Deskjet 3845 InkJet Printer
HP Deskjet 3845 InkJet Printer Logo
16 people viewed this question
Ben Johnson
