Question about Hoover Company Wind Tunnel U53019 Upright Vacuum
Problem with vacuum suction in upright position
My the roller bar does not rotate and loss suction on my Hoover Wind tunnel unless the handle is held nearly parallel to the ground. Both belts are good and the roller is free of hair and other debris. What could be the problem?
  • Anonymous Mar 19, 2014
    is shooting out dust particles
Move the lever on the front of the machine to "carpet". It won't agitate on floor
Posted on Apr 26, 2007
My hoover wind tunnel just quit while vacuuming. It is dead??? Two years old used about every other week? Any suggestions?
Some Wind Tunnels by Hoover have a poor design in the switch on the handle. Sometimes the switch does not turn on all the way and will stop running. Other times you can't turn the unit off.
Feb 28, 2015 | Hoover Self-Propelled WindTunnel Bagless...
Agitator bar on UH4700RM wind tunnel doesn't turn
Unfortunately you machine is a re manufactured vacuum and has a 6 month warranty. (The RM suffix indicates this ) You should take it to your local vac shop and let them look at it. It's probably a minor issue.
Aug 08, 2017 | Hoover U6630-900 WindTunnel Bagless...
I replaced my belts on my premium hoover wind tunnel and the roller barely moves. Also, I keep getting a rubber burning smell. I'm confused weather if it's worth to have fixed or buy new.
More then likely whats going on with your roller is on each side of the roller is bearings and hair or other things build up and makes it really hard to rotate.Take the roller off the vacuum and check you may be able to clean and oil them.
Jun 22, 2011 | Hoover Premium U45900 WindTunnel Bagged...
My new Hoover Wind Tunnel Upright UH50000 will not turn off unless I unplug it.
First I would be sure the handle was properly installed. Remove the two screws holding the upper handle in place and tap it bacwards to remove it. Set the switch inside to the OFF position. Next set both buttons on the handle to the OFF position and re-install the upper handle. If the switch still does not turn the vacuum on and off, the switch will need replacement.
Apr 01, 2011 | Hoover U6630-900 WindTunnel Bagless...
How do you change the Hoover wind tunnel belts?
If you turn the vacuum over there will be (4) screws that hold on the base cover for the roller brush. Remove the screws and the cover and you can get to the belt(s). You can get replacement belts here:
Hoover Windtunnel Belts
Nov 18, 2009 | Hoover Company Wind Tunnel U53019 Upright...
My wind tunnelhas no suction when using the beater brush. Something is stuck. Can I fix it?
If the hose has suction in the upright position, and the floor has no suction in the normal use position, check for obstruction in the dirt path from the agitator cavity, thru the short hose, into the lower handle.
Oct 03, 2009 | Hoover U5753-900 WindTunnel Bagless...
Hoover Company Wind Tunnel U53019 Upright Vacuum Logo
384 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Kirk Thompson
Level 1 Expert
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
