Question about Apple iBook G3 Mac Notebook
Powerbook g3 will only power up for a few seconds then shut off, charger was bought on ebay as well as the computer, computer has no hard drive and only 32m of memory
  • 368 Answers
Hi Alienlogic,
As noted in my other response to your other posting, more information is useful.
The computer isn't going to boot-up normally with no hard drive.
You might try target booting if you happen to have another bootable drive you can connect with (like a FireWire drive with the OS installed, or if you're trying to boot from an install CD, or Netbooting to a server).
Having only 32Mb RAM doesn't help, but in this case, your computer really has nothing to boot-up. Get yourself a hard drive you can use, or one of the options I mentioned above.
If I can be of further assistance, let me know. If this helps or solves the issue, please rate it accordingly.
Thanks in-advance,
Jon
Posted on Dec 24, 2008
When laptop start window 10 boot screen come up and during the process after 15-20 seconds since the laptop was powered on the laptop get shut down.
hi there.
Laptop performance slowing down, or the laptop isshutting off completely because the laptop is trying to protect itself from damage caused by an excessive heat build-up. ... There are times when a laptop will turn offbecause of a virus or malware, hardware or software problems/conflicts as well.2 Nov 2013
Don't panic!... Is your "laptop shutting off by itself" or "slowing down ...
https://www.youtube.com/watch?v=74agkgZdzkI
What is the problem if laptop shuts down automatically?If removing air doesn't fix shutdown issue, it is a faulty hardware (can be anything), related to overheating or serious power related failure, such as bad battery or adapter. Overheat issue will result in unit turning on, but shuts down after about the same time (i.e. 15 sec).29 Jun 2015My Laptop automatic shutdown in few seconds - Laptops - Laptop ...
What would cause a computer to keep shutting down?An overheating power supply, due to a malfunctioning fan, can cause a computer toshut off unexpectedly. Continuing to use the faulty power supply can result in damage to the computer and should be replaced immediately. ... Software utilities such as SpeedFan can also be used to help monitor fans in your computer.5 May 2017Computer turns off without warning - Computer Hope
How do I get my computer to stop shutting down?Cancel System Shutdown or Restart. You cannot cancel a restart or shutdown using the Shutdown Event Tracker Windows interface. It is only possible to perform this task from the command line. To cancel or abort system shutdown or restart, open Command Prompt, type shutdown /a within the time-out period and hit Enter.1 Apr 2013Stop, Cancel, Prevent, Abort System Shutdown in Windows 10/8/7www.thewindowsclub.com/abort-system-shutdown-windowsSearch for: How do I get my computer to stop shutting down?
or go to this link to find out more.
Laptop keeps shutting off after few minutes
Nov 19, 2017 | HIS Computers & Internet
Reset button on a powerbook g4
The Powerbook G4 power button functions like a reset button if you hold the power button in for a few seconds until the computer powers down.
  1. Hold the power button in for a few seconds (until you see the screen turn off/go black and hear the fans & hard drive stop spinning).
  2. Press the power button again to turn your computer on.
  3. If you have more trouble, you may need to boot in Safe Mode or "perform a Safe Boot":
    Press and hold down the "Shift" key immediately after you hear the start-up tone. Release the "Shift" key when the gray Apple icon appears on the screen.
May 02, 2014 | Apple 15" PowerBook G4 Aluminum 1.67 GHz...
I need one charger to my laptop M-4753
Have a look at http://www.applemacparts.co.uk/store/powerbook-wallstreet-233mhz-512-m4753-c-7405_7433_7457_7892.html the code for the charger is 922-2568 do a search on google to for this code and then click on shopping and you should be able to source one from where you are located. Hope this helps.
Dec 28, 2011 | Apple PowerBook G3 M4753 Laptop Charger...
Usb not recognized on macintosh powerbook g3
The Powerbook G3 will be using the original USB architecture and I suspect that your flash drives are using USB 2 and are not backwards compatible, so sorry I don't really think it is possible.
Dec 16, 2011 | Apple PowerBook G3 Mac Notebook
My system doesn;t boot up and I don't have the CD to boot up my system. When I brought the powerbook G3 it didn't with the CD. Please where can I get it from? I am in Ghana now. Thanks Ishmael
If you have another Macintosh that is working correctly, you can copy the contents of that hard-drive, including the Operating System onto an external hard drive.
To do this, install Carbon Copy Cloner on the working machine and plug in an external hard-drive. Then run Carbon copy cloner and make the source the computer's hard drive most likely named "Macintosh HD". Then choose to have your external hard drive be the drive where all of the data is copied. Then run the program and let it copy all of the files.
Once this is done, remove the external drive from the computer and plug it into your G3. Turn on your G3 while holding the Option (alt) key and then double click on the hard-drive image that is named whatever your external hard-drive is named.
Once your system boots up from the external hard drive, run Carbon Copy Cloner again and repeat the process again except have the source be your external drive and have the internal drive in your G3 be the disk that has all the data copied to it. Once this is done, turn off your computer, remove the external drive, and then boot up your computer again.
You will have an exact clone of the computer that you copied the data from and will just simply need to adjust the account settings as such as you see fit.
The external drive process can be skipped if you have a firewire cable. Simply connect the firewire cable to both computers and when you turn on your G3, hold the "T" key. This will turn your G3 into an external hard drive and you just have to carbon copy the files straight to your computer's internal hard drive.
If you do not have access to another computer mac computer, then you will need to go to the Apple Store and see if the Genius Bar can install the default operating system that your computer came with.
If for some odd reason you have the contents of an Mac OS install disc copied onto a flash drive or external hard drive, you can boot from that and use it in place of a disc.
Apr 15, 2011 | Apple PowerBook G3 Mac Notebook
Powerbook G4 12" no video
Try this courtesy of your manufacturer
  1. If the computer is on, turn it off.
  2. Reset the power manager by simultaneously pressing and then releasing Shift-Control-Option-Power on the keyboard. Do not press the fn (Function) key while using this combination of keystrokes.
  3. Wait 5 seconds.
  4. Press the Power button to restart the computer.
If that doesnt work lemme know
Feb 03, 2010 | Apple PowerBook G4 Mac Notebook
Apple Mac PowerBook G3 M5343
since apple drives are formatted in HSF+, a file system that windows cannon read, the chances of it even being bossible to run anything on it from a PC is very very slim.
Jan 18, 2010 | Apple PowerBook G3 Mac Notebook
Apple Macintosh PowerBook G3 Start-up problem
Your mac doesn't recognize the system folder. Try to find the original boot disks that came with the machine, and see if you can mount the hard disk while booting from the CDs. If you can, I'd backup the data as soon as possible and reinstall the operating system, including a full hard drive reformat. If you can't see the hard drive from the boot cd, another option is to hold down the T key during startup to boot the mac into "target disk mode" - this will allow you to hook up the g3 to another computer as an external hard disk in order to back up the data.
Oct 21, 2009 | Apple PowerBook G3 Mac Notebook
I have a Powerbook G3. Gets power but does not boot up.
It may not be a fan, it may be the cd drive spinning up. Is there a cd in it?
Jul 18, 2009 | Apple PowerBook G3 266Mhz w/ 14.1" Screen...
Powerbook g3 will power up for 4 sec. then shut off
Hi Alienlogic,
Several points here:
1) More info as to make/model, and type of powercord would have been helpful.
2) From your description above, it sounds like you have a faulty connection in the laptop's DC/Sound card (the small circuit board that the power cord plugs in to). You can sometimes get a temporary workaround by rigging a way to apply gentle pressure on the plug to keep it connected, say with a rubber band or the like, but the only real fix is to have the board fixed or replaced. Sooner or later, the workaround - won't any more.
3) With most iBooks and Powerbooks I've worked on, this involves nearly complete dis-assembly of the computer, and you have to find a working part, or be handy enough with a soldering gun and lucky enough to have a break that you can fix yourself.
4) Parts are for-sale on eBay, or from other parts resellers on the web.
Thanks in-advance,
Jon
Dec 23, 2008 | Apple iBook G3 Mac Notebook
Apple iBook G3 Mac Notebook Logo
61 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
