Question about Philips 55PW9363 55" Rear Projection HDTV-Ready Television
Philips 60PP9202 Color Problem
Hi, my dad has this tv and had the converg chips changed about 6 months ago. The tech said son it would need color tubes filled cause it they be getting cloudy. Is that something I can do or replace myself. Were can I find those parts. He said it was 375 dollars to refill the tubes. I want to change the tubes if possible and mke the picture like new?? please help if you can
  • Philips Master
  • 8,617 Answers
Go to the following link and under the repair kit category you will see the phgillkips CRT coolant replacement kit which contains the proper amount and type coolant and includes a cd with the step by step instructions. Heres the link.
http://servicemanuals.vstore.ca/
Posted on Dec 28, 2008
I have a Zenith approximately 8 years old. The color is not aligned and the convergence/alignment feature on the remote control seems to do nothing. Can a service tech do an in home alignment?
Your TV most likely has one of two possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc
Dec 22, 2010 | Zenith R50V26 50" Rear Projection...
Sony 51" projection tv standby light blinks 6
  • Screen looks 3D
Dec 15, 2010 | Sony KP-51WS520 51" Rear Projection...
Toshiba Rear Projection TV picture color is now a greenish hue
Hi, I used to work in Best Buy and one of the key things about rear projection TVs and the reason they push those service plans on you is that the tubes/colors need to be calibrated each year. You can do this yourself by checking out the following website:
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=3229
If you are not able to adjust the convergence using the remote you will need to replace the convergence chips.
Typical Symptoms
1) Convergence menu does not work for one or more colors.
Such as: Red moves up,down, but left or right fails.
2) Screen is bowed looking.
If you have one or more of the problems above you need to replace the convergence chips. You can get a kit and instructions from www.TvRepairKits.com
Hope this helps :)
Sep 12, 2009 | Toshiba 50H82 50" Rear Projection...
55" Hitachi colr Red has dropped to the bottom right
Your TV most likely has one or more possible problems.
  • Screen looks 3D
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
May 03, 2009 | Hitachi 50UX57B 50" Rear Projection...
The blue color sags in regular tv but is fine in hd
  • Screen looks 3D
Apr 06, 2009 | Akai PT4298HD Rear Projection Television
Picture bowing from top and bottom to the center
  • Screen looks 3D
Mar 29, 2009 | Zenith Televison & Video
Couldy image
Problem #1 - Failure in the convergence circuits. ( common problem )
  • Screen looks 3D
Here are some photos of convergence problems.
0667c5f.pngSOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses. Its a fairly easy DIY job or you can call in a pro. If you want to do the repair yourself check the site www.TvRepairKits.com. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, email/phone support, etc.
Picture of a set that needs the fluid changed. Notice how dull the colors are and how white the screen looks. The screen may also look red, orange, dull, etc.
TV set after fluid change. Notice how bright the colors are now. Everthing looks crisp and sharp again.
Mar 14, 2009 | Philips 46PP9302 46" Rear Projection...
ALOT OF BLUE ON THE SCREEN!!
  • Screen looks 3D
Aug 20, 2008 | Philips 60PP9200D Television
The color keeps going out
The repair tech used cheap parts or did not replace both convergence chips.
  • Screen looks 3D
Nov 12, 2007 | Sony KP-53V80 53" Rear Projection...
Bent picture
The convergence circuits straighten out the edges of the picture, putting the 3 colors exactly where they should be for the picture to look normal. There are usually 2 large IC's that handle the 6 convergence channels and if one of them burns out then one of the colors bends dramatically. If the power supply for the convergence circuits stops working, then all 3 colors bend in, the colors do not line up with each other and the image looks almost 3D, and the adjustments in the convergence menu will have no effect. I would bet that is the case with your set - the convergence power supply has quit working. If you do not have experience troubleshooting power supplies and realigning convergence circuits in projection TV's then allow a qualified tech to handle it for you.
Aug 07, 2007 | Philips 51PP9910 51" Rear Projection HDTV
Philips 55PW9363 55" Rear Projection HDTV-Ready Television Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
