Question about AOpen AX4SPE-UN Motherboard
There is a red light glowing on my motherboard
At first the usb didnt respond... all four of them.. then there was no video input at the screen and at last there was a a red light glowing on my motherboard.. What that light means...? May i with the power supply of my pc...?
Red light always glows on mine.
Posted on May 20, 2009
Give me sound dirivers of ibm thinkpad R50
Posted on Dec 23, 2008
Red light flashes blank screen
I have the same problem on 2 of my IP's - did you manage to sort it out?
Mar 27, 2013 | Saitek Pro Flight Instrument Panel...
No luminance
poor very dark is sighn of bad bulb ok after 3000 hours they get dark they wont die just get darker in darker like what going on now and have stuff looks like red nasty get new bulb ok
Feb 10, 2008 | Mitsubishi WD62627 62" HDTV
Acer laptop switched on light up on switch but no screen display
A blacked-out screen doesn't necessarily indicate a broken monitor. If the computer has run out of charge or is in hibernation or sleep mode,
if the screen is too dark, or if the display cable has come disconnected from the motherboard, the screen may appear black or fail to turn on.
To fix a blacked-out laptop screen, troubleshoot the screen settings, check the LCD connector and see if the computer is awake and receiving power.
Touch the touchpad or move the external mouse to see if the computer is asleep or hibernating. If the computer fails to respond, press "Enter" on the keyboard.
Press the power button if the screen remains black. Confirm that the power indicator light, found at the front of the computer or above the keyboard, is glowing solid green or blue.
Confirm that the power adapter is plugged into the computer and into a wall outlet. Confirm that battery indicator light is glowing solid green or blue.
Hold down the "Fn" key. Press the up-arrow to see if the screen brightness increases. Some computers also use the "F6" or "F7" keys to increase screen brightness.
Hold down the power button for 10 seconds to turn off the laptop. Remove the AC adapter from the computer, close the screen, and then turn the PC over.
Slide the battery latch to eject the battery. Pull the battery out of its compartment.
Turn the computer back over, open the lid, and insert the edge of a flathead screwdriver or other flat, solid object beneath the bezel above the keyboard.
Wedge the edge of the keyboard bezel off of the top cover. Work your way along the edge of the keyboard bezel to loosen it. Pull the bezel off the laptop.
Trace the cable coming from the laptop screen to the connector found beneath the bezel. Reconnect the display cable to the motherboard if the cable has come loose from the connector.
Line up the tabs on the bezel with the slots along the top of the keyboard. Insert the right edge of the bezel into the gap above the keyboard, and then push the bezel back in place.
Turn the computer back on. If the laptop screen is still blacked out, connect an external monitor to the video port on the side of the PC to confirm that the video card isn't defective. If the external monitor works, the LCD screen could be broken.
If the monitor doesn't work, the motherboard or video card might need to be replaced.
hope this helps
Hope this helps
Nov 24, 2012 | MSI P45 Neo3-FR (MS-7514-010) Motherboard
I have a jazz hdv188 i just bought from a friend who didnt have a charger and i have a motorolla phone charger, the charger turns the light on to red blinks for a few seconds then shines red continually, I...
according to the manual guide, you cannot use another recharging, only the recharge that came with the camera, because you can get a problem on the screen.
you have to use this ADAPTER>
Sunny* SWITCHING ADAPTER
MODEL: SYS1196-0605-W2
PART NO: SYS1196-0505-W2-C
INPUT: 100-240V-0.3A MAX 50-60Hz
OUTPUT: +5V_-_1.0A
OUTPUT POWER: 5W MAX.
Nov 13, 2010 | Jazz HDV-188 Camcorder
My ps3 screen wont show when i turn the ps3 on.
  1. Make sure the HDMI cable is connected to the HDMI OUT port on the back of the PLAYSTATION 3 system. Connect the other end of the HDMI cable into the HDMI Input port of the TV or display monitor.
  2. While the PLAYSTATION 3 system is in standby mode (red light on the front of the system), hold down the touch-sensitive power button on the front of the system until the system goes into standby mode again . (So the light cycle would go from: red light --> green light --> then back to red light). This will ensure that you have held down the power button long enough to reset the Video Output Settings.
  3. Turn on the PLAYSTATION 3 system and once the system finishes powering up, the Video Output Settings will automatically reset to the standard resolution (or detect the current display output settings of your TV/monitor).
Jun 28, 2010 | Sony PlayStation 3 40GB System
PS/2 to USB adapter Issue
go to Control panel, click on your mouse icon and set the settings for your mouse
Jan 22, 2009 | Foxconn 6100K8MA-RS Motherboard
Screen goes completely out.
when it blanks out, tuen the lights out in the room, and shine a flash light at the screen, see if you can see the picture, if you can, it is the inverter moard blamking out, thats the board that lights the back lights, if you cant, hit the input button on the remote, if the TV comes back with a picture, it is a problem with the main board, in paticular the componant input on the main board
Jan 10, 2009 | Samsung LN-R268W 26 in. HD-Ready LCD...
Red light flashes and system not responding
Erratic power supply, at least hope its just that and not a burnt CPU thats keeping it from posting.
Sep 28, 2008 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
Xbox 360 Video Problems
try using another input " a/v input on your tv " thos inputs may be fried.
May 24, 2008 | Microsoft Xbox 360 Console
AOpen AX4SPE-UN Motherboard Logo
880 people viewed this question
Top AOpen Computers & Internet Experts
Alun Cox
Jim Goldsmith
Jim Goldsmith
Are you an AOpen Computer and Internet Expert? Answer questions, earn points and help others
