Question about Wharfedale DVD-M3 DVD Player
With warfedale 256
I have a warfedale dvd 265.
I was just wandering if you can download from a computer to the dvd using a USB cable.
    Genius:
  • 1,199 Answers
NO! But you can upload yo the computer!
Please rate are answers and help keep this site free
Thank You
Posted on Dec 23, 2008
Ca I get an upgraded software for my Warfedale LP250DTRHDMI
That's indeed a common issue with the older firmware versions. Please refer to: http://chall32.blogspot.nl/2009/06/digihome-dtr160-pvr-personal-video.html on howto get ahold of a newer firmware and flash it. Good luck !
Jun 27, 2014 | Wharfedale DVD-M3 DVD Player
Garmin 265 wt is charging via USB cable.It will not connect to the garmin website.
The Garmin Communicator Plugin needs to be installed on your computer.
http://www8.garmin.com/products/communicator
Also check to be sure that the data cable is the correct one.
When connect between the nuvi and the computer, the nuvi should show that it is in mass storage mode by displaying a computer on the screen.
The correct cable is Garmin part number 010-10723-01.
http://www.gpscity.com/garmin-usb-pc-cable.html
Aug 18, 2011 | Garmin nuvi 265WT Car GPS Receiver
How to unlock maps on my Garmin 265 WT
With the unit Off........ connect your gps to your computer using a usb cable ( most cameras use the same usb cable )
your computer will detect new hardware (usb) a pop up box will appear you can minimise it
next
go to www.MyGarmin.com this site also will now have you Register your GPS
it then would tell you to download WebUpDater to transfer files to your gps
it will detect your model number and let you unlock maps
Nov 25, 2010 | Garmin GPS
How do i charge my 265 via computer
You charge it by using a Mini-USB to USB cable... Its the same USB cable most cameras use to connect to a computer
with the unit off plug in the USB to gps then to computer.....your computer will detect the new hardware (USB)
it will take a few hours to totally charge the gps this way
Nov 05, 2010 | Garmin n?vi 265WT Car GPS Receiver
Garmin nuvi 265 keeps shutting off
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Sounds like a bad or low battery. Do you have the Garmin approved charger / car charger?? You may have to send your 265 in for battery replacement or try this:
There are three ways to charge the internal battery in your automotive GPS unit.1
  1. Use the provided vehicle power cable that came with your GPS unit. The unit will charge while powered on and using the device as well as when the GPS unit is powered off and plugged into a running vehicle. About 3 hrs for a full charge. If the unit will not charge in the vehicle, check the fuse in the power cable for the unit and the power outlet in the vehicle.
  2. Use an AC power adaptor. Some units come with this power cable to plug the GPS unit into a wall outlet allowing the GPS unit to take a charge. For units that do not come with this cable, one can be purchased from Garmin's online store.
  3. For most units, the final way of charging the battery is to plug the GPS into a powered on computer with a USB cable2. This method of charging will be a trickle charge and it may take longer (like a full day) than the other two options, however it will still charge the battery. A USB cable is provided with a few GPS models. For those that don't come with this cable, one can either be ordered from the online store or you can use a standard USB to mini-USB cable that fits the unit and plugs into your computer.
1 - Please note that temperature can play an effect on the charging of a device. If the battery registers a temperature of 0°C and below or 45°C and above (32°F and 113°F respectively) then it will not charge. When connected to external power it will only be operating off of external power.
2 - The Quest® and Quest® 2 will not charge using a USB cable.
Dec 27, 2009 | Garmin Nuvi 265W GPS Receiver
How to fully charge nuvi 265 gps
The nuvi 265 comes with two cables. The auto cable will power it while you're driving, and charge it if you turn the unit off (slide the switch to the left to turn it off/on, or to the right to lock it in the off position). You can see the level of charge on the main page (especially when it's unplugged).
The other cable connects the nuvi to a USB port on your computer. In this mode, the nuvi will appear as a storage device, so you can download images and updated software/maps to it. It will also draw a charge from the USB cable.
Nov 14, 2009 | Garmin nuvi 265 Car GPS Receiver
Garmin Nuvi 265W just will not switch on!
Bad or very low battery
Replace at Garmin
But first know this:
Aug 06, 2009 | Garmin nuvi 265 Car GPS Receiver
I have lost my power cord to my LaCie DVD+RW Dual Layer....
Here is the PDF Users Manual for the LaCie DVD+RW 301230U
external optical drive,
http://www.lacie.com/download/manual/portable_dvd_sh_en.pdf
(Give it at least 10 seconds to download)
Should the direct link above not work for you, you can download the Users Manual from here,
http://www.generalmanual.com/Disc-Burners/LaCie-301230U-Portable-DVD-RW.htm
Go down to the bottom of the page, and under the green -> Download Now <- heading, click on -> User Manual
The reason I posted the link to the User Manual, is that you can use a USB to USB cable for power. You plug one end of the USB cable, into an available USB port on your computer, and the other end, into the LaCie DVD+RW external optical drive. (You need two available USB ports on your computer. One for power, and one to connect the LaCie external optical drive. This USB cable, is called an Interface cable)
The USB end, that goes into your computer, (Laptop or Desktop computer), is the USB A style end. (Male) This is what it looks like,
http://en.wikipedia.org/wiki/File:USB_TypeA_Plug.JPG
The USB end, that plugs into the Lacie optical burner drive, is a USB Mini-B style end. (Male) It looks like this,
http://en.wikipedia.org/wiki/File:USB_types_2.jpg
It is the second one from the left side.
Where I'm at, we have Walmart stores. At Walmart they sell a USB adapter kit, made by Philips. This kit has a USB A to USB A cable, that both ends are Male. This cable is on a little retractable reel. The reel is about the size of a USA fifty cent piece. In the kit are five different styles of USB adapter ends. They just plug on that USB A to USB A style cable. (On the small reel) One of those adapter ends is a Mini-B USB male end. It has a Female USB A socket on one side, and a Male USB MIni-B end, on the other side. The kit sells for about $12 dollars.
Should you find that somehow, this USB power cable does not give enough power to your LaCie external optical burner drive, then here is LaCie.com, Products, Support & Downloads, and the Power Supply, for your LaCie DVD+RW 301230U external optical drive,
http://www.lacie.com/us/products/product.htm?pid=10715
May 15, 2009 | LaCie (300776EK) DVD±RW Dual Layer...
Downloading to computer to burn to a dvd
I have a zr300. You need a firewire connection and a firewire cable to download the contents of your minidv tape for burning. You can not do that with a usb cable. USB cable can only download photos and videos from your memory card not from the tape.
Jan 09, 2008 | Canon ZR300 Mini DV Digital Camcorder
Saving Dv tape to computer? Getting computer to see camera?
The USB connection is for getting still images (photos) off the camcorder. To get moving images (video) off the camcorder, you must use a FireWire cable (IEEE 1394). The cable only costs about $15. But you need to have a FireWire port on your computer to plug it into -- if you don't have one, you'll have to install a FireWire card. Check someplace like TigerDirect computer parts supplier, they are only $15 to $60 now.
Or, if you don't want to open up your computer to install a FireWire card, you can buy a Pinnacle MovieBox for $120. It just sits next to your computer, not inside. It is very easy to use and comes with great video editing software. You plug the FireWire from your camcorder into the front of the MovieBox, then plug the back of the MovieBox into your computer with USB.
Plus, you can use the MovieBox to record from your VCR or DVD player into your computer! For that, you'll need the standard red/white/yellow cables.
In fact, if your camcorder has those cables, you can use them to go thru the MovieBox, and save yourself the cost of the FireWire cable. But I think FireWire will give better quality than the red/white/yellow cable.
Sep 25, 2006 | Canon ZR70MC Mini DV Digital Camcorder
Wharfedale DVD-M3 DVD Player Logo
Top Wharfedale Televison & Video Experts
Marvin
Marvin
Colin Stickland
Colin Stickland
Are you a Wharfedale Televison and Video Expert? Answer questions, earn points and help others
