Question about RCA D61W20 61" Rear Projection Television
3 green lights flashing on rca d61w20
First the sound went now the tv will not turn on. I only have one service professional in this area and he charges an outlandish rate just to come out to pick the tv up and diagnosis it. From what I read it indicates that it should be a capacitor. How do I know where the capacitor is located and how do I replace it?
  • RCA Master
  • 5,138 Answers
On Deflection board cp150 if it is puffed up on top it is bad ,3 capacitors cp114 cp120 they are green with gold writing on them But; if cp150 looks ok Then you have problems in SSB board its the one that has tuners on it/ where you hook your cable too. The board to the left of it is the deflection board.
Posted on Jan 02, 2009
My rca d61w20 rear projection television will not turn on. green light indicator will come on for 5 sec. then go out. any ideas?
Replace the CP150, CP120 and CP114 capacitors you can get the RCA repair kit by that same name from www.tvrepairworld.com which contains the caps and the CD with instructions.
Feb 17, 2011 | RCA D61W20 61" Rear Projection Television
Trouble turning on RCA D61W20
the green light blinks three times but does not come on
Aug 16, 2009 | RCA D61W20 61" Rear Projection Television
TV does not turn on model RCA D61W20B
first check all fuses they are small, square ,RED and can be confused with the square small caps. the sizzling is prob. the flyback transformer (what the h.v. wires from each tube plugs into) if you are only getting green then tv shuts down or is dead now. i would replace any bad fuses and replace the flyback transformer. also make sure you do a very good visual inspection of all the boards.
Jun 21, 2009 | RCA D61W20 61" Rear Projection Television
RCA HDTV #D61W20, CHASSIS ITC222, Power button flashing 1, pause, 9. Possible error code 19, anyone know what this means
This is not a friendly chasis, the only easy fix that you might check on the power supply board and the left side (looking from the back) 3 capacitor (220,330,and 2200uf 16V) have the top pop up. Other than that poping, arcing noise, burn smell when first start up is bad york, Flyback Transformer and even the cooling leak for those tubes you will need professional TV repair man. Those TV picture not very nice anyway.
Nov 07, 2008 | RCA D61W20 61" Rear Projection Television
RCA will not turn on
replace the flyback. you can get a replacement at the following link with free tech support to expain step by step how to replace it. you need flyback 259296 Heres the link.
http://servicemanuals.vstore.ca/
Aug 11, 2008 | RCA D61W20 61" Rear Projection Television
RCA D61W20 Image Turns on and Off
sounds solder related. I would guess the vertical output IC or flyback needs resoldering, As the vertical will shutdown the picture if the solder looses contact, and the flyback feeds the filament voltages to light the tubes. Solder repair is usually the cause when you lose picture but have sound.
Apr 05, 2008 | RCA D61W20 61" Rear Projection Television
Need Help
same problem here. did anybody get there's fixed??
Dec 16, 2007 | RCA D61W20 61" Rear Projection Television
RCA D61W20 61" Rear Projection Television Logo
166 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
