Question about KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator
Ice Maker not working
The Ice maker on my KitchAid KSC25INSS00 stopped working. I have read other posts and understand it could be one of a few causes. 1)The motor module is bad? 2)Frozen water lines? How do I tell which one of these may be the culprit? I don't want to buy a new motor module and find out that is not the problem. Thanks
    Novelist:
  • 114 Answers
ALWAYS UN-PLUG ANY APPLIANCE BEFORE CHECKING ANY COMPONENT ... WAIT 15 MINUTES BEFORE PLUGGING BACK IN. FIRST THING TO DO IS ALWAYS CHECK THE WATER SUPPLY LINE FROM THE SUPPLY LINE VALVE (SADDLE VALVE 1/4" COPPER LINE IF USED) USUALLY BEHIND YOUR REFRIGERATOR OR YOU MAY HAVE TO TRACE THE SMALL COPPER-LINE BACK TO WHERE IT IS CONNECTED TO THE NAIN WATER SOURCE. TAKE A RAG AND BUCKET AND SLOWLY LOSEN THE BRASS OR NEOPREME NUT TO ENSURE YOU HAVE ADEQUATE WATER PRESSURE AND FLOW.... NO WATER? NO ICE !!! THEN YOU CAN CHECK THE WATER SOLENOID VALVE AND INTERNAL STRAINER & ORFICE LOCATED USUALLY ON THE BACK OF THE FRIG AND JUST INSIDE THE SUPPLY SIDE OF THE SOLENOID VALVE. MOST ALL WATER DISPENSER, AND ICE MACHINE PLOBLEMS ARE DUE TO SEDEMENT THAT CLOGGS THE SOLENOID ORFICE OR CAUSES IT NOT TO "SEAT" PROPERLY. IF YOU SEE YOU HAVE GOOD WATER FLOW ... TO THE INLET SIDE OF THE SOLENOID VALVE ... PLUG FRIG BACK-IN. GO TO WHERE THE ELECTRIC WATER SOLENOID IS LOCATED ... TAKE A BUTTER KNIFE OR A "METAL" NAIL FILE AND HOLD IT ABOUT A 1/4" FROM THE TOP OF THE SOLENOID ... IT SHOULD PULL THE METAL DEVICE YOU ARE HOLDING DOWN BY THE MAGNETIC FORCE THE SOLENOID CAUSES.... THIS TELLS YOU THE SOLENOID IS GOOD AND THAT YOUR PROBEM IS SOMETHING ELSE. I ALWAYS RECOMMEND CALLING A TRAINED LISCENSED "FACTORY CERTIFIED" APPLIANCE REPAIR COMPANY (CHECK THE BBB IN YOUR AREA). UNFORTUNATELY HUNDREDS OF CONSUMERS ARE BILKED BY THE FIX-IT-ALL HANDY MAN THAT COST CONSUMERS THOUSANDS YEARLY.
Posted on Apr 27, 2007
Why does my new ice maker only make a few cubes?
I don't think your ice maker was the issue sounds like it's not cold enough to make ice in your freezer get a thermostat and see if you are maintaining temps between 0-10F if not you are slowly losing freon somewhere
May 09, 2014 | Refrigerators
Not enought water to ice maker
Can you provide a make & model # for the unit?
Feb 08, 2014 | Refrigerators
Ice maker
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
other ice maker related issues and solutions:---
Ice maker dispensing ice with black or white plastic pieces in ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-dispensing-ice-with-black-or.html
After replacing ice maker assembly, ice is not getting made?
http://alltypesofpartsreplacing.blogspot.com/2011/10/after-replacing-ice-maker-assembly-ice.html
Ice maker is leaking water and causing the ice to freeze?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-is-leaking-water-and-causing.html
Ice maker is noisy and not making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-is-noisy-and-not-making-ice.html
Refrigerator ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/refrigerator-ice-maker-stopped-making.html
Ice maker leaks water into ice bin causing a glob of ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-leaks-water-into-ice-bin.html
Amana Refrigerator leaking water from ice maker?
http://alltypesofpartsreplacing.blogspot.com/2011/10/amana-refrigerator-leaking-water-from.html
Ice maker leaking?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-leaking.html
Ice maker is dumping the ice cubes out before frozen solid.
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-is-dumping-ice-cubes-out.html
Water overflowing ice maker?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflowing-ice-maker.html
Ice cube is getting stuck up hard in ice maker
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-cube-is-getting-stuck-up-hard-in.html
Icemaker quit working?
http://alltypesofpartsreplacing.blogspot.com/2011/10/icemaker-quit-working.html
Quit making ice
http://alltypesofpartsreplacing.blogspot.com/2011/10/quit-making-ice.html
Water leaking into ice tray, frozen glob of ice
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-leaking-into-ice-tray-frozen-glob.html
Not making ice, and water leaking in freezer?
http://alltypesofpartsreplacing.blogspot.com/2011/10/not-making-ice-and-water-leaking-in.html
The ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice_20.html
Ice maker not making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-not-making-ice.html
Ice maker quit working?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-quit-working.html
Ice maker dispensing black pieces of plastic in the ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-dispensing-black-pieces-of.html
Replaced Ice maker but its still not making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/replaced-ice-maker-but-its-still-not.html
Ice maker leaked creating an ice block?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-leaked-creating-ice-block.html
Ice tray leaked?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-tray-leaked.html
Ice maker stopped functioning?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-functioning.html
Ice maker stop working?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stop-working.html
Ice maker failed
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-failed.html
Old ice maker stopped working?
http://alltypesofpartsreplacing.blogspot.com/2011/10/old-ice-maker-stopped-working.html
Old ice maker started leaking?
http://alltypesofpartsreplacing.blogspot.com/2011/10/old-ice-maker-started-leaking.html
Ice maker not working?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-not-working.html
Ice maker overfills and cause water to flow into ice dispenser and freezes?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-overfills-and-cause-water-to.html
Ice maker didn't make ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-didnt-make-ice.html
Ice maker was leaking?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-was-leaking.html
Ice maker was leaking after it filled up with water?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-was-leaking-after-it-filled.html
These will help.
Thanks,.
Dec 21, 2012 | LG LFX25976ST - 3-Door French Door...
KENMORE 106.53644300 ice maker type 2 with front door dispenser. ice maker stopped making ice, than 3 days later started again then stoped, day or so later ran again then stopped. I removed the unit put...
That is a Whirlpool module type ice maker that seems to have has been so strict with their information I will need to give the manual's another way about a 5 year life span. I have some manuals but because Whirlpool stopped letting people post what they believe is their property. I guess I need to only understand but if I place them here I will lose my subscription. Click Here=> My E-Mail and I will send it to you. May have to fill out the capsha first. Below is what I am talking about as far as how they work and yes I have the schematics and tech sheets, I will look to hear from you, Thanks, Sea Breeze
Click Here=> 8201515 Ice Maker Module
May 05, 2011 | Kenmore Refrigerators
Ice maker wont make the ice
a few things to check... 1st if you have a filter on this unit has it been changed regulary and when was the last time you changed it.. next make sure you are getting water to ice maker itself... is there frozen ice in tray ...if there is no water in unit then pull white cover on icemaker and check gear assembly does the white plastic gear look broke or anything... see if the gear turns to the right with hand freely it should not ... if this has a phillips screw in the middle of gear turn screw to the right it will be a little difficult turn it about half a turn and stop does the ice maker gear keep moving on its own this will advance the timer and should go through a cycle.. if your ice maker has a "t" and "h" terminal take a jumper wire small gauge will work jump these 2 terminals out and the gear will start to turn when you here a click pull the jumper out... watch it see if water ever enters ice maker and that teeth in ice maker actually rotate. these are a few things to start with you didnt post alot of info so hard to tell you where to start... could be a bad water valve,filter, the fill tube coming into ice maker make sure it is not frose up ,gear to ice maker head broke,heater on ice maker bad... hope this helps you start at it...good luck to you
Jan 27, 2011 | Maytag MSD2454G Side by Side Refrigerator
Ice maker stopped working
check to make sure that the fill tube has not become blocked with frozen water.
Feb 23, 2010 | Frigidaire FRS3R5EMB Side by Side...
Kitchen Aid Ice maker Stopped working
The ice maker has stopped working. The red led light blinks when the freezer door is opened. Any thoughts?
Nov 22, 2007 | KitchenAid Superba Architect KSCS25INSS...
No ice making
First i would check the water valve in the back. One side is for water.. the other side is for the ice maker... If you have a ohms meter check selonid for continuity look for blisters of plastic on sides showing in would be bad... You can also make a test cord to energise the valve by passing the icemaker to tell if valve is good. ALSO This would put water into you ice maker telling you.. you have a clear path for water to icemaker You only need to plug in for few seconds .. to keep from over filling icemaker if vavle good and water comes thu
Aug 20, 2007 | Kenmore 21.7 cu. ft. Top Freezer...
Ice Maker
Company needs to recall....
Mar 11, 2007 | KitchenAid Superba Architect KSCS25INSS...
KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator Logo
331 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
geob91
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
