CS-35401 Mitsubushi
I had a problem with Vertical hold,,, a guy soldered in a New Chip on the Main TV board.. it in...
I put everythingback, in,,, and just got solid white... with some horizontal lines...
but he damaged,, the little Circuit board, that plugs into the Back of the YOKE... one heat sink was bent,, and damaged some of the board....
I can see some cracks.. and the coppertraces are broken.. in some places..
Can i solder in the trace,,, and repair the board..
or is there any replacement ...
JCESP@hotmail.com
Gary
Del Mar Ca
  • 146 Answers
SOURCE: tv repair
No instrution sheet that I know of. Those "F" connectors are most of the time part of the "tuner", if so just take off the tuner (unsolder it) and pop off the two sides of the "tuner can" and straighten the "can". Take the "F" connector with a small screw driver and scrape the side of the connector to make it shinny and so the solder will stick to it, and do the same to the "tuner can". Use a good hot iron to solder it back on. Do NOT get the "F" connector so hot that the inside of the connector will melt. The center conductor of the "F" connector will have to be soldered back into its hole as well.
Posted on Mar 15, 2008
Slinteriors
  • 8617 Answers
SOURCE: I attempted a repair
You can repair any of the traces with small wires from the affected pin to the next componnent on that trace. To remove the board label all wires that you disconnect. There are "bridge" connectors that connect the signal bd and main bd. these lift up off the main board and will stay attached to the board youre working on. If you need further info please let me know. Also use solder wick to remove the solder and get a small tip solder iron 30watt from radio shack. The proper way to solder is (1) allow the iron to heat up. (2) touch the hot tip to the pin on one side and then briefly touch the solder to the other side of that pin so the solder flows around the pin. Use the solder sparingly so you dont bridge the pins with solder. (3) always check your work with a magnifying glass to insure the pins arent bridged.
Posted on Apr 09, 2008
CAYPIANAN
  • 227 Answers
SOURCE: Rear Projection TV convergence
dear friend if you have that type of skills you cerlainly can either resolder or replace the convergence stks. you we'll need to replace both if that's the case. they look like the audio outputs in the audio amplifiers. good luck
caypianan@yahoo.com
Posted on Oct 12, 2008
  • 126 Answers
SOURCE: Toshiba TP48C90 Convergence (replaced ICs, worked for 2 days)
Well, my thought is that there are a ton of knock off generic convergence IC's out there that usually hold up as long as yours did. Professionals like me will only use Sanyo original STK's. The counterfeit STK's out there are everywhere. Do some research on the web to locate Sanyo originals, they are out there.
Posted on Jun 11, 2009
  • 1779 Answers
SOURCE: Have a problem isntlaling my new convergence chip?
That's your HV distribution block, lift up the rubber boots and hold the block down and pull the red anode leads out, one at a time.
Posted on Jun 18, 2009
How do I fix samsung tv ln40a550p3fxza vertical hold?
After a main digital board replacement, a firmware update might be necessary to most of the main boards.
Sep 29, 2016 | Samsung Televison & Video
CS-35303 tv picture reduced down to a line horizontally through screen
The set weighs a ton so getting inside is first challenge.
Problem is in vertical circuit--9 out of ten times bad solder connections on the vertical output IC---usually if rapped on the cabinet the picture may try to open up.
The chip will have a location number like IC301 or 401 and if memory serves me be a LA7845 with that or a similar LA number right on the front.
If get to it only 7-13 pins (depends which chip is used) in a straight row--look at the solder connections on them--if find any that look a little discolored or even cracked solder all the pins.
picture of what a typical chip looks like:
the actual number will be right on the face of the chip12_21_2012_9_31_45_pm.jpg
Dec 21, 2012 | Televison & Video
My Mitsubishi CS-2610 S-Monitor suddenly blacked out! I am having a difficult time finding a job, and cannot replace my TV right away. Can it be fixed?
tried to re soldered first cold soldered component parts at the main board which may get loose contact. if can not get with re soldered check bulged or leak capacitor at the vertical section. and then try to observed if the vertical ic is too hot, that was mean the ic get bad.just replaced with new one and re check other component near the ic.
Aug 09, 2012 | Mitsubishi CS-26201 TV
On power up I hold the power button down, I can hear some sort of relay kick-on, sometimes a horizontal white line appears across the screen, then it kicks-off, and the red led blinks four times...
White line across the screen indicates that tv got vertical deflection failure problem that may be due to vertical output chip failure. If that kind of problem occurred, tv select protection mode and red light starts blinking 4 times.
Please check vertical output chip in tv main board and replace it to solve tv issue. This job needs soldering work so local tv repair shop will help you.
Thanks.
Feb 01, 2011 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Vertical deflection! TV warms up about 20 minutes and vertical problem clears.
Chances are you have bad solder joints on the main board, take the back off the set and flip the board over. Next check the area around the high voltage transformer, if you are handy with a solder iron, re-solder all the pins around the flybach transformer, then you should see a vertical ic chip mounted to a heat sink next to the flybach, re-solder all pins and any other you might see.
Dec 28, 2010 | Samsung TXG2547 25" TV
Line across picture tube
It's a bad solder connection on the vertical IC.It will be mounted on the main board.It is vertical in length and will have thirteen pins..should be marked "LA7838" or similar.
Apr 04, 2009 | Emerson TS2587D 25" TV
Mitsubushi vs4541 red,blue,green vertical lines no picture,very good sound
Try soldering the vertical output IC, sound without picture usually means vertical output is either defective or has bad solder joints. Does your on screen displays work when you press menu?
Mar 12, 2008 | Mitsubishi WS-48315 48" Rear Projection...
No picture just sound
Had the same problem, took the back off and found some bad soilder joints on two of the main circut boards. Re-soildered and appears to be fixed.
Nov 12, 2007 | Maxent MX-27X1 27 in. HD-Ready LCD...
Mitsubishi cs-35401television
HORIZONTAL FAILURE AND LINE DOWN THE SCREEN. REPLACE T5A1 LOCATED ON PCC-3-PCB. PT#349P145030(FOR CS-35401,CK-35402 ONLY) Hope this helps! Troy
Sep 11, 2007 | Televison & Video
Mitsubishi 36" model cs-35607 lost BLUE
All the IC's have a location number printed on the pc board, look for an IC with IC6F01 next to it.
Sep 06, 2007 | Mitsubishi CS-35607 TV
Televison & Video Logo
Top Televison & Video Experts
Marvin
Marvin
