Question about Magic Sing Along Consumer Microphone
No power My magic Mike doesn't work when you plug to electric, and I use AA batteries but only last for 1 hour...any solutions? Thanks
    New Friend:
  • 18 Answers
You need to buy autovolt adaptor (8 volts)
but never use adaptor and batteries at the same time.
try our site www.magicmic.com
email us customerservice@magicmic.com
try cleaning the chip. you can clean it using a pencil eraser.
You need to remove the chip from its casing
make sure to take note of the position of the chip inside casing- (inverted song chip will not make mic power on)
try erasing the gold terminal pins of the chip - gently) then return it properly..
Posted on Mar 08, 2009
My magic mike does have power, but a couple of my song chips comes up garble, and unable to bring song up, where as a third chip is able to play . Some times when I run through the list there will be some songs that pops up but not all. Then after a while it will go gargble again, but the third chip is okay.
This is when I use the AA batteries, If I remove the batteries, then it will come up data check, and garble...........any solutions or answers? Thanks
Posted on Dec 30, 2008
Have a nikon D80, sometimes when turning on and taking a photo the battery drains to no charge. have to turn off and back on again and camera works ok. have tried on existing battery and on a brand new...
HI,
You can try updating the firmware if it is possible first.If this doesn't help then try removing the batteries off the camera and allow the camera to reset for an hour and then put them back.
If this doesn't help then You need to use 2500 or higher rechargeable batteries - as soon as you switch to this type of battery, it will work fine!
Your camera requires four AA size batteries.There are several factors that contribute to battery life:
NiMH: This is the best solution for enjoyment and cost savings. NiMH batteries typically last longer per charge than the average alkaline batteries. NiMH batteries are rechargeable batteries, so they can be used several times and thereby reduce the expense of continually purchasing new batteries. NiMH batteries are typically sold with a power adapter for charging. The life of these batteries can often be determined by the mAh rating, the higher the mAh rating on the battery, the longer that they will last. NiMH batteries do not have the memory effect associated with NiCd batteries, which means that these batteries can be recharged at any time and at your convenience (you do not have to wait for the batteries to completely drain between charges).
Lithium: Energizer has introduced a new series of Lithium batteries that provide optimum performance and long life for disposable AA size batteries. Laboratory studies shows that Lithium batteries last more than three times as long as standard Alkaline batteries. This means many more hours of fun and satisfaction with your digital camera. These lithium batteries are not rechargeable, they are long lasting.
Alkaline: Using the LCD display, downloading images, playback, zoom and flash all require some battery power to operate and may decrease the number of shots per set of batteries. Performance may also vary based on the Alkaline batteries selected. To significantly increase battery life, be sure to turn off the LCD when it is not in use. The LCD consumes the most amount of battery power. The benefit of being able to use alkaline batteries is that you can find then almost anywhere if needed.
Manganese: If you are using manganese batteries, the typical battery life will be about 2 - 5 shots. Then the camera will indicate that battery power is low and may shut-down. To avoid this experience, use either Alkaline or NiMH batteries.
Optimum Solution: Use a set of NiMH batteries for longer use and to reduce the expense of continually buying new batteries. It may also be a good idea to keep a spare set of NiMH batteries for other devices that require AA size batteries on a regular basis. Use AA Alkaline batteries when the NiMH batteries need to be recharged and you want to continue enjoying the use of your camera.
Goodluck,
Please don't forget to rate the solution as fixya..
Apr 08, 2008 | Cameras
How many hours will 4 AA lithium batteries power a constant draw of 2.5 watts?
2.5 Watts sounds pretty high for an LED strip. If the batteries are paralled and the applied power is 1.5 Volts, then you will be pulling 1.6 amps - the batteries won't last long at all. The batteries are good for around 2500maH, (Milliamp hours). so figure you may get around 2 hours of life for the batteries.
Jan 14, 2013 | Audiovox Energizer Lithium Batteries 2...
I got a Braun Series 7 790 cc-4 shaver with Clean & Renew station from Amazon yesterday. All worked great trying it out last night. I left the shaver in the station, and last night I noticed the blue...
pit back in the charge station for at least 4 hours and switch the power on for the charger
many small battery chargers will flatten the battery if the power is switched off
if that fails , contact amazon for a return letter to get you warranty refund
Jun 05, 2017 | Braun Series 7 790 Pulsonic Shaver System...
I have a magellan 4370. I plugged it in to charge but as soon as I unplug it it shuts off. When plugged into the wall, it shows that the battery is charging but the battery doesn't take the charge. ...
I have several gps, and have worked on them as well. I also currently have a megellan , I have found out over the years that the batteries they use in 99 percent of the gps are ****. Even with my extensive background in electronics, I have replaced interior battery with top of the line one, At first it last for a couple hours, then one hour and eventually about 15 minutes . My total professional advice, consider your self lucky, you have one of the best gps brands out there, draw back, battery is poor. Just enjoy it in your car, plugged in your cig lighter. It's funny how these low budget throw away tom-tom,s have better battery, but gps is junk. So at least you have a superior gps. Please rate this post, if I have helped you, keep me updated on any other questions. Thanks mike
Jun 17, 2011 | Magellan Maestro Elite 4370 GPS Receiver
Which battery model fit for Panasanic ES4025 s?
The battery actually is exactly AA size, just has pins added. Having wasted a bit of time serching for a solution on the internet, I finally put a cheap AA non-chargeable instead of the original one. Just bent contacts in the shaver a little bit. The battery lasted about an hour or 10 shaves. In the end I didn't have to throw away a good shaver just for a dead battery and now don't need to carry a bulky charger when travel, but will try to use a ni-mh rechargeable one day.
Aug 04, 2009 | Panasonic ES4025
Camera turns on for 2 seconds or wont turn on at all.
There is no hardware reset on this model. We have many situation on different make digital cameras that uses AA batteries that would not turn on with some other AA batteries due to Amp requirement on the batteries. Which means that some circuit design would work only with rechargable batteries because they have more power due to higher Amp power. So I would try rechargable batteries for the last resort. -James
Apr 12, 2009 | Fuji FinePix A820 Digital Camera
Kodak Z812 shuts off automatically
It is a high-powered camera, also knows as a GREAT camera. Use CRV-3 lithium duracell batteries. I have the same camera and the same "problem", but when I use that battery it lasts forever.
Dec 03, 2008 | Kodak EasyShare Z812 IS Digital Camera
Initial charging time
hi there
the first charge should be around 12 hours, this then teaches the battery its max load.
ignore the charger if tells you its charged after a couple of hours.
after the first charge use as normal.
hope this helps
beergut707
Oct 09, 2008 | Sony AA Nimh 2500 Mah Rechargeable Battery
No power
Better to connect another AC adapter and check it.If ur laptop have Warranty then please take it from nearest Service centre.
Thanks,
Feb 12, 2008 | Tatung (TWNB12N01) PC Notebook
Magic Sing Along Consumer Microphone Logo
208 people viewed this question
Top Magic Audio Players & Recorders Experts
Michial Gueffroy
Lyle Siemens
Lyle Siemens
Are you a Magic Audio Player and Recorder Expert? Answer questions, earn points and help others
