Question about Ovens
The electric oven isnt working
The electric oven has stopped working, everything else is working fine including the fan oven. We have tried to have a look to see if it is the fuse but cant seem to find one??
  • 700 Answers
Look on the outsidfe of the house for a double pole breaker that goes to the oven and it should either be outside or in the Garage. there's actually two different breakers
Posted on Dec 23, 2008
Bush ae56tcs the oven has suddenly stopped working. The light and fan isnt going on either. Everything else on the cooker is working (ie the grill and hobs)
-Check the breaker on the electric panel. Possibly two legs breaker, one pop out but still one on. you still have power but can't cook.
Good luck
Mai Lor
Nov 08, 2014 | Ovens
Noise when oven running and stops when oven stops
Is it a convectional oven? If so, this is the fan turning on to circulate the heat. Being an electric oven, there really shouldn't be any noise whats so ever when on. I suspect your have a convectional oven and the fan is making the noise...either because it is working fine...or because its not and needs to be replaced.
Dec 02, 2013 | Thermador SC272T Electric Double Oven
Fan has stopped working in main oven,element is fine recently replaced (2008).Is this terminal or can it be repaired
It is usually better to have a new fan fitted than to try to repair it unless it is something simple like a broken wire.
Dec 19, 2010 | Neff U1661 Double circotherm super...
Bottom oven on my cooker has stopped working, it trips the electric after 7 mins running but the top oven is fine why
hi there the most likely cause for this is the element going into a fault condition as it warms up and expands your best bet is to replace the element which isnt that hard to do yourself, you might also want to check that the fan is spinning freely as it may stick and overload
Oct 16, 2010 | Baumatic B905SS Stainless Steel Electric...
In cabinet oven cooling fan does not work
it is the cooling fan if you have already replaced the thermal fuse on the back then replace the fan also shop around that price for the fan sounds high
Apr 05, 2010 | Whirlpool RBS305PDS Electric Single Oven
My oven has decided not too heat up working everything else fine ..just no heat Any ideas? Thanks
If fan is working o/k, then the problem is probably due to a faulty oven element.
This is located at the rear of the inner oven compartment behind a removeable cover.
Mar 30, 2010 | AEG B3101-4 Electric Single Oven
Hotpoint UD47 electric oven not hot enough
For all Free appliance repair videos visit our VIDEO TUTORIALS
You-Tube video "pEhRqdvpiJM" placeholder (do not delete)
1, If the fan motor in the back of the oven is going round and the temperature light is on (normally little red light), but there is no heat then you will probably need a new oven element, these are generally very easy to fit and readily available from our website these can be tested with a electric meter.
To gain access to the NEFF element you will have to remove the back plate from inside the oven. Once removed you will see the fan and element, if you look closely at the element you will probably see a small hole burnt in it where it has blown. Sometimes however there is no evidence of a fault but the element is open circuit ie: broken inside the element casing, either way it will need replacing. Some elements will are fixed from inside the oven and some are held in place by nuts from the rear of the machine.
2, If your NEFF fan oven is getting warm but takes a very long time to cook or is burning the food more on one side than the other, then you need to check if your oven fan motor is working you will see the blade turning fast if it is ok. if the element is heating but the fan motor is not blowing the heat into the oven then you need To replace the oven fan motor is a little more expensive and a bit more involved.
3. If you have the opposite problem ie: your oven is over heating and burning everything then you will need to replace your NEFF oven thermostat
4, A quite common and easily overlooked answer is if your NEFF oven is not working at all ie: no heat and no fan then the chances are that someone has put the oven timer into AUTO mode, simply put oven back to MANUAL mode and all should be working again.
Jan 13, 2010 | Ovens
Lights grill and fan work but oven isnt heating up
On our oven, we have to reset the clock before the oven will work. I think it's because of the automatic timer features.
Yours is a slightly different model, but on ours we have to press the two buttons with arrows on, at the same time as turning the clock dial. Once this is done, the oven should work again.
Good luck.
Jan 04, 2009 | Neff U1721 Double circotherm Electric Oven
Ovens Logo
47 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
Are you an Oven Expert? Answer questions, earn points and help others
