Question about Vacuums
I have a hayden premier supervac central vac system, while working on the switch in for the beater bar, the actual unit has turned off, the green light is no longer lit, is there a fuse on it somewhere or a reset button, i have tried unplugging it and replugging it in, but can not seem to get it to power up now?
  • hvypetn Dec 23, 2008
    that little white reset doesnt do a thing??
  • hvypetn Dec 26, 2008
    OK, I traced the problem back to the circuit board, and can see a small spot on it that was burnt..so I need a new board, Any recommendations as to where to get one..Canplas is closed till Jan. 2nd I might as well get a new three way switch for the nozel as well, just to make sure this problem doesn't happen again.
  • 125 Answers
Should be a reset on the main unit near the top
Posted on Dec 23, 2008
Hayden supervac
There are end caps and you can replace them. You will need to expose the brush bar/ beater; and remove it. Dig out the end caps and replace with exactly the same type. If you inspect the so called bearings, you may find matted up material that caused the stoppage. Clean and retry the system before getting a set of end caps.
Apr 03, 2014 | Vacuums
Hayden SuperVac central vacuum making an unbelievably loud noise.
Stop using the vac. Remove the filter and clean thoroughly, inspecting for damage. If the vac is spiting out bits off fuzz or lint it may need the motor cleaned and serviced as dirt has leaked past the filter. If it is spewing black, not gray this is carbon dust from the motor brushes. If the noise is scratchy or growling this is a sign of a motor problem as well.
The muffler unless it is a hepa filter/muffler combination is NOT designed to catch dust.
Exhaust dust is a sign of dust leaking through the motor which indicates future moor problems.
HINT, if the guy who installed the muffler didn't secure it right he is probably not a good choice as a service tech either. The muffler is normally clamped or secured in place with a small screw so it can be removed in the event of service.
Jun 14, 2009 | Hayden Industries SuperVac 3600 Central...
Hayden 6000+ wont run
Define hose works or doesn't, no suction, hose will not activate vac , etc.
Test the vac by shorting across the low voltage terminals where they enter the machine. If the vac works here your problem is in the internal wiring, at the valve or the hose to wall connection. If the vac will not run, you will need to check the motor for continuity across the motor leads.
Apr 18, 2009 | Hayden Industries SuperVac 6000 Central...
Hayden Super Vac Premier will not stop unless I unplug
one of two problems cause this. first is a short in the wires that turn it on, the small wires going to the side of the body unplug one of them to see if thats the problem
second is a stuck relay inside the top cofer of the main body
Jan 26, 2009 | Hayden Industries SuperVac 6000 Central...
Hayden Supervac 3600
http://geeksquad.fixya.com/ThreadView.aspx?prdid=11860&thid=808510
Posted by kdm0 on Jul 20, 2008
Hi, I have a Hayden Supervac 3600 central vac system in a house I just purchased. The Amber light indicating that it needs regular maintenance is on. I have cleaned and serviced the motor, everything is fine and suction is well. How do I reset the service light? The reset button seems to do nothing. Thanks
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. I heard of this happening before and you need to refer to the owner’s manual and or to contact the factory or manufacturer of which I will provide to you @ the end of this question. There may be some type of rely switch or board that might need replacing but check with the factory. If you need further help please refer to a local vacuum cleaner dealer in your area. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.haydenvac.com/company/company.html
Customer Service 1-800-461-5300
Company Phone # 1-705-726-3361
Company Fax 3 1-705-726-2186
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 20, 2008 | Hayden Industries SuperVac 3600 Central...
Vacuums Logo
99 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
