Question about Honeywell Electronic Programmable Heat/Cool Thermostat - CT3300A100 Heater
Honeywell Thermostat I have a honeywell CT3611 thermostat and a york heat pump (E2CS030A06A) and I'm having problems with the fan and auxillary heat turning on and off to maintain the indoor temperature. My indoor unit has wires connected to C,G,R,W1,W2 and my thermostat has wires connected to C,R,W2,E,W1,Y,O,G but no wires to B,L. I followed the guide for the thermostat wiring however the fan does not work when I place the control on "continuous" and the aux/supplemental heat does not turn on on the indoor unit eeven though the thermostat indicates it's on. I checked my aux/supp coils and they are working fine. I have not chaged anything on the heating system except the thermostat. Someone please help.
    Guru:
  • Honeywell Master
  • 588 Answers
Make sure G from indoor unit goes to G on thermostat for fan continous fan, if that doesn't work and you have 24 volts to R and C then the t'stat is bad.
For 2nd stage heat or aux.heat, on the indoor unit you need to make sure the wire W2 from the indoor unit goes to W2 on t'stat.
You don't need any wires from W1on the indoor unit to W1 at the t'stat because with a York heat pump Y1 is the contactor which turns the compressor on and you will get 1st stage heat, and for cooling the t'stat will also bring on O which is the (reversing valve) or cooling changeover relay for the cooling mode.
C = common usually black wire
R = hot usually red wire
Y or Y1 = contactor
W1 = 1st stage heat not needed for heat pump
W2 = Aux. heat indoor heat
G = fan
O = Cooling changeover relay
B = Heating changeover relay
L = System monitor
E = Emergency heat relay
Posted on Sep 17, 2009
  • 1 more comment
  • Bill Long Sep 22, 2009
    I noticed I didn't explain what you needed to do for Emergency Heat. You need to put a jumper wire from W2 to E on the thermostat for Emergency Heat. B is not used.
  • Bill Long Feb 16, 2010
    R = hot side of transformer
    C = common side of transformer
    Y = compressor contactor
    O = reversing valve it will be energized in the cooling mode
    G = blower / fan
    W2 = indoor unit 2nd. stage
    E = emergency heat (jumper W2 to E)
    W1 = Not used or (jumper Y to W1 but do not hook up wire going to furnace)
    B = Not used
    L = system monitor
    R = transformer hot
    C = transformer common
    O = reversing valve (energized in cooling mode)
    G = blower / fan
    W2 = Indoor furnace or electric heat
    E = emergency heat ( jumper W2 to E on t'stat)
    L = system monitor
    W1 = not used
    B = not used
How do you program the Honeywell RTH 2410B1019 thermostat for a heat pump.
5-1-1 Day Programmable Thermostat - Honeywell
yourhome.honeywell.com/.../thermostat/5-1-1-day-programm...
HoneywellSet the Honeywell 5-1-1 day programmable thermostat to your maximum comfort settings. Works with heat pump systems. Buy now!
Nov 18, 2015 | Honeywell Heating & Cooling
Aux keeps coming on !on honeywell th3210d thermostat when i turn regular heat on
This is normal when the heat pump doesn't satisfy the room temperature within a given time, it automatically will kick on auxillary for backup.
Nov 08, 2013 | Honeywell Programmable Thermostat Heater
I have a York Unit and a Honeywell thermostat. Our unit froze up and I was told to activate the emergency heat. I did this, what does this heat do? I mean how does it work? When do I set it back to...
by going to emergency heat you have shut off your heat pump and turned on a back up source,either gas or electric, if its cold out,35or less ,just leve your emergency heat on till it warms up a bit
Jan 10, 2011 | Honeywell Programmable Thermostat Heater
I have a new York hybrid heat pump/gas furance
Did they check the sensor in the plenum. You are suppose to have bonnet sensor to switch from heat heat pump to gas whaen it is to cold for the heat pump. The bonnet sensor may be to bad. The unit is cycling ever five minutes because it may have five minute time delay.
Dec 15, 2009 | Honeywell Programmable Thermostat Heater
Replacing Old York TS to HoneyWell RTH230B
rh is hot for heating rc is hot for cooling looks to me like ya need a heat pump stat some thing to control the reversing valve.Tom
Jun 18, 2009 | Honeywell Electronic Programmable...
Thermostat auto-changeover mode unavailable
when you programed it did you go through all the setup #1-0 ,#3-0 ,#5-5 ,#12-1
Nov 24, 2008 | Honeywell Electronic Programmable...
Honeywell CT3611 thermostat, not working..
if you cross the two wires and you see a slight spark and heat comes on, then the problem is in the thermostat, if not then problem is at furnace it self.
Oct 24, 2008 | Honeywell Programmable Thermostat Heater
44860 thermostat won't activate in heat mode
I had the same set and problem. I had a RC wire which is the power to the AC. But didn't have an RH wire which is the power for the heat. To fix this just use the jumper wire and insert it in with the RC wire and hook it up to the RH. Fixed my problem.
Oct 20, 2008 | Hunter Fan Company 5/1/1 Programmable...
Heating & Cooling Logo
824 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
