Question about Reddy Heater-30-55,000 BTU Variable
Heater runs for 2 to 20 mins stops and smokes
Replaced ignighter and air filter
  • 3 Answers
I just had the identical problem in the shop. Found the fuel filter almost completely clogged. Replaced the filter and it ran great.
Posted on Dec 24, 2008
Turbo heater will only run and heat with top open
NO MAKE NO MODEL no help can be found or given
Mar 04, 2015 | Heating & Cooling
It starts up good then stops and a big cloud of smoke comes out. Got a new ignighter (50$) but still doing the same. can you help me?
http://www.bealsmotor.com/manuals/113282-01.pdf You could have an air problem. Take the cover off the heater and see if it runs ok, if it does then you have an air problem, check for bad lines or cracked housings
Oct 16, 2014 | All-Pro Kerosene Garage Shop Heaters - All...
Runs for a min then smokes it self out and tuns off other times it will run for 5 min then do it
Check the fuel system for plugged fuel filter, these will have an in line filter and they often get plugged up. Check your fuel lines for holes,kinks or pinching. These will rust in the tank from storing all summer condensation builds water forms then rust. Clean fuel system out good to include the screen in behind the nozzle assembly. While you have the cover off clean out the photoelectric eye and igniter. If the fuel is old change it out as well.
Dec 12, 2010 | Master Heaters Master B115DT 115,000BTU...
R55B Reddy Heater won't stay running. (PMS? menopause?)
Wow! Yours is the best description of a problem I have ever seen!!! Before I read the whole thing I figured you missed the pressure check as most people do but you nailed it. This is what I would try, Replace the air filter, the fuel filter, and the fuel (to make absolutely sure there is no water in the fuel) and readjust the fuel/air mixture. If that does not do it replace the cadmium cell they only cost pennies. Let me know how you make out and good luck.
hardrocko
PS, I have one of these so I am pretty familiar with the problems.
Feb 03, 2010 | Reddy Heater-30-55,000 BTU Variable
Look below
make sure air and fuel filter are clean.Set pump pressure to mfg set pressure after two minutes of operation
Feb 26, 2009 | All-Pro Kerosene Garage Shop Heaters - All...
Pro 110, runs 10 min., blows white smoke ,shuts off
the first thing you need to do is go back to useing K1 kerosene, diesel fuel not only burns dirty but also has a tendency to gel up in cold weather which could be makeing it hard for the heater to draw the proper amount of fuel. To reset the pressure you will need a gage, it should run at about 6-7 psi. you can order a pressure gage from mr. heater online, they are by far the cheapest I have found as they are the actual manufacturer or call 1-800-251-0001
Feb 05, 2009 | Reddy Heater-170,000 BTU Kerosene Deluxe
Heater will run for about 5 min. Than flame goes out , and smokes
MAKE SURE THE HOLE IN THE K1 CAP IS CLEAR.SOUNDS LIKE A FUEL AIR MIX PROBLEM.
Dec 11, 2008 | Reddy Heater-170,000 BTU Kerosene Deluxe
30'000 btu spark style will not lite
  1. clean the fuel filter
  2. clean the nozzle
  3. set the air pump pressure.
It should fire off, unless you have developed an air leak, worn nozzle, bad fan, or a motor that is not turning rpm's.
Nov 10, 2008 | Reddy Heater-70,000 BTU Kerosene w/T'stat
Reddy Heater-30-55,000 BTU Variable Logo
76 people viewed this question
Top Reddy Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
T bone 1963
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
