Question about Kyocera Mita Kyocera-Mita - PB-60 BASES FOR PF-8E, HS-8E Printer
Paper feeder unit open(Kyocera FS-3800n)
Can I have part number for 2000 sheets paper feeder unit(PF-8E) controller board and the micro switch?
Thank you.
  • 523 Answers
Here you go all parts you need:
parts number Description
5AAPRCZR2013AH P.W.B.ASSY KP-772 CONT X X 1
5ESM010235***01 MICRO SWITCH X X 1
5ESM010234***01 MICRO SWITCH 01X02 X X 1
let me know if you need anything else? enjoy
I’m happy to help further over the phone at https://www.6ya.com/expert/mustafa_06f84c65ab5cc745
Posted on Mar 01, 2009
FS-4020DN "Paper Jam Deplexer"
check for jamed paper above the paper tray in the duplex unit.
=remove tray
=move green lever and open duplex unit
=remove jam
Jun 27, 2014 | Kyocera FS4020DN (A4) Workgroup Mono Laser...
Where do I load paper in a Kyocera FS-C5350DN Full-Color Laser Printer
At the bottom of the printer you will find the paper cassette. Pull the handle and the cassette will slide out. Eventualy you will need to ajust the size of the paper.
Jun 23, 2014 | Kyocera FS-2000D Laser Printer
Error call service 4000:00433933
The codes on this model are the same as on the Kyocera Mita copiers.
ie: 4-digit codes
Call service 0150 engine pcb EEPROM error
Call service 0420 option paper feeder communication error
Call service 1010 lift motor lock error
Call service 1140 lift motor going up error
Call service 1150 lift motor going down error
Call service 2000 main motor error
Call service 2200 drum motor error
Call service 4000 laser scanner unit (polygon motor) error
Call service 4200 laser scanner unit (pin photo sensor) error
Call service 5100 short-circuited main charger output
Call service 6000 broken fuser heater lamp M wire
Call service 6020 abnormally high fuser thermistor M temperature
Call service 6030 broken fuser thermistor M wire
Call service 6400 zero-crossing signal problem
Call service 7000 toner motor lock error
Call service 7410 drum unit non-installing error
Call service F000 communication error between the main controller board and operation panel board
Call service F010 main board (system DIMM board) checksum error
Call service F020 main or expanded memory error
Call service F030 general failure
Call service F040 communication problem between main board and engine board
Call service F226 main pcb video data control error
May 18, 2011 | Kyocera FS-3900DN Laser Printer
Kyocera FS 4000 DN printer stops printing for no reason.
Try the feed tires in the tray first. More than likely the paper is not being picked up and causing jam message. The separation roller also has a hub on it to prevent a second sheet from feeding. Sometimes these start to lock up ,a little oil on the hub sometimes relieves some of the tension.
Jun 03, 2010 | Kyocera FS- 4000DTN Laser Printer
Paper folds up in the main print unit. Whether i feed manually or from paper tray ! Does this 80% of the time
open the paper feed unit there you can find a iron rood thats called registartion unit clean it .... two side of the registartion unit you can see two springs remove both ...registartion unit will come out ... clean the two rollers properly and refix it and check .....
if its not working replace the paper feed unit ..... if you want for this mail to me at anantakumarjena0@gmail.com
Dec 01, 2009 | Kyocera Mita FS-3800N Printer
I have a KM-1820 and the problem is CF223 error.
Meaning Motor error in the option bulk paper stacker HS-8E. Suggested causes Defective harness (S02400) between engine board and option unit interface connector. ? Defective option bulk paper stacker HS Corrective action Replace engine board Replace harness
Oct 21, 2009 | Kyocera Mita FS-1920 Laser Printer
Kyocera 3800N Defaulted To MP Tray
paper guide was set at A5, then this allowed menu to change feed tray selection
Apr 29, 2009 | Kyocera Mita FS 3800 Laser Printer
Pf-8e telling me "install MK"
it needs a maintenance kit... call kyocera support to see which one is required...
I’m happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
Mar 29, 2009 | Kyocera Mita Kyocera-Mita - PB-60 BASES...
The printer will not load the papers
Hi you may try:
1) paper input sensor dirty, clean paper input sensor usually near the tray input roler area there is a micro switch or a led light sensor with two wires.
2) paper input sensor fail or disconnect between sensor and socket on the board, you have to open the cover to check.
Dec 22, 2008 | Kyocera Mita FS 1000+N Laser Printer
76 people viewed this question
Top Kyocera Mita Office Equipment & Supplies Experts
Adorjani Laszlo
AAAA262430
Marvin
Marvin
Are you a Kyocera Mita Office Equipment and Supply Expert? Answer questions, earn points and help others
