Question about HP OfficeJet 6210 All-In-One InkJet Printer
It shows a paper jam, but I can't find any paper in the machine. makes a strange surging sound when I put new paper in
Remove the black panel (mechanism) from the back and chances are you will find a piece of "jammed" paper on the roller. Remove it and replace the black panel. Press OK and wait a minute while it resets itself.
If there is no paper behind the panel or nothing you can see from the front-inside ... then you may have a problem.
Posted on Dec 27, 2008
Paper jam in this position
Open the machine as if you were putting in a new cartridge and remove the jammed paper. You may have to remove the paper tray or duplexer to find more paper.
Reassemble, don't put so much paper into the tray, make sure the paper isn't curled badly. Generally I put the paper in concave down...it will flatten over time.
Perhaps your paper is curled somewhat and is concave up which is causing the jam.
Jun 25, 2015 | Office Equipment & Supplies
Paper jams and burn
Lets try the following
  1. If there is no paper, load a new stack of paper into the paper tray.
  2. If there is paper in the paper tray, make sure it is straight. If the paper is curled, you should straighten it. Sometimes it is helpful to remove the paper, turn the stack over and put it back into the paper tray.
  3. Reduce the amount of paper in the paper tray, and then try again.
  4. Check that the MP tray mode is not chosen in the printer driver.
  5. If the LCD shows Paper Jam message and you still have a problem
Or try
  1. Pull the paper tray completely out of the machine.
  2. Use both hands to slowly pull out the jammed paper.
  3. Press the cover release lever to open the front cover
  4. Slowly take out the drum unit and toner cartridge assembly. The jammed paper may be pulled out with the toner cartridge and drum unit assembly, or this may release the paper so you can pull it out of the paper tray opening.
  5. Put the drum unit and toner cartridge assembly back in the machine.
  6. Close the front cover.
  7. Put the paper tray firmly back in the
Or leave a Voice mail we'll check what we can do
Jul 26, 2014 | Canon Genuine Oce Imagistics Fx3000...
Am repairing a canon ir1020 which shows paper jam for any single copy.though paper is completely delivered out of the fuser ,but the red in response to paper jam still flashes.I need an assistance.
Sounds like the fixing exit sensor flag is missing or broken. I would look into that and just a note... I had a strange jamming problem with one as well. It turned out to be the registration clutch. I cleaned the clutch and it worked......
Sep 01, 2012 | Canon IR-1022 Copier
"P" is blinking in display Sharp AL-1641cs
There is a small white gear that drives the fuser module. It wears out at 30 to 40 thousand pages.
If the sound is a jumping to gringing noise that would be the problem.
That gear jumping will cause the machine to say out of paper,, jam,, give all kinds of problems from things bouncing around.
Aug 02, 2010 | Sharp AL-1641CS Laser Digital Copier
Keeps telling me to remove back tray as I have a paper jam. No paper jam. Message won't clear and won't let me put in new ink cartridges which it needs....printer is 2 months old....what gives?
You did not post a Make/Model but with many machines they will have a trap door/panel at the rear of the printer. If paper did not pickup from paper tray properly then it will show a jam message that can only be reset by opening the rear door/panel.
Jun 26, 2010 | Office Equipment & Supplies
SHARP UX-A1000 - sends all BLACK page (to all
Noisy line? is all that strikes true when you ensure me it makes great photocopys, but then you receive OK, very strange, All the mechanisms for doing a local copy is the same as sending a fax the difference is the conversion to phone noise so it has to be electronic, I;d guess lightning/power surge, cant think of much else....sorry
Nov 04, 2009 | Sharp UX 510 Plain Paper Thermal transfer...
Have a Brother Intellifax 770. Machine went completely dead
Probably fried. Sounds like more of a power surge than a paper jam.
Apr 07, 2009 | Brother IntelliFAX 770 Plain Paper Thermal...
Doesn't Print - Says "Paper Jam"
That is the problem, machine will show printer jam if paper feed rollers fail to pick up paper when requested, your machine sounds like it needs new paper feed roller or you can clean the paper feed roller with a slightly! damp cloth.
If no jam light shows when power is turn on and machine comes to ready and then you send a job to printer and it then shows jam then it is the feed roller or sometimes the feed clutch
If on the other hand it always show jam then there is or a switch is stuck.
Oct 25, 2007 | Kyocera Mita FS 1200N Laser Printer
HP OfficeJet 6210 All-In-One InkJet Printer Logo
23 people viewed this question
Clive
Clive
