Question about LG HBM 730 Bluetooth Headset Wireless Headset
Jabra BT500 won't turn on or indicate charging??
I've only had the unit about 1 month. When I first purchased it, I followed the mfg instructions, and paired it w/my Blackberry and all was working properly. I didn't use it for the last couple of weeks, so when I pulled it out again, I plugged it into my laptop via the usb power cord and the red charging light came on briefly, then off. Now, nothing will come on, no charging light, no blue light signal, no green light, nothing. No indication that it is working whatsoever. When I attempt to connect on the Blackberry, it shows 'paired' with the Jabra BT500 but always fails the connection. Any ideas?, or is the unit just fried? Thanks for any help you can offer.
  • Anonymous Apr 06, 2008
    IT WONT TURN ON OR SHOW ITS CHARGING
  • ihonorelalla Jun 21, 2008
    Jabra Bluetooth worked fine for the first few months. Now it won't work at all. Red charging light comes on briefly then goes off. Can't pair with palm treo with either wall charger or with USB charger.
Noggin
  • 944 Answers
SOURCE: Jabra BT500 won't power up
If you can try a different charger, try that. try charging with USB cable if not. Try your charger on another headset if you can. I think the charger is the problem. If no change every way, here is the link to the user manual if you need it; http://www.jabra.com/Sites/Jabra/NA-US/pages/SupportProduct.aspx?productid=3c063d26-e62b-4b4d-9613-c10134a79cf3 Page 7 has the toll-free tech helpline which is probably worth a check in case they have any ideas before opening it up. If still no luck, and you want to open it up, first thing to look for is the battery. check any connectors are on properly. try charging for a while and see if battery gets warm/hot/no change. See if there are any technical specifications or part numbers written on the battery and I can get more info to see if it can be checked and if it is worth replacing. If you have any trouble identifying the battery, try posting back a photo of the inside and we will see what we can do. Hope this helps :)
Posted on Aug 17, 2007
SOURCE: jabra bt500
yeah charge it for 14 hours......and then hold the pair and call at the same time... then repeat the pairing process
Posted on Feb 11, 2008
SOURCE: Jabra 250 Codes
Jabra 250 pairing code is nothing but 0000, however it has to be paired from an external device like a phone or computer.
I mean to say the pairing has to be intiated from the other device not the jabra 250.
hope that helps
Posted on Apr 08, 2008
SOURCE: Problem with LGv 42PC3D - won't turn on
The POWER SUPPLY UNIT with Out !!!!
Go to http://www.shopjimmy.com
for the Part Types, the cost is about $160.00.
Posted on Feb 10, 2009
SEJS
SOURCE: Cant connect LG Renoir via USB, connection problem
I get this all the time and it is really annoying.
What I do to solve it for me is to is to tern all my mobile application off and then reconnect the USB cable.
To close all open applications: press the white hard key (in the middle of the red and green), and you customisable menu appears. At the top of the screen is a grey tab with a dark grey triangle (like a play button), press this and you see all (if any phone application are open), press the end all button on the screen. Then to confirm action pres yes to stop all tasks.
Hope it solves you problem.
SS
Posted on Mar 24, 2009
Is the rechargeable battery in the Jabra BT500 replaceable?
  • jabra headset battery swap - YouTube www.youtube.com/watch?v=MMLocSWjq8Q
    • BY THEDIECLAN2004
    • 3 MIN
    • 24K VIEWS
    • ADDED 2011-12-10
    Video embedded · jabra headset battery swap theDIEclan2004. Subscribe Subscribed Unsubscribe 15 15. Loading ... Plantronics Pro battery replacement - Duration: 9:15.
  • Jabra BT500 Bluetooth Headset - Newegg.com www.newegg.com/Product/Product.aspx?Item=N82E16826552001
    • 4/5
    • 69 REVIEWS
    Buy Jabra BT500 Bluetooth Headset with fast shipping and top-rated customer service.Once you know, you Newegg!
  • Jabra SPORT Bluetooth Battery Replacement - YouTube www.youtube.com/watch?v=Sm8cSkyTmfA
    • BY GREG PAJAK
    • 2 MIN
    • 27K VIEWS
    • ADDED 2013-09-23
    Video embedded · A quick video showing the ease of replacing the battery in the Jabra Sport bluetooth headphones. Jabra says when it it out of warranty they cannot be ...
  • Jabra BT-350 Disassembly and Repair - Instructables www.instructables.com/id/Jabra-BT-350-Disassembly-and-Repair Intro: Jabra BT-350 Disassembly and Repair. I wooted a few of these dandy devices a while back and they work great but the volume buttons are weak and the solder ...
  • Jan 26, 2016 | Jabra BT500 Wireless Headset
    Aug 17, 2007 | Jabra BT500 Wireless Headset
    I'm trying to pair my jabra bt500 with my iPhone 4. I get all the way through the process when I receive the following message: Connection Unsuccessful "Jabra BT500" is not...
    I just had this same problem. I solved it by turning the iPhone Bluetooth off and then back on, after which the pairing (with passcode 0000) worked properly and so does the headset.
    Dec 28, 2010 | Cell Phones
    Hello. I can't seem to get my phone to "discover" my bluetooth device.... Help?
    1. Turn headset off. Press and hold until solid light comes on.
    2. Activate Bluetooth on your phone.
    3. Search for Bluetooth devices and select Jabra BT500.
    4. Press ‘OK’ on the phone ,If the phone asks for a PIN then confirm with PIN code 0000 (4 zeros)
    Thank You
    Sep 05, 2010 | Jabra BT500 Wireless Headset
    My Jabra BT500 is on mute. Callers can not hear me. It worked fine at first now nothing.
    When powered up and in "talk" mode (during a call) hold the volume up and down "bumps" simultaneously. This engages/disengages the headset's mute function.... Hope this helps...
    Mar 08, 2008 | Jabra BT500 Wireless Headset
    Bluetooth help
    When you pair the bluetooth headset default passkey (PIN) should be used as "0000" (4 zeros). for further info you can check the user manual as I attached the link below
    http://www.jabra.com/sites/Jabra/GNimages/Products/WirelessHeadset/BT500/Documents/UM/BT500_UM_NA_EN_480.pdf
    Good Luck
    Feb 20, 2008 | Jabra BT500 Wireless Headset
    Jabra bt500
    Jan 04, 2008 | Jabra BT500 Wireless Headset
    Cant hear
    I have the same problem. The lights are on, it's paired, and my caller can hear me. but I cannot hear the beep from pressing buttons on the jabra, nor can I hear anything from the phone.
    Oct 31, 2007 | Jabra BT500 Wireless Headset
    Jabra BT500 will not power on or charge
    I would also like to know if you find a fix for this problem. I have the BT500 and it will also not turn on.
    Sep 17, 2007 | Jabra BT500 Wireless Headset
    Unit won't charge and I get no lights
    I have the same problem. it's due to a faulty pover-cell inside the headset. i have also read that the charger can be inserted the wrong way, this would in turn kill the battery by giving it a reverse charge.(not sure about that) as i tried this after finding the unit defective and it will only plug in one way.. the only suggestion that i can give is contact Jabra directly. iv'e read that they will replace any headset in this range for free, here is the address for their site. http://www.jabra.com/Sites/Jabra/UK-UK/pages/Contact.aspx Hope this helps.
    Sep 14, 2007 | Jabra BT500 Wireless Headset
    LG HBM 730 Bluetooth Headset Wireless Headset Logo
    129 people viewed this question
    Top LG Radio Communications Experts
    Damen Wong
    Damen Wong
    iPhone Technicians
    iPhone Technicians
    Level 1 Expert
    coolboyjitu
    Level 1 Expert
    Are you a LG Radio Communication Expert? Answer questions, earn points and help others
