Question about Kenmore 24032\24036 Top Load Washer
Hi, Have you heard of problems with the new washing machines that spin so hard they damage floors?
  • 179 Answers
I have not heard of the machine damaging floors. the new front loading machines do spin at a high rate of speed. It is so fast that if it is not on a solid floor it will shake the floor. I have been in homes that have a front loarder on the second floor and it literally shakes the whole house. This is why this machine should be only on concrete floors.
Posted on Dec 23, 2008
The spin cycle om my Maytag washing machine isn't working, what can I do?
unless you know how to replace the transmission on it I would look for a new one
Mar 27, 2015 | Maytag Neptune MAH5500B Front Load Washer
I have an F&P MW612 washing machine that stops at the start of the spin cycle leaving water in the machine. After pushing the pause button, looking inside, closing the lid and restarting I've heard...
Something may have been stuck in the drain pump impeller creating the clanking noise. This is a serious problem that can lead to the burning out of the motor controller module, the machine's "brain". It has been found that a short circuit is imminent on a leaky drain pump which can eventually burn out the motor controller module.
Empty the machine then lay it's front on a padded floor/surface and check the drain pump including the diverter valve where both the drain pump and the recirculation pump connect from. Replace the drain pump if damaged or leaking to avoid further damage to the motor controller module.
Fault Code Reading on Fisher and Paykel Top Load Washing Machines
Aug 23, 2011 | Washing Machines
Front loader has gotten really really loud and shakes the whole floor when it spins properly. Today it left a lot of water in the clothes. It used to make a weird whining noise when it didn't spin out...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 13, 2010 | GE WBSR3140DW Top Load Washer
Not spinning and emptying
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
May 14, 2010 | Zanussi FJD1266W Front Load Washer
Hi all i have a big problem heard a big bang the
When it was fitted did the installer remove the transit bolts from the rear of the machine because it sounds as if it has done damage to the drum and housing when it went into a spin.
Hope this helps.
Good Luck
May 09, 2010 | Washing Machines
Legacy leaked on floor and subsequently ruined gararge ceiling. I put a wash in yesterday, filled it shut it off and left it soaking. I returned home from my errands three hours later to an 3/4 empty SS...
Its most likely the tub seal at the bottom, check and see if the area inside is wet in the middle. You will need to remove the outer panels to do this. It doesn't sound like anything else if the water was left to sit so a replacement of the seals around the center shaft should fix this problem. Let me know if you have any questions about doing this and I would be happy to help.
Jun 04, 2008 | Maytag Legacy Series Top Load Washer
During the spin cycle the wash machine spins so hard the wash machine moves
there are several factors here.Has the washer always moved ?Are you on a cement slab.Make sure that all 4 legs are firmly touching floor.If the machine was just recently installed brand new than there may be packing still attached that stabilizes the suspension and that would throw it off.
May 26, 2008 | GE Washing Machines
LE code, Unplugged but machine doesn't want to spin properly
your unit doesn't have brushes, the problem is the hall sensor, which is located on the stator. Have this replaced and your problems will go away. Insure you are using 'HE' branded detergent as well.
Oct 21, 2007 | LG WM2077CW Laundry XL Front Load...
Kenmore 24032\24036 Top Load Washer Logo
51 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
