Question about Bosch 30 in. NGP 732 / 736 Gas Cooktop
Creda gas hob now keeps ignighting
The ignition is from all four burners and seems to be ignighting under the hob intermittantly. have turned off the electric oven. British gas want 167 to come out.
  • Anonymous Mar 12, 2014
    my gas hob is 30 years old and a gas burner is breaking up
    My Technic hob burners won't ignite when knobs turned on
The ignitors have got wet usually due to cleaning. they are usually located under the rotating switches just let them dry out ( very well .....may take days) and it will work normally again
Posted on Apr 11, 2009
Westinghouse gas hob four burner only one igniting the other three only light with a match gas coming through but no spark
Clean the wires going to the ignitor of each burner, clean the burners as well. Chances are you have too much oil and dirt on them that is why your burners are not igniting.
Jan 27, 2014 | Cooktops
My hotpoint gas hob ignighter keeps clicking
You have either a bad switch under the knob, or you recently had a power outage or something took out the spark module. You can test each switch for continuety when the switch is closed or 0 ohms on your resistance meter. if these are all reacting fine, then replace the spark module. Oh, and you might want to call a technician on this one. Make sure its unplugged and the gas line is stable. You have to remove all of the burners to get the top off. GL
Mar 15, 2012 | Cooktops
Electric ignition to hob seems to be jammed
Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
Gas Range Repair Burners Keep on Clicking
http://www.fixya.com/support/r4033033-gas_range_repair_burners_keep_clicking
heatman101
May 31, 2010 | Cooktops
Creda stovetop tries to light without gas on.
heatman101
May 28, 2010 | Creda Colonial 42352 23 in. Electric...
Ignitor keeps sparking not wet or dirty even when no burner on
Will most probably be a problem with your ignition box. If you want to test this try taking off the hob by undoing the screws under the burners, be very careful with these however as it is very easy to strip the thread on them, once you have the hob off try unplugging the ignitor that keeps sparking and swapping where its plugged into the ignition box with another ignitor. These ignitor can be plugged into any plug in the box so no worries there. If the ignitor keeps sparkings in another hole its the ignitor. If the new ignitor sparks its the ignition box. It will most probably be the ignition box. Is a common fault
Aug 08, 2009 | Fisher and Paykel GC913 - Stainless Steel...
Jenn-Air 36 Gas Cooktop
try to use macth in the burner u said,if ok the flame,the problem is the igniter wire,nid to replace,but if u use the macth then the flame is malfunction again i think the sensor is the problem,nid the tecnician coz is hard to repair,sometime after repair the sensor it problem again in next day
tnx gerbee
Jul 02, 2009 | Jenn-Air 36 in. CCGP2720P Gas Cooktop
Four burner gas hob
You have to turn the knob a little farther, past the light stage. Sometimes they're not marked quite like they should be.
Jan 04, 2009 | Cooktops
No gas to hobs
use mactches for ur gas burner if the ignition not really work.put all gas in off position b4 cleaning by using a vacium in the place of the control knob,turn off the power b4 try to clean,tnx
Nov 24, 2008 | Dacor Preference SGM466 Gas Cooktop
Baumatic B40 Gas Hob : Gas not staying on.
we have the same problem... try removing the knob, ours works fine without the knobs ????
Dec 19, 2007 | Baumatic 24 in. B40 Gas Cooktop
Bosch 30 in. NGP 732 / 736 Gas Cooktop Logo
785 people viewed this question
Top Bosch Cooktops Experts
Paul Carew
Jay Finke
Jay Finke
Narinder Chhina
Narinder Chhina
Are you a Bosch Cooktop Expert? Answer questions, earn points and help others
