Question about Actiontec GT701R DSL Modem
Adding 2nd computer to msn broadband
I currently have msn broadband through Qwest Connect Silver residential service, using Actiontec modem #GT701R. I want to connect a 2nd computer, HP a6610t, which has a 56k modem built in. I'd like these computers to work independently, not sharing info. The computers could be used in the same room or in rooms close to each other that each have phone jacks. It would not be a big problem if they could not be used at the same time.
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Initially, the built-in 56K modem of the HP-A6610T will not work with a broadband line. It will however work with the regular telephone but it would require a separate dial-up account. If your requirement is for them to share the broadband connection, then a router would have to be used. To make each computer not be able to access each other would entail removing any shared folders on each. The only thing they would be sharing is the Internet access.
Pls post back should you want to explore and consider this solution. However, should you reject this solution, then all my subsequent postings may no longer be viewable by you.
Good luck and Thank you for using FixYa. Happy Holidays.
Posted on Dec 23, 2008
    Sergeant:
    Novelist:
  • 327 Answers
If the computers are with in cabling distance to each other I would suggest a router and hook the cable modem directly to the router so so each computer does not have to do the routing services. ============ If you are going to connect ONLY 2 computers to each other, you don not need a router, or a hub. All you need is a "cross-over cable". It is a type of RJ45 Network Cable that you can find anywhere. You would however need another Network Card, AKA Ethernet Card. The extra NIC (short form for network interface card) will be put in your main computer that is connected to you cable/dsl modem. You would basically have your modem connected to your computer through one card, and the crossover cable connected from the same computer to the other one through the other NIC Card.
That Way, You don't have to spend about $120 for a router, and you also don't need a hub.
IF you decide to buy even another computer and want to connected it to the network, you will than have to consider buying a router, or a hub.
Routers are better because simply saying, routers intake the signal, and regenerate it to all the computers connected to it whereas Hubs split the signal up.
Therefore, hubs are almost tripple times cheaper. The Crossover cable method only workds with two computers.
Interms of the routers, I think Linksys is a good and affordable router. (get the Linksys 4 port router)
  • 13,433 Answers
You will need to get a Lan / Ethernet card to the 2nd computer. and connect it to the dsl modem also, if there are no open slots you will need to get a hub or a switch in the middle.
This one for example http://www.bizrate.com/networkhub_switches/trendnet-te100-s5-network-switch--pid607324985/compareprices.html
How do I reset the password and User ID on an Q1000 Actiontec Modem?
Things You'll Need
• Q1000 Qwest Wireless N VDSL Modem Router
• Computer connected to the Modem
Step1 On any computer that is
connected to the Internet, type http://192.168.0.1 in the web
browser window and then press Enter.
Step2 Click Utilities.
Step3 elect "Restore Defaults" from the menu on the left.
Step4 Click the last restore button that follows
"Restore Modem to Factory Default State
The manufacturers web site with this advice is here.
http://www.actiontec.com/products/datasheets/Q1000QwFactoryDefaultsHowto.pdf
Sep 24, 2014 | Actiontec Qwest Model Q1000 4-port...
I am trying to connect a D-Link DIR-628 router to a Qwest Actiontec GT-701-WG DSL modem. My computer OS is windows XP-service pack 3. The modem works fine when connected directly to the computer and...
Plug your internet into the router then, the router to the computer. Go to your network settings and run the network setup. This will change the settings in windows to except the router into the network. You may have to restart the computer. This should give you internet access to your computer through your router.
Jan 27, 2011 | D-Link Computers & Internet
How do I connect my modem to my computer with the usb cord? I have windows seven.
First Install Drivers for USB Cord for GT701R DSL Modem. You can get the drivers from the official website. Here is the link to download the drivers http://www.actiontec.com/support/product_details.php?pid=168&typ=all#soft
Apr 05, 2010 | Actiontec GT701R DSL Modem
I am running qwest DSL through a Linksys wrt160N that is brand new. it will work next to the router, but not upstairs or in the basement which is less than 15 meters. The upstairs bedroom is directly above...
If you have concrete floor slabs the the wireless signal from the Linksys will have a difficult time penetrating the floor slabs.
The wireless card in the computers will show a low signal strength.
Try altering the Linksys aerial to a horizontal position and also positioning the Linksys to another location.
You could be getting interference form other wireless sources, check the wireless channels of other wireless router/access points in your area. If they are broadcasting on the same channel then configure your Linksys to broadcast on an unused channel or one that has the weakest signal strength.
If none of these methods work then I would suggest you run network cables from the Linksys to upstairs and downstairs and not use the wireless connection.
If network cabling option is not an option then consider extending the wireless range with wireless repeater access points.
Nov 07, 2009 | Linksys WRT160N Wireless Router
Got Qwest DSL internet and now PS3 can't connect to internet. "Access Point Was Not Detected" What do I do? Modem is Actiontec PK5000. Wireless internet works fine.
I found out that the ps3 is case senitive for the password so it there is caps in the password use caps..the qwest guy gave me a password like fff3093fhfhjh3r and I had to use FFF3093FHFH blah blah
Oct 26, 2009 | Actiontec Computers & Internet
Want to use Dlink DI-514 with Qwest modem to hardwire 2 computers
Believe it or not, Actiontec modems from Qwest are setup as a router already (even though ports are missing from it). You should use a switch instead of another router. Otherwise you will have to configure the DI-514 to act as a switch rather than a router. This is done by assigning a new starting IP address into your DI-514. By default both routers use 192.168.0.1 as the default. You will have to plug the DI-514 seperately into a computer (to take it off the network) and assign a new starting IP address for the DI-514 such as 10.150.1.1 for example. Then you will be able to get it work. I would strongly recommend using a switch instead and turn the wireless on the modem itself (this is why the modem is the router). It will save you some headaches if the power goes out.
Feb 04, 2009 | D-Link Dlink DI-514 Air Wireless 2.4 GHz...
Modem speed slow, reboot modem speeds it up
THE REMOTE COMPUTER DID NOT RESPOND
Oct 22, 2008 | Computers & Internet
Actiontec GT701R modem
what you running it from(computerwise)..sounds like you may have a driver/interface issue with computer.
got backup?
Feb 19, 2008 | Actiontec (GT701) Modem
How to connect to Actiontec GT 701-WG
choose add new connection and choose wireless and follow the direction
Sep 28, 2007 | Sony Playstation 3 (PS3) Console
Actiontec GT701R DSL Modem Logo
91 people viewed this question
Top Actiontec Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you an Actiontec Computer and Internet Expert? Answer questions, earn points and help others
