Frigidaire GLEQ2152ES Electric Dryer Logo
Posted on Dec 23, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Fridgidaire dyrer three years old
Smelt like it cught on fire and then now it does not blow heat when started It set off the fire alarm today- only 3 years old- smells like electrical fire- it was cleaned about a year ago.  What should I do?
Anonymous
Level 2:
  • Expert 71 Answers
  • Posted on Dec 24, 2008
Anonymous
Expert
Level 2:
Answers
71
Questions
0
Helped
26358
Points
171
The heater has most likley shorted to yhe frame and needs to be replaced
My kidde 10 years battery operated smoke alarm has started beeping and I can't shut it off
if 10 yrs old thats usually the life span and should be replaced --three things cause the detector to go off if actual smoke/fire condition --low battery ---or internal component failure [ ionizer ]
Oct 30, 2016 • Home
My watch is 3 hours and 5 minutes off its a shp8948
1. Since all of the settings seem to go through the start/stop button, hold it down for three seconds to put it in "set the watch mode" (when the seconds at the bottom start blinking).
2. Do a quick press of the start/stop button to move from seconds to minutes to hours to years to months to days. The mode button subtracts & the reset button adds.
3. Setting alarms & so on require putting it alarm mode via the mode button. Use the reset button to move to the selected alarm (1-5).
4. Hold the start/stop button for three seconds to "set the alarm mode."
5. Quickly press the start/stop button to between things to set (kind of alarm, hours, minutes).
6. Again, the mode button subtracts & the reset button adds.
7. A three-second press of the start/stop button exits the setup mode.
Feb 27, 2015 • Watches
Williams wall heater setting off co2 alarm
Then it may well need a service or check the alarm
No heat blowing from vents
probably your blower motor resistor has fried, not an expensive fix ath a garage
2helpful
My Scorpion Z6 house alarm system, with fire alarms attached, beeped during the night for no apparent reason. All contoller lights were correctly on indicating it is not a battery problem. I think the beep...
I'm not familiar with your system... but, I'd suggest changing any and all batteries, if it happens again. I don't know about your controller lights, but I do know that the battery does not have to get very low in an alarm before it starts giving you an occasional warning chirp.. If your battery or batteries are over a year old, you should change them, anyway. If a new battery (batteries) doesn't fix your problem, you might try vacuuming or blowing some air into the works on the chance you might dislodge some foreign particle that might be causing this. That said, though, I have had to trash fire alarms that did just how you're describing... because, no matter what, I couldn't make them be quiet.
Nov 14, 2013 • Home
My LG LCD flat screen tv shut off one night and smelt like burnt rubber. It turned back on fine but I'm worried it will catch fire
You are safe. :) It may have shut off from a voltage spike or brown-out on the line. There are several fuses inside of the TV that are supposed to blow before anything catches fire. If it starts smelling again, then unplug it and take it to a service center.
3helpful
RCA Rear Projection problem
the problem with that is probably that your blub has gone out and need to replace it.
Top Frigidaire Dryers Experts
ZJ Limited
ZJ Limited
Paul Bade
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
