Question about Samsung Digimax D53 Digital Camera
Recently changed the battery and now everytime I shoot a picture the camera goes off and has to be re-powered back on to take another. Now, it won't power back on.
  • 903 Answers
You need to check that you have put in the correct type of battery. Some cameras will only work with alkaline batteries.. I had this problem with my samsung when i inserted zinc batteries instead of alkaline, I use duracell cause they are pretty good for taking lots of shots before running out.
Posted on Dec 23, 2008
Camera shuts down when try to take picture
You can try using NIMh batteries instead of using of using the conventional. Most other cameras with similar problems have turned to function normally by using the above mentioned cameras.
Dec 15, 2011 | Sony Cyber-Shot DSC-F707 Digital Camera
My camera lense won't go in. Everytime I switch it
Your batteries are too low.
When you switch on the camera, the lense go in. Then lense comes out fully. Then, if the batteries are low, lense goes in and camera turns off.
But if the batteries are too low, camera turns off before the lense retracts or even before the lense comes out fully.
Aug 27, 2011 | Sony Cameras
I changed the batteries in my Power Shot A720 IS recently when the low battery warning flashed, and had taken only two photos when the warning flashed again. I moved the mode switch to playback and the...
Hi, 1st you must use alkline bat or minimum 800 mhp bat....
and if problem is not solved then cheak the bat cap and connection clean with aomthing,,,,
If any thing else contact me
Khatricamera@gmail.com
Mar 27, 2011 | Canon PowerShot A720 IS Digital Camera
HELP! I have the sony DSC S950, everytime I take a picture, the picture has this green, pink and blue horizontal line on it, and it is so lighty... pls. help me!
When shooting a subject with a strong light source, such as the sun, black lines or other noise may appear on the recorded image. This is called the smear phenomenon and is specific to the CCD of the camera; this is not a camera malfunction. To prevent this from occurring, do not shoot a subject with a strong light source directly.
If the issue persists with all shooting conditions, it may be an issue with the Camera.
Try initializing the Camera. To initialize the Camera, please use the Initialize option under the setup 1 Menu.
If the issue persists, perform a power reset of the Camera.
Performing a manual power reset
  1. Turn off the camera.
  2. Remove the battery pack.
  3. Remove the button-sized lithium battery.
  4. Allow the camera to remain without power for 30 seconds.
  5. Reinsert the button-sized lithium battery.
  6. Reinsert the battery pack.
  7. Turn on the camera.
If the issue persist, service is required.
Jan 07, 2011 | Sony Cyber-shot DSC-W50 Digital Camera
My 70-200 is acting up. When mounted and shooting,
yes- the internal mechanicsw of hte lens pull from the camera body - are the contacts between the lens and body clean? your probably going to need to send the lens in for repair. :(
Mar 07, 2017 | Nikon 70-200mm f/2.8D VR G-AFS ED-IF Lens
The date will not stay set. Every time we turn the camera on it opens with the date screen. We set the date and it then goes into shoot mode but the date is not set. All pictures are stamped with the...
to keep the date on, you have to leave the camera off with a charged battery for 24 hous to charge the inner battery that keeps date on. If this doesn´t solve the problem then is because the inner battery won´t charge anymore, but it will take pictures as normal without the date. To avoid this don´t leave the camera too long without use or with a worn battery.
Oct 04, 2009 | Sony Cyber-shot DSC-W120 Digital Camera
Canon EOS 40D shoots on its own.
Sounds like a software issue, try to upgrade or reload the firmware.
I hope it helps :)
Oct 26, 2008 | Canon EOS 40D Digital Camera
Shuts off after pic
have you changed your batterys recentley as digital camras work better with rechargable batterys
Jun 18, 2008 | Nikon Coolpix 5600 Digital Camera
Camera switches off when I press the shoot button
Are you using NiMH rechargable batteries? Digital caemras are real battery eaters and Nickel Metal Hydride batteries are the only ones that can stand up to the drain. Buy ones with the highest power rating yu can get. If this doesn't help, then the power board has started to fail and needs replacing.
Apr 01, 2007 | Fuji FinePix A605 Digital Camera
Samsung Digimax D53 Digital Camera Logo
Top Samsung Cameras Experts
Computer Links
Jerry Z
Are you a Samsung Camera Expert? Answer questions, earn points and help others
