Question about Sunbeam 4237 / 4238 Iron with Auto Shut-off
Iron whuts off
While using the iron on high settings, it will shut off (with the red light blinking) and loose heat. I have to press the + or - button in order for it to turn back on. Is this a malfunction or am I doing something wrong?
    Genius:
  • 1,074 Answers
Check the circuit at the switch it could ave faulty cap that is not regulating the voltage properly.replace it.good luck
Posted on Apr 18, 2007
Why light blinks then goes off when switch is still in the on position
The thermostat in the iron controls the temperature of the iron. The red light indicates when the power applied to heat the iron which is set by the temperature dial on the iron. When it reaches the correct temperature the thermostat turn off the power and that is when the red light switches off.
Jan 15, 2012 | Irons
Iron heating sporadically and sensor lights working sporadically
It looks like the cord has a loose connection and will need to be replace.
Mar 29, 2008 | Rowenta DZ9080 Iron with Auto Shut-off
My rowenta iron which is about 4-5 years old starts blinking the red on-off button after only 2-3 minutes of use. Also the orange button will not stay lit. What is the problem? The red on-off button does...
your iron has a thermostat fault its this thermostat thats cutting in and out that puts the red light on it could be fixed but that wont be a cheap fix best bet is to buy a new iron as that would work out cheaper
Sep 11, 2010 | Rowenta DX6700 Iron
Iron won't heat up, the 3 lights of yello green and red blinking
Here is a tip that will help you to troubleshoot your iron and figure out what is wrong with it.
Electric Iron not Heating Up or not Working Right
http://www.fixya.com/support/r5300202-electric_iron_not_heating_up_or_not
heatman101
May 03, 2010 | Rowenta DZ5080 Iron with Auto Shut-off
My iron will not stop flashing and will not go to green light -- it will not heat up
Hello :
Check the fuse first ! If the fuse is in good condition , then try this troubleshooting .
1: Make sure there's enough water in the tank if the iron won't steam. Fill the tank up .
2:Check that the iron is set to a steam setting. Some of the settings are dry and won't create steam.
3:Set the temperature dial to the shaded setting which represents steam. You'll see a little dark cloud-type icon with raindrops as opposed to a white cloud with a stripe through it. The dark cloud represents moisture (steam), and the white cloud with the stripe through it represents no steam.
4:Allow the iron to heat up for a while and to emit steam for a couple of minutes while pressing the extra-long burst button a few times. That should get rid of any impurities which can cause blockages. Try this if the iron hasn't been used for a while and steaming is intermittent.
5:Iron horizontally. Steam is only generated when the iron is horizontal.
6:Use the maximum steam setting when the iron is set to its maximum temperature setting.
7:Let the iron get to a high temperature before expecting steam. If the soleplate isn't hot enough, the water won't turn to steam and will in fact drip, spit or leak from the soleplate. Some Rowenta irons have an anti-drip system, which will turn off the steam when ironing at a low temperatures. Turn the temperature up, if needed.
PLEASE DON'T FORGET TO RATE !
Apr 21, 2010 | Rowenta DZ5080 Iron with Auto Shut-off
Switch light goes on when pressed but goes off if not pressed
Switch light goes on when pressed but goes off if... OR iron does not heat at all even pressing the button to turn it on continually.
Don't understand which one question you are asking
But if there is no heat at all after switching it on, it needs to go to iron heaven but be sure to cut the plug of the end, Saftey reasons at the dump. BUT if lights are coming on the iron is working. the large dial on the water filler is temperature control. Turn this around to cotton or linen.
The light will come on and off while in use, it allows you to know that the iron has cooled and is going back to your select temperature( on the large dial)
Make sure that you use water in the iron as it will aid your ironing and make it quicker. Make sure that the iron temperature dial on the water filler is at the correct temperature for the item that you are ironing.
Hope this helps
Sep 17, 2009 | Black & Decker Steam Xpress AS250 Iron...
Red light keeps blinking and iron shuts off
Sounds as if the cable may be damaged or a loose connection. May be cheaper to buy a new one from wallmart or similar store.
Jul 31, 2009 | Rowenta Effective DX1900 Iron with Auto...
I'm having a problem with the auto shut off of my sunbeam 421A series iron. The iron works great until the auto shut off comes on and the red light starts blinking. I understand that the iron should...
Unless you have a 5 or 6 hundred dollar iron, or unless it is brand new, and still under warranty, there is an excellent rule of thumb when an iron quits working: Buy a new one! These days, irons can be purchased cheaply enough that it is WELL worth the money. Not just for the convenience, but for the safety issues. This is an appliance that could burn your house down even if it's in PROPER working order. Hope this helps!!
Chad
Sep 21, 2008 | Sunbeam 4214 Iron
Red Light Blinking
heatman101
Jun 11, 2008 | Krups V70 Iron
Black and Decker AS775 Iron won't reset to heat up.
heatman101
May 22, 2008 | Black & Decker AS775 Iron
Sunbeam 4237 / 4238 Iron with Auto Shut-off Logo
724 people viewed this question
Top Sunbeam Irons Experts
Wayne Fellows
Wayne Fellows
Craig Butler
Craig Butler
ray gallant
Are you a Sunbeam Iron Expert? Answer questions, earn points and help others
