Software problem How do I correct this computer problem? OLE microsoft draw server may only be used to embedd object. I have updated Kodak Easy Share and now when I try to launch this is the error that pops up.
  • Roy Deros Dec 24, 2008
    Bytes error info.
    0000: 7b 39 31 35 31 37 36 33
    0008: 31 2d 41 39 46 33 2d 34 1-A9F3-4
    0010: 42 37 43 2d 42 34 38 32 B7C-B482
    0018: 2d 34 33 45 30 30 36 38 -43E0068
    0020: 46 44 35 35 41 7d
  • Roy Deros Dec 27, 2008
    I have SOLVED the problem myself and NO LONGER require help
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Initially, pls postback what Windows you are using, 98, XP or Vista. Offhand a couple of possibilities:
  • the Kodak Easy Share installed is a trial only and the trial period has lapsed;
  • Microsoft Draw is not installed in your computer.
Pls post back as requested.
Good luck and Thank you for using FixYa. Happy Holidays.
Posted on Dec 23, 2008
  • 758 Answers
Could you tell me what the error says?
Excel Corruption files
Without seeing the file, it is difficult to diagnose what is going on, but I will offer some ideas.
What version of Excel are you using? Are you using Excel 2003? Was the file you are trying to open created in Excel 2007 or Excel 2010. If so, it might be using the new format and therefore will not open in Excel 2003 and older.
It is possible the Excel file is data that was imported from a source in which Excel cannot import. Does the Excel spreadsheet contain any imported data?
Try to use: XLSX Viewer Tool here :
Those are the most likely causes of the corrupt data. Is every file you open in Excel corrupt, or just this one workbook? If it is just this one workbook, then, yes, it sounds like it is corrupted. If every file you open with Excel is corrupt, then your version of Excel could be corrupt, but that is unlikely.
Jul 10, 2015 | Microsoft Excel for PC
OLE (Object Linking and Embedding) is a technology that enables application to create compound documents that contain information froma number of different sources.
Sep 25, 2010 | Microsoft Computers & Internet
Autocad 2010 problem
If you run Win7 in XP mode, all should be fine.
May 06, 2017 | Autodesk AUTOCAD LT 2008 SLM 10 SEATS...
The desctop is locked
COM Surrogate errors The Component Object Model (COM) is a platform for developing software components developed by Microsoft and commonly used on operating systems such as Windows Vista, Windows XP or Windows 2003 Server. COM has been known under many names over the last few years including OLE, ActiveX, DCOM and COM+. Essentially it is designed to allow for easy re-use of software.
So what are these errors? COM Surrogate errors can occur when something wrong happens when software uses in-process components outside the main process either on the same machine or on a remote server. The default DLL surrogate (Dllhost.exe) can act as a host for in-process components. This is often used on Windows Vista, XP or Windows Server 2003.
According to Microsoft
"The file Dllhost.exe is an executable component that you can run remotely and instruct to load any in-process component, providing the component with a surrogate parent process and security context."
How to help fix this? Usually some software is out of date on your PC. You could try updating your software components. You might try updating software like Nero or DivX as this often happens with media software players for video files, music or MP3s. Other people have reported success by using QuickTime or Real as an alternative to using the software that caused the previous errors. Here is what you need!!! Click on the Above Link. Follow Each and Every Step!!!
Hope This Helps!!! Please Rate my Response!!! Thanks!!!
Mar 13, 2009 | Microsoft Windows XP Home Edition
What is the compatible database for visual basic 6.0?
Microsoft Access uses the Jet Engine. In VB 6, you can create a data connection using ODBC or OLE DB. Here is an example of OLE DB:
"Provider=Microsoft.Jet.OLEDB.4.0;Data Source=C:\YourAccessDB.mdb;User Id=;Password=;" Good luck
Mar 09, 2009 | Microsoft Press MS Access 2000 and Visual...
Kodak Easy Share 5300
You need to update your Kodak Easy Share and your printer drivers or try uninstalling and reinstalling the drivers .
The reason you are facing the problem is because the present drivers are not compatible with Publisher
Jan 01, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Regarding ActiveDirectory Services in Windows system
Active Directory (AD) is a technology created by Microsoft that provides a variety of network services, including: using the same database, for use primarily in Windows environments. Active Directory also allows administrators to assign policies, deploy software, and apply critical updates to an organization. Active Directory stores information and settings in a central database. Active Directory networks can vary from a small installation with a few hundred objects, to a large installation with millions of objects (though not easily [3]).
Active Directory was previewed in 1996, released first with Windows 2000 Server edition, and revised to extend functionality and improve administration in Windows Server 2003. Additional improvements were made in both Windows Server 2003 R2 and Windows Server 2008.
Active Directory was called NTDS (NT Directory Service) in older Microsoft documents. This name can still be seen in some AD binaries.
There is a common misconception that Active Directory provides software distribution. Software distribution is run by a separate service that uses additional proprietary schema attributes that work in conjunction with the LDAP protocol. Active Directory does not automate software distribution, but provides a mechanism by which other services can provide software distribution.
Jul 01, 2008 | Microsoft Windows Server Standard 2003 for...
Create a MS Word Report
This from the Word Help files - search for Embed.
You can simply select an area in Excel copy it and paste it into your word document, but embedding allows the data in your Word document to be automatically updated as you change the figures in the Excel Worksheet.
From the Help pages:
You can insert objects (object: A table, chart, graphic, equation, or other form of information. Objects created in one application, for example spreadsheets, and linked or embedded in another application are OLE objects.) into a Microsoft Word document when you want to include information from files created in other Microsoft Office programs or in any program that supports linked objects (linked object: An object that is created in a source file and inserted into a destination file, while maintaining a connection between the two files. The linked object in the destination file can be updated when the source file is updated.) and embedded objects (embedded object: Information (object) contained in a source file and inserted into a destination file. Once embedded, the object becomes part of the destination file. Changes you make to the embedded object are reflected in the destination file.).
default.aspx?assetid=za060473201033 default.aspx?assetid=za060474651033 Embedded object
default.aspx?assetid=za060474661033 Linked object
default.aspx?assetid=za060474671033 Source file
For example, a monthly status report might contain information that is separately maintained in a Microsoft Excel worksheet. If you link (link: Used to insert a copy of information created in one program into a Microsoft Word document while maintaining a connection between the two files. When the information changes in the source file, the changes are reflected in the destination document.) the report to the worksheet, the data in the report can be updated whenever the source file (source file: The file that contains information that was used to create a linked or embedded object. When you update the information in the source file, you can also update the linked object in the destination file.) is updated. If you embed (embed: To insert information created in one program, such as a chart or an equation, into another program. After the object is embedded, the information becomes part of the document. Any changes you make to the object are reflected in the document.) the worksheet in the report, your report, or destination file (destination file: The file that a linked or embedded object is inserted into. The source file contains the information that is used to create the object. When you change information in a destination file, the information is not updated in the source file.), contains a static copy of the data.
default.aspx?assetid=za790050001033The differences between linked objects and embedded objects
The main differences between linked objects and embedded objects are where the data is stored and how you update the data after you place it in the destination file.
Linked objects When an object is linked, information is updated only if the source file is modified. Linked data is stored in the source file. The destination file stores only the location of the source file, and it displays a representation of the linked data. Use linked objects if file size is a consideration.
Linking is also useful when you want to include information that is maintained independently, such as data collected by a different department, and when you need to keep that information up-to-date in a Word document.
When you link to an Excel object, you can use the text and number formatting from Excel, or you can apply the formats supplied by Word. If you use the Word formats, you can preserve formatting when the data is updated. For example, you can change table layout, font size, and font color without losing those changes once the object in the source file is updated.
Embedded objects When you embed an object, information in the destination file doesn't change if you modify the source file. Embedded objects become part of the destination file and, once inserted, are no longer part of the source file.
Because the information is totally contained in one Word document, embedding is useful when you want to distribute an online version of your document to people who don't have access to independently maintained worksheets.
default.aspx?assetid=za790050001033Edit and update linked objects
To edit a linked object in your document, use the Links command on the Edit menu.
By default, linked objects update automatically. This means that Word updates the linked information every time you open the destination file or any time the source file changes when the destination file is open.
If you prefer, you can change a linked object's setting so that the linked object is updated only when you choose to manually update it.
To ensure that your document is always up-to-date, you can also update linked objects whenever you print the document.
To prevent updates, you can lock individual linked objects. When you lock a link, Word uses the last information available from the source file.
You can also permanently break the connection between a linked object and its source file.
default.aspx?assetid=za790050001033Edit embedded objects
To edit an embedded object, double-click it, and then make changes to it in the source program (source program: The program used to create a linked object or embedded object. To edit the object, you must have the source program installed on your computer.). If you don't have the source program, you can convert the embedded object to the file format of a program you do have.
Apr 13, 2008 | Microsoft Office Professional 2007 Full...
CLARIS DRAW 1.0 print problem with Windows XP
Sounds like old software (1995) with a much newer operating system. I would upgrade to whatever is compatible with XP or take your OS back to what works with the software. I'd go with Corel Draw with XP. Vintage software has to be run with the same vintage OS to work properly. Hope this helps!
Jan 07, 2008 | Claris Draw (DRAWV1) for Mac
"Pocket PC 2002 Update 1.0"
Microsoft Pocket PC 2002 Update 1 official statement This document provides useful information for end users and IT professionals to successfully update Microsoft® Pocket PC 2002 with the Microsoft® Server ActiveSync® client. It also outlines improvements to the Pocket PC 2002 software included in the update. New Feature: Microsoft® Server ActiveSync® client gives users the ability to synchronize directly through Microsoft® Mobile Information 2002 Server with their Microsoft® Exchange Server. Improvements: Improved support for Point-to-Point Protocol (PPP) connections to correct problems experienced when connecting to read e-mail or browse the Web while away from the office. Improved connection support in instances where a specific Internet Protocol (IP) address must always be used. Connection Manager no longer reverses static IP addresses and Domain Name System (DNS) server names. Improved Pocket Outlook Object Model (POOM) support for additional programs you can download or buy for your Pocket PC 2002. If you encountered problems with new programs crashing on your device, this update will help prevent future crashes. Improved viewing of Wireless Application Protocol (WAP) pages. Improved e-mail support for Simple Mail Transfer Protocol (SMTP) servers. Further improvements have benn made in the following features: PPP Networking Connection Manager POOM (Pocket Outlook Object Model) WAP Inbox To download this MS Pocket PC Update 1.0 from our Download files area click here Download and unpacking instructions: To download the file, simply "click" the desired file or link and select save to disk. Download the file to a known directory on your hard disk drive. For example: c:\Temp Open Windows Explorer and locate the "downloaded file" on your hard disk drive. Use an unpacker program to extract the files to a known location on your hard drive. The shareware WinZip unpacker can be downloaded from
Sep 07, 2005 | Toshiba e570
Computers & Internet Logo
49 people viewed this question
David Payne
David Payne
